Reload this Page Misfire, Checked everything?
#1: 03-06-2012, 08:55 AM
 2manysubies
2manysubies's Avatar
Car: '13 BRZL,05 LGTL Stg3+,05 LGTLW+3 subies
Send a private message to 2manysubies Find all posts by 2manysubies Reply With Quote
05 LGT stock, P0302, changed plug(all were changed before I bought car)
changed coil pack(subaru)
changed injector(subaru)
Did comp check 125psi(same as other 3 cyl. +/- 2psi
checked coil connector and re-routed wire a bit
checked for vac. leaks @ manifold/head area(spray method)
removed TMIC, checked for Vac. lines/leaks/cracks
Nothing out of place or "odd" looking...
I'm at my wits end.
WHAT AM I MISSING???
R/Mac
2manysubies
Find More Posts by 2manysubies
#2: 03-06-2012, 08:58 AM
 2manysubies
OBTW, the car runs good, doesn't feel like its misfiring, gets CEL, sometimes the CEL blinks on/off before it goes on steady, did clean the MAF/IAT
2manysubies
#3: 03-06-2012, 09:07 AM
 bmx045
Title: Banned
Car: 08 LGT, built motah
Find all posts by bmx045 Reply With Quote
maf sensor, clean it
bmx045
Find More Posts by bmx045
#4: 03-06-2012, 11:08 AM
 GTTuner
GTTuner's Avatar
Title: Whut, who me?
Car: It runs 12's
Send a private message to GTTuner Find all posts by GTTuner Reply With Quote
Cylinder leak down percentage.
GTTuner
Find More Posts by GTTuner
#5: 03-06-2012, 04:45 PM
 20lgt06
20lgt06's Avatar
Car: 2007 lgt BrenTune 334whp@375wtq
Send a private message to 20lgt06 Find all posts by 20lgt06 Reply With Quote
i was battling the same issues, did all off the above- ended up with a burnt valve. does your rpm dip? vac leak check bov or on your year the blue t fitting?. when they changed the injectors did they use all new gaskets and orings? also check voltage coming off the harness. checked your intake ? pvc assembly replaced? bad or clogged cat? fuel filter clogged? just to throw out a few others i would check. is that the only code ?
The Following User Says Thank You to 20lgt06 For This Useful Post:
2manysubies (03-08-2012)
20lgt06
Find More Posts by 20lgt06
#6: 03-06-2012, 05:01 PM
 suds2250
suds2250's Avatar
Car: 05 5MT wagon
Send a private message to suds2250 Find all posts by suds2250 Reply With Quote
Is the problem at idle, and get better at high RPM? I had a similar issue, the engine would act like it was running on two cylinders. Turned out to be the oil control valve (OCV) was sticking, causing the timing to be way off.
335HP/360Tq VF-22/1820 clone with Meth
The Following User Says Thank You to suds2250 For This Useful Post:
suds2250
Find More Posts by suds2250
#7: 03-07-2012, 10:17 AM
 2manysubies
Thanks for all the suggestions! The CEL comes on randomly,more often when it's cold out(all the time right now in Maine LOL) when it's acting up, Idle is rough. I did remove the TMIC and checker the blue T vacume, thew BOV sems intact, will do a vacume check on it, the injectors were new and new "O" rings. I didn't check the pvc, but I will. What voltage are you refering to on the harness?? Vacume check did not indicate a bad cat. I have a leak down tester comming, don't want to borrow one from the shop in case it breaks, I own it $$. As far as the oil control valve, how do I check it? Location? I do ALL my own work on my subies, but this is mt first Turbo, I am getting quite intimate with the system as we speak. Thanks for all the help again. Compression was 124-126psi, is this normal for a higher milage motor?? For my last answer, P0302 is the only code I get.
Thanks again
R/Mac
2manysubies
#8: 03-07-2012, 07:37 PM
 suds2250
suds2250's Avatar
Car: 05 5MT wagon
There are lots of threads on the OCVs
http://legacygt.com/forums/showpost....28&postcount=8
suds2250
#9: 03-07-2012, 07:51 PM
 snowboardr424
Car: 2007 Evergreen Metallic LL Bean Forester
Send a private message to snowboardr424 Find all posts by snowboardr424 Reply With Quote
I had a strange cylinder 4 misfire on my old wrx...I would only get the misfire at a cold start up (never moving,) maybe a week or more in-between lights.
I cleaned the iacv, crank sensor, cam sensor, maf, you name it...the culprit was the front o2 sensor at 70k.
snowboardr424
Find More Posts by snowboardr424
#10: 03-08-2012, 07:06 PM
 2manysubies
OCV's checked today, cleaned, actuated (12v electric) and manual movement to check for binding, vacume check BOV good, waiting on leak down tool (shipping now) removing TMIC again tomorrow, better check for lines, fittings, cracks etc...
Mac
2manysubies
#11: 03-08-2012, 08:19 PM
 suds2250
suds2250's Avatar
Car: 05 5MT wagon
Good to hear. How/when did the misfire code happen? what condition was the engine running at? (RPM, load). Has it happened since?
suds2250
#12: 03-08-2012, 11:08 PM
 2manysubies
Usually when the car is slowing down to a stop, I can feel a slight vibe(miss) in the steering wheel when driving normally, I just know I'm gonna get the CEL, 9 out of 10 times I'll get the light within a few minutes. If I nail it when it's doing the vibe thing, it scoots like hell, no misfire at all, even with the CEL on it runs good when I get on it. Another thing, if I clear the code with the scanner(which I keep in the car) I may get a CEL in a few hours drive time, if I disconnect the battery for about 20 minutes, the car runs sweet for days, the ECU is learning bad habits from somewhere, I only use Mobil hi test(91) with 10% ethanol, same station. I really want to put 5 gal of 100 low lead(aviation fuel) in mixed with the rest pump gas and see how she does. I WILL get to the bottom of this, I never give up, it's only a machine! Feel free to PM with any suggestions, and Thanks!
R/Mac
2manysubies
#13: 03-11-2012, 03:57 PM
 20lgt06
20lgt06's Avatar
are you running a stock top mount ? check the throttle body hose and the ring gasket that goes into the stock tmic
20lgt06
#14: 03-12-2012, 10:44 AM
 2manysubies
I've had the TMIC off already, everything seems in order, I'm gonna take it off again to check PVC system, I'll take another look. Thanks!
Mac
2manysubies
#15: 03-15-2012, 03:05 PM
 2manysubies
OK, Got my leak down tester, checked with engine at op. temp, only checked the #2 Cyl. Total leak down:
1st test = 14% held steady.
Switched adapter hose to apply 100psi to cylinder(seat rings a bit) TDC verified on compression stroke.
2nd and 3rd tests = 12%
Checked compression again 4 cranks 125psi
I didn't hear any leaks from the usual places, exhaust, oil fill etc. I don't think the issue is mechanical, I guess this falls into the "Subaru stumble" catagory, havn't got a CEL in over a week. driving real smooth 21mpg(mixed) I'll keep looking, think I'll check the brake booster for vacume requirements. ALL SUGGESTIONS WELCOME!!
Mac
2manysubies
