Go Back   Subaru Legacy Forums > Walkthroughs > Walkthroughs :: Basic Operation & Maintenance
Reload this Page Disable seatbelt chime - no cutting required!!!
Page 1 of 15 1 2311 > Last »
#1: 05-21-2007, 01:17 PM
 robertsm99
robertsm99's Avatar
Car: '08 Spec-B
Send a private message to robertsm99 Find all posts by robertsm99 Reply With Quote
Alright, so I was pretty fed up with the whole chiming thing and was trying to figure out a way to pull the base of the seatbelt apart b/c I was going to unplugg whatever was causing the stupid chime to continually go off. I tried the 30x click thing and it'd work sometimes and other times it wouldn't.
So, today I had a little bit of freetime and decided to see if I couldn't pop the housing off. I used 2 standard eyeglass screw drivers, pretty thin, and was able to pry off the cover to the base of the seatbelt. Surprisingly enough when I managed to open it up, all there is a a white plastic switch that needs to be slid down and that will turn off the chime permanently.
Below are some pictures I took while doing it, it only took about 15 min and very minimal damage to the housing, I'm sure if you have something thinner to slide in there, you won't damage the housing at all. I'm going to go back in later and put some tape over it to ensure that it stays that way.
Enjoy.
Here are the pictures of what I did for those that want to do it as well.
For any questions feel free to PM me.
ID:	37377   Click image for larger version
ID:	37378   Click image for larger version
ID:	37380   Click image for larger version
The Following 3 Users Say Thank You to robertsm99 For This Useful Post:
benena (12-12-2012), DeathToad (02-16-2013), titoedge (08-19-2011)
robertsm99
Find More Posts by robertsm99
#2: 05-21-2007, 01:23 PM
 Paradiso
Paradiso's Avatar
Car: 05 Stage II ABP 5MT Wagon
Send a private message to Paradiso Find all posts by Paradiso Reply With Quote
I nominate you for F*in genius of the day award!
Paradiso
Find More Posts by Paradiso
#3: 05-21-2007, 01:25 PM
Gitster
Title: Guest
Posts: n/a
Nice but theres an easier way, with no cutting required and no disassembly of the locking mechanism....
http://legacygt.com/forums/showthrea...=disable+chime
Gitster
#4: 05-21-2007, 01:27 PM
 rao
Title: Too Big to Fail
Car: 05 Legacy GT/98 BMW 540 w/Chevy Power
Send a private message to rao Find all posts by rao Reply With Quote
I tried that with my Odyssey and it made the Passenger Air Bag Off light go on all of the time.
There is a much easier way for the Legacy.
Rob
This DISCLAIMER applies to this post.
IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT
rao
Find More Posts by rao
#5: 05-21-2007, 01:39 PM
 robertsm99
robertsm99's Avatar
Car: '08 Spec-B
It's not disassembling the locking mechanism, I'd never tempt to play with that part of the seatbelt, just the plastic housing around it, and it's another way to do it instead of cutting the wire as some have done under the seat or for those who don't feel comfortable with disconnecting a wire.
Just another option, and not a lot of work to do it.
P.S. Still wear your seatbelts, as advocated by the law, smokey the bear, the popo and other folks who care for your safety etc....
robertsm99
#6: 05-21-2007, 01:53 PM
Gitster
Title: Guest
Posts: n/a
I know, I got it. Options are good
Gitster
#7: 05-22-2007, 07:50 PM
 robertsm99
robertsm99's Avatar
Car: '08 Spec-B
Just an update, I went back and put a piece of tape over the plastic piece to keep it in place and it actually doesn't work. You can't buckle the seatbelt with it in place, but without the tape it still works and the chime doesn't return.
It is so nice not constantly hearing that chime anymore!!!!
robertsm99
#8: 05-25-2007, 10:45 AM
 OhBe1
OhBe1's Avatar
Title: Moondog's crewchief
Car: '06 LOB, '97 MX-5, '03 Taco
Send a private message to OhBe1 Find all posts by OhBe1 Reply With Quote
So, the next question is - does it work on the passenger side?
Purely academic, of course...
06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest.
OhBe1
Visit OhBe1's homepage!
Find More Posts by OhBe1
#9: 05-25-2007, 10:52 AM
 robertsm99
robertsm99's Avatar
Car: '08 Spec-B
Well I took apart the passenger side first to see what the beep was, and of course there's no switch like that, but from what I've found the passanger side is shut off as well and hasn't beeped since doing it. I'm pretty sure of it, but havn't taken too many people in my car to really notice if it's off.
robertsm99
#10: 06-29-2007, 07:25 PM
 Max Capacity
Max Capacity's Avatar
Wrong, he's a freak'in god.
Just did this in about 2 minutes.
THANK YOU, THANK YOU, THANK YOU
Yes you need to leave the cover open a bit but who cares.
It's only a subaru anyway's.
Max Capacity
#11: 07-03-2007, 04:14 PM
 robertsm99
robertsm99's Avatar
Car: '08 Spec-B
If you piece it back together right, it should go right back in and not be open at all. I think you just need to pop the top back over the part that flips down.
Also, since the earlier posts, I have had a chance to test it out, and it DOES disable the passenger side as well. No more chimes except when you first start the car!
robertsm99
#12: 07-03-2007, 04:24 PM
 mccorry
mccorry's Avatar
Title: Mr. NiceGuy
Car: 2005 LGT 5MT Stg. 2.5 / 69 Camaro RS/SS
Send a private message to mccorry Find all posts by mccorry Reply With Quote
And this was easier than the 20 click method?
mccorry
Find More Posts by mccorry
#13: 07-03-2007, 08:09 PM
 robertsm99
robertsm99's Avatar
Car: '08 Spec-B
It's more permanent than the 20 click method and is only undone if the dealer or someone goes in there and flips that white switch back. The 20 click method can and does reset itself at time. I know I tried the 20 click method numerous times and it didn't always work, this does.
I guarantee you or double your money back
(P.S. unless you give me money, I can't give you double back if you are unhappy with it)
robertsm99
#14: 07-06-2007, 10:12 AM
 Max Capacity
YEP, IMO much easier.
I use two small common screwdrivers. The kind geeks wear in the shirt pockets. I'm sure you know or have one or two...
Max Capacity
#15: 07-06-2007, 10:16 AM
 Max Capacity
Also, since the earlier posts, I have had a chance to test it out, and it DOES disable the passenger side as well. No more chimes except when you first start the car![/QUOTE]
Yes I had my friend in the car Saturday and she didn't set off the stupid chime.
I asked her if she wanted me to fix her chime, 05 OB. She said it doesn't bother her.
women...
Max Capacity
Similar Threads
Passenger Seatbelt Chime and Light.... icehousewvu Warranty Issues & Problems 4 04-06-2009 07:07 AM
Seatbelt Chime Th3Franz Interior/Audio 13 07-02-2008 01:29 PM
Does anyone know how to disable the seatbelt chime? meyerb Interior/Audio 20 09-27-2006 05:46 PM
Do the people who hate the seatbelt chime not wear their belts? akm3 Interior/Audio 24 02-02-2005 06:31 AM
