Go Back   Subaru Legacy Forums > The Marketplace > Vendor to Member Sales > Suspension/Brakes
Reload this Page Koni Yellow Sport shocks on sale with FREE SHIPPING!!
#1: 02-11-2014, 07:30 AM
 Moddiction
Moddiction's Avatar
Car: 2008 OBP Legacy GT SC'd Honda S2000
Send a private message to Moddiction Find all posts by Moddiction Reply With Quote
It's almost spring time again and the Koni Yellow Sport Shocks are on sale! We are also offering free shipping within the continental US!
Order on our site or give us a call to place order over the phone.
Shocks are in stock ready to ship!
Toll free - 877-738-9672
Click here for the rear shocks.
Click here for the front shock inserts.
Product Description
The Koni Sport product line is one of our specialities. Koni serves Sporting Drivers with a carefully designed range of sport shock absorbers. This product focuses on exceptional road holding and handling, combined with a reasonable level of driving comfort. They can also be used with spring kits to lower a vehicle up to 35mm.
Many of the Koni Sport dampers are externally adjustable by means of an adjustment knob at the top of the damper. This means you do not have to remove the damper from the vehicle to adjust the rebound forces. This enables you to fine tune the handling & ride to suit your driving style.
Dampers without the top adjustable feature can still be adjusted, although they will need to be removed from the vehicle to achieve this. You may wish to use lowered springs with the Koni Sport range, if you do this please be aware the maximum lowering permitted is 35mm. Please also ensure that any bump stops are re-fitted to ensure no damage occurs to the valving should the damper bottom out.
Features
  • Big handling improvements
  • Reasonable ride quality
  • External rebound adjustment on most cars
  • Best KONI shock for all lowering springs
  • Re-buildable and re-valveable for custom vehicle setups
  • Yellow exterior finish
  • Lifetime Warranty
All Koni Shocks are sold ‘per shock’ a complete set requires four shocks
Moddiction
Find More Posts by Moddiction
