Reload this Page Where is the turbo range?
#1: 10-30-2012, 04:21 PM
 Roche
Roche's Avatar
Car: 05 LGT 5EAT 226k
Send a private message to Roche Find all posts by Roche Reply With Quote
Since I need a timing belt and other things, I'm trying to keep it easy on the car. I want to stay out of turbo range, i.e, use the cars own power.
Where in RPMs does the turbo kick in? I also want to know to keep it under a certain speed on the highway because I'm assuming 80 is in the range.
Roche
Find More Posts by Roche
#2: 10-30-2012, 05:22 PM
 chaz517
Car: 07 5spd Legacy GT White
Send a private message to chaz517 Find all posts by chaz517 Reply With Quote
Has nothing to do with speed or rpms per se. Has to do with the load you put on it. Just dont depress the gas pedal too far and shift under 3k and uwill be golden
chaz517
Find More Posts by chaz517
#3: 10-30-2012, 08:32 PM
 GEE-OTTO
GEE-OTTO's Avatar
Title: GEE OTTO
Car: 08 QSM LGT
Send a private message to GEE-OTTO Find all posts by GEE-OTTO Reply With Quote
If your TB and related parts (pulleys, pump) are toast the act of driving it exposes you to risk staying out of boost would mean using higher gears for lower speed driving and lugging the engine which is a different type of strain on the ol EJ
GEE-OTTO
Find More Posts by GEE-OTTO
#4: 10-31-2012, 12:45 PM
 Roche
Roche's Avatar
So you're saying don't shift too early? I have a 5EAT and I usually have it shift around 1800-2500 (again, being easy on it) but in shift mode I shift around 2-2500 RPM
Roche
#5: 10-31-2012, 02:22 PM
 dr_sharp
Title: drives a hybrid now :(
Car: i ride a bike
Send a private message to dr_sharp Find all posts by dr_sharp Reply With Quote
the turbo isn't too difficult to remove.
or a simpler solution would be just remove the intercooler... boom no more boost!
lol
dr_sharp
Find More Posts by dr_sharp
#6: 10-31-2012, 02:57 PM
 BAC5.2
BAC5.2's Avatar
Title: OTM Dir. of Engineering
Car: Rental cars
Forces on the timing belt are almost entirely independent of RPM and power output.
What do you intend to gain by staying out of boost?
BAC5.2
Find More Posts by BAC5.2
#7: 10-31-2012, 06:04 PM
 Roche
Roche's Avatar
Just being easy on it. I also haven't removed the banjo bolt screen which is the reason for my last one blowing at 99k
Roche
#8: 11-01-2012, 09:24 AM
 ripemeat
Title: Banned
Car: Saxual content
just stay off the gas pedal as much as possible. /thrad.
ripemeat
Find More Posts by ripemeat
