Reload this Page Best way to address squeaky pulley
#1: 05-15-2013, 10:00 PM
 psucaptainkickass
psucaptainkickass's Avatar
Title: I need a new title.
Car: 2005 Legacy 2.5 GT 5MT
Send a private message to psucaptainkickass Find all posts by psucaptainkickass Reply With Quote
So I suspect the circled pulley is squeaking by my super scientific hearing test. What's the best way to address this? Completely new pulley? Shot of WD-40?
psucaptainkickass
Find More Posts by psucaptainkickass
#2: 05-16-2013, 08:54 AM
 robitrice
Car: Driveway Ornament
Send a private message to robitrice Find all posts by robitrice Reply With Quote
a way to check and make sure it the right one is get a screw driver and place it on the pulley while the car is idling. Like a stethoscope. just replace the pulley, short money and pretty easy to do
robitrice
Find More Posts by robitrice
#3: 05-16-2013, 09:10 AM
 That Guy 2-1
Car: '11 Leggy, '08 Outback
Send a private message to That Guy 2-1 Find all posts by That Guy 2-1 Reply With Quote
A/C clutch pulley replacement is pretty straight forward. Mine broke in one of my older cars and made a mess, then I regretted not replacing it sooner.
That Guy 2-1
Find More Posts by That Guy 2-1
#4: 05-16-2013, 09:24 AM
 psucaptainkickass
What do I do with the screwdriver? Press it against it? Am I looking for an altered sound there?
Is the A/C Clutch Pulley the pulley that I have circled. I actually don't know the names of all these pulleys.
psucaptainkickass
#5: 05-16-2013, 09:59 AM
 breadstick
Car: 2007 Legacy GT
Send a private message to breadstick Find all posts by breadstick Reply With Quote
Yes, that is the A/C clutch pulley. With the car running and the AC off (you don't want it running with the screwdriver and your face that close to it) wrap your fist around the screwdriver handle and put the tip against the pulley. Put your ear to your ear to the screwdriver handle and the sound will travel through the screwdriver if it's the bad pulley.
This should go without saying, but if you have long hair make sure you have it pulled back or a hat on. The belt will be spinning and getting hair caught in the belt will ruin your day.
breadstick
Find More Posts by breadstick
#6: 05-16-2013, 11:30 AM
 Max Capacity
Max Capacity's Avatar
Check other pulleys to see if they sound different.
be careful.
Max Capacity
#7: 05-16-2013, 07:44 PM
 JmP6889928
JmP6889928's Avatar
Location: Michigan where the snow flies, the salt sticks, and the vote is in the WRONG direction
Car: 05 LGT EAT, 97 OB wagon
Send a private message to JmP6889928 Find all posts by JmP6889928 Reply With Quote
Are you sure it's not a belt squeaking?
JmP6889928
Find More Posts by JmP6889928
#8: 05-17-2013, 06:07 AM
 06LegacyRBP
06LegacyRBP's Avatar
Car: 2006 LGT Limited
Send a private message to 06LegacyRBP Find all posts by 06LegacyRBP Reply With Quote
if this just tighten back up..
06LegacyRBP
Find More Posts by 06LegacyRBP
#9: 05-17-2013, 08:50 AM
 psucaptainkickass
Could be a belt...I'll have to check this all out when I have some downtime.
psucaptainkickass
#10: 05-18-2013, 08:45 AM
 Danteneon
Danteneon's Avatar
Car: 2008 OBK XT Limited
Send a private message to Danteneon Find all posts by Danteneon Reply With Quote
I would put my money on the A/C idler pulley below and to the left of the A/C compressor. We replace many of those.
Danteneon
Find More Posts by Danteneon
