Go Back   Subaru Legacy Forums > Technical Forums > Exterior/Aesthetic
Reload this Page Cheap and Easy way to mount/relocate your front license plate.
#1: 01-06-2013, 09:12 PM
 mattmattyxcore
mattmattyxcore's Avatar
Car: 95 Legacy LS and 2000 Mazda Protege LX
Send a private message to mattmattyxcore Find all posts by mattmattyxcore Reply With Quote
While I was waiting for some PB Blaster to set in I thought of making a license plate bracket since mine was just screwed into the bumper by the previous owner. Unfortunately I live in one of the few states that requires front mounted plates. Here is what I came up with...
Materials:
4 Screws (Anything works)
2 Brackets from a set of cheap window blinds that are sold at any major retailer.
There is only one in a box and they are used to support the middle of the blind, we never use them.
2 Bolts with washers (Used to secure Plate to Brackets)
Drill Your pilot holes for the brackets. Make sure they are the correct width.
Mount up the brackets.
Bolt the plate to the brackets. I used stainless steel so it wouldn't rust and discolor the plate.
Voila! You're done. I mounted mine to the right side just to see how it looks but the beauty is you can mount just about anywhere. The other benefit is that the screw holes are small and located on the underside of the bumper so they won't be as noticeable if you ever have to remove them.
mattmattyxcore
Find More Posts by mattmattyxcore
#2: 01-06-2013, 09:13 PM
 SurlyOldManMN
SurlyOldManMN's Avatar
Car: 2010 LGTL & 91 Angry Turbo Legacy
Send a private message to SurlyOldManMN Find all posts by SurlyOldManMN Reply With Quote
Not bad at all! Does it stay flat at speed?
SurlyOldManMN
Find More Posts by SurlyOldManMN
#3: 01-06-2013, 09:14 PM
 mattmattyxcore
So far so good but I don't get over 75mph.
mattmattyxcore
#4: 01-06-2013, 09:23 PM
 famaya26
famaya26's Avatar
Car: 05 LGT 5EAT
Send a private message to famaya26 Find all posts by famaya26 Reply With Quote
Wow, very innovative. Good job man!
famaya26
Find More Posts by famaya26
#5: 01-07-2013, 04:43 AM
 mattmattyxcore
Thanks folks, just wanted to share the idea.
mattmattyxcore
#6: 01-07-2013, 03:05 PM
 mattg
mattg's Avatar
Title: Brass Monkey
Car: '05 Limited 5MT Stg 3+
Send a private message to mattg Find all posts by mattg Reply With Quote
Good idea
mattg
Find More Posts by mattg
#7: 01-07-2013, 08:55 PM
 famaya26
famaya26's Avatar
Car: 05 LGT 5EAT
This should go under the cheap and Free mods thread.
famaya26
