What do you think? 18x8.5" +48. They were sandblasted and then primed rather crappy. I can fix that. Now for those who don't know these were made in Japan and the name meant "5th Dimension" and pronounced 5 GeeGan (sp?) I believe. Center caps included and painted anodized valve stems.
Here they are from the factory. $1700 brand new:
Here is how I got them:
Here is a quick fit on the rear and boy are these large:
Bout 1/2" from the control arm:
And here is my issue. One of them has a weld on the back and some weights. The weld looks really quality actually and I can see no signs of cracking or weld on the inner lip. The outer lip is a tiny bit out of round but the sealing surface is smooth as can be.
So, for $200 did I score or do I have a set of 3 wheels and need a new rim?
I weighed one and they are 22 pounds each! But what can ya do. I will finish them in gun metal and mount some 225/40/R18's.
Let me know if I should make these into a coffee table or go mount them up.
Thanks.
Jon
