06-24-2011, 03:31 AM
loosing oil inexplicably
Car: 2012 LGT Graphite Gray Metallic
My car is loosing oil to the point that few hundred to 1k prior to oil change the dipstick is completely dry. like bone dry. dealer did some oil test and told e to return in 1200 miles. 1200 miles later, same deal and come to think of it, its been happening since about 30k (@ 48k now). i'm due for an oil change in the next few days and as of yesterday it was just above the lower limit. dealer added 2 qts 1k ago!!! this engine was part of the "recall" and was replaced at 4,700 miles. its not dropping it on the floor, no froth on cap from what dealer told me so i'm scratching my head. thoughts? (AP, that's all, i know someone will ask.)
06-24-2011, 04:25 AM
Car: 05 LGT stage 2+ | 2009 3.0R Limited
My 05 uses about that much oil per 3400 miles of driving. I check my oil every 1000 miles of driving and top off accordingly. I'm un-familiar with subaru's oil consumption policies under warranty (if you still are). When I worked at VW i know for a fact the owners manual charged the customer with topping off all fluids between oil change intervals.
If they told you to come back 1200 miles later they did an oil consumption test. Drain the motor completely of oil. Weigh the oil in grams prior to pouring it in. You drive 1200 miles return they drain the oil completely and then re measure compare the differences, do some maths and bam... exact x qts /1200 miles measurement. Then if it's at a point where they can replace something under warranty it gets replaced, if its not may offer for you to pay for a repair, or just tell you to monitor your oil levels between intervals.
Remember it's a turbo, turbos eat oil. Check your oil levels regularly and top off with choice synthetic as needed. I suggest trying a 5w40 weight.
06-24-2011, 06:34 AM
Title: Need more fast!
I think i remember reading that 1 qt per 1000 miles is normal (from what dealers have said). To me...that is way too much even being a turbo car.
06-24-2011, 06:40 AM
If it's not dripping on the ground, then it's burning the oil. The oil can be getting into the engine in more than 1 way: turbo seals leaking, valve guides worn, or blow by from the rings. I've seen bad PVC valves cause excessive oil consumption too.
Pull a spark plug and check it for evidence of oil burning. At that rate oil consumption, the car should be blowing a blue cloud either under acceleration or when you lift.
06-24-2011, 06:56 AM
Title: Whut, who me?
Car: Tuned for torque!
Time for a compression and leak down test!
The Following 2 Users Say Thank You to GTTuner For This Useful Post:
06-24-2011, 07:07 AM
Title: Moderationor
Car: 08 spec.B GTX3076R | 13 Ford Raptor
Get a leakdown test.
I was having oil consumption issues (1qt every 800 miles) that ended up being a cracked ring land.
06-24-2011, 08:16 AM
Title: Cowabunga!
Car: 09 Honda Civic EX sedan w/ NAV
Same here.
06-24-2011, 10:39 AM
Car: Subaru Legacy GT LTD
Hi Guys,
My car has started to loose oil at an incredible rate as well (1 qt per 1,000 miles). It has 90k miles. Use synthetic oil 10-30. No blue smoke.
I hear a loud rattling in the right valves. Mechanic said it was the hydraulic lash adjusters that was worn.
Could this be the cause of the oil loss?
06-24-2011, 08:41 PM
i am under 50k. the powertrain is still under warranty. taking it in tomorrow...
06-25-2011, 10:03 PM
they are doing oil consumption testing as per subaru. 2 more and they go from there..
06-26-2011, 05:55 AM
i hope the results are really bad so they fix your car
The Following User Says Thank You to iv_05gt For This Useful Post:
06-27-2011, 12:40 AM
Gee thanks!!??
06-27-2011, 04:13 AM
Well If the results are only moderatly bad, they mite ship it and say it's with in tolerance. You obviously have an issue, so i hope the results are to the point where they take action to resolve the issue instead of sending you on your way...
06-27-2011, 05:01 AM
Car: 05 lgt
hey i was also going thru about a quart every 700 mi. or so ....switched to the rotella t6 5w40 and installed the grimmspeed aos system. now i barely lose anything!! oh and also replaced the pcv ..im now at 60k. and bought it at 30k....thought maybe that would help?
The Following User Says Thank You to rapture For This Useful Post:
06-27-2011, 06:02 AM
Until the warranty expires on the person, I'm letting them handle it.
Thread Tools |
Display Modes |
