04-05-2011, 02:01 PM
FS: "Switchback" LED Turn Signal Bulbs (video demo, sale!)
Title: Vendor II
3157 Dual-Color 60-1210 SMD
3157 Dual-Color 60-1210 SMD is a direct replacement for any 3157-size front turn signal bulb. This is a unique, specialty item. When on as normal, with parking lights, it shines a nice, pure white color, and when you activate the turn signals, it flashes an amber color. Two colors, for an awesome lighting effect!
You might have heard of the many issues in getting these bulbs from us in the past. Finally, after 16 months and 14 prototypes, we have a large stock of the perfectly-engineered bulbs. No modules, totally plug and play. Check it out!!
This bulb has 60 1210-size SMDs. It uses an 3157-size terminal and will fit as a replacement for stock halogen. It uses less power and heat than halogen bulbs, and will last longer, with its engineered heat-sinking technology. A load resistor is embedded to prevent blowing the LED from voltage surge, and a diode is implanted to protect the LED from reverse polarity. The LED is wired for 12v operation, the kind found on all vehicles.
Resistor Option: Some vehicles may have fast-blinking issues when LED bulbs are installed as turn signal replacements. We offer resistors to remedy this issue for a nominal charge. Alternatively, we offer plug-and-play flasher modules to regulate the flashing speed.
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. And we do not jack up the prices to astronomical levels- We're breaking that market trend, and offering you great, low prices, every day. These LED bulbs are made just for us by a company that has been in business since 1992, and every bulb carries with it a one-year full warranty.
CLICK TO SEE MORE PICTURES AND TO ORDER
Thanks!
Paul
04-05-2011, 05:46 PM
Car: 2008 LGT DGM Gone... 2012 SWP WRX Hatch
so this should be compatible with 08 turn signal bulbs which are 3457? and your flasher module would be a direct swap for the 08 one? i'm itching to pull the trigger on these. this is a great deal
04-05-2011, 06:50 PM
Car: 13 Outback 2.5i Premium w/AWP 6MT
too bad my lights aren't cleared, otherwise I'd jump on this. But with my anber reflector still in there, I wonder how it would look. hmmm.
04-05-2011, 09:06 PM
Title: Vendor II
This is compatible, but at this time, we don't have the flasher that is compatible. Please use the resistor kit. Thanks!
04-05-2011, 09:49 PM
Car: 05 Kinugawa TD06SL2/18g 5EAT
These are pretty sweet and definitely considerable once I get some other things done that need to be. Good luck with the sales! We'll be in touch one day.
04-06-2011, 01:57 AM
sweet. just made the order on your website. can't wait to install these!
Originally Posted by Paul J. McCain
Correct on both counts! Thanks!
04-06-2011, 02:48 PM
Title: Vendor II
Shipped out today
04-06-2011, 03:17 PM
Shipped out today
Got shipping info this morning! that's fast
oops. sorry, meant shipping label xD. will take pics and vids once installed
04-06-2011, 04:30 PM
pics pics!
04-06-2011, 09:44 PM
Car: 2008 N/A Subaru Legacy 2.5i
whats the difference between using the flasher module and load resistor kit? why is the resistor kit more expensive than the flasher module? once i get an answer, im pulling the trigger on these bad boys!
04-06-2011, 09:49 PM
Title: Vendor II
You will need the resistor kit for the Legacy, as the flasher doesn't fit this vehicle. As for price, the resistors are simply a more expensive part. Thanks!
04-06-2011, 09:52 PM
I asked about the flasher module for my 08 LGT and you said they were a direct swap... now you're saying the opposite?  i already ordered the bulbs with your flasher module... what do i do now? -_-;;
04-06-2011, 09:57 PM
Title: Vendor II
I'm sorry, I misspoke, please PM or email me your name and I'll send out a resistor kit immediately. We will have the correct flashers shortly but right now do not have the type needed for direct swap in the Legacy.
04-07-2011, 11:52 AM
Title: Vendor II
OK, we have the correct flashers listed, they will be available on Wednesday. Thanks!
04-07-2011, 12:22 PM
Car: 09 IPT EFI Logics 228whp/312wtq
Just ordered the bulbs and resistors for my new headlights! Can't wait
Edit......Paul got my confirmation email and it says flasher module......what I need is just the in line resistor kit, not the flasher module replacement. The order is from unc148@msn.com
