Event: Dyno baseline
Date: 04/30/2012
Ambient Temp: 85deg
Elevation: 910'
Weather: Clear
Car: 2005 Subaru Legacy GT Limited Wagon
Tuner: Cobb StreetTuner
Dyno Info: Dynojet
Transmission: 5 speed
Gear: 3rd
Peak Horse Power at RPM: 334.4hp @ 5400rpm
Peak Torque at RPM: 359 ft lbs @ 4300rpm
Baseline hp/tq for a stock on same dyno 2011 WRX Stage 2 was 272hp / 317 ft lbs
Target Boost: 21.0psi
Target AFR: 11.75
SAE Correction factor: 1.02
Fuel: 93 octane
Engine/Power Modifications: - Deadbolt VF22 -1820 with vf40 compressor cover
Labonte Methanol injection, Wossner 4032 pistons, PTP turbo blanket
One step colder plugs
Borla Header, Crucial uppipe, Crucial catted downpipe, Magnaflow 2.5 in mufflers
Prodrive 3-port EBCS
AEM Intake
TGV deletes
Perrin Top mount intercooler
Walbro fuel pump
Deatchwerks 740 injectors
Driveline Modifications: ACT clutch, WRX flywheel
Suspension Modifications: JDM Spec B Bilsteins with Prova springs
Other Modifications: Rota Formula Mesh 18x8
335HP/360Tq VF-22/1820 clone with Meth
