Go Back   Subaru Legacy Forums > Technical Forums > Turbo Powertrains (2.0GT, 2.5GT, 2.5XT)
Reload this Page Fuel pump need a tune??
#1: 05-08-2012, 07:37 AM
 legacy95
legacy95's Avatar
Send a private message to legacy95 Find all posts by legacy95 Reply With Quote
I just purchased a Deatsch dw65c fuel pump for my 05lgt. Will I need a tune when this is installed or will the fuel pressure regulator do its job.
legacy95
Find More Posts by legacy95
#2: 05-08-2012, 08:25 AM
 austin42008
austin42008's Avatar
Car: O5 Lgt stage 3
Send a private message to austin42008 Find all posts by austin42008 Reply With Quote
You don't need a tune for the fuel pump
austin42008
Find More Posts by austin42008
#3: 05-08-2012, 08:47 AM
 fahr_side
fahr_side's Avatar
Title: Royal Pain in the Ass
Car: '08 SWB BNR16G LGT (aka WRX)
Send a private message to fahr_side Find all posts by fahr_side Reply With Quote
Depends. If you had IDCs pushed into the 90s on the stock pump, with the stock MAF scaling you might not hit rich AFR targets. Since the stock MAF scaling isn't too awful many tuners will not change it, but just target a slightly higher AFR than is wanted.
For example you might target 10.5 AFR knowing very well the stock fuel system can only hit 10.8, which is what you wanted all along. Now you upgrade the pump and suddenly you can reach 10.5 AFR or even richer. You have more safety in that your pump isn't getting its neck wrung, but you will probably lose a bit of power.
While I might not re-tune the car for this I'd probably want to check AFRs at high revs to see they are what you wanted and tweak to suit.
Never pass up a good opportunity to keep your mouth shut
fahr_side
Find More Posts by fahr_side
#4: 05-08-2012, 11:54 AM
 mcg_
Car: 05 LGT LTD 5MT - Basic stage 2
Send a private message to mcg_ Find all posts by mcg_ Reply With Quote
fahr_side, so are you saying that a new fuel pump won't harm a stock LGT (i.e., not tuned)?
mcg_
Find More Posts by mcg_
#5: 05-09-2012, 09:56 PM
 fahr_side
fahr_side's Avatar
If you're stock it probably won't make any difference. If it does it might be richer by 0.1 AFR up top.
The guys who are running 90%+ IDC and stock MAF scaling will have more issues with this.
fahr_side
