Reload this Page For those that use Thule 400XTR footpack
#1: 11-03-2012, 12:16 PM
 Drogos
Car: 08' spec B
Send a private message to Drogos Find all posts by Drogos Reply With Quote
with the old aero load bar (pre aeroblade). Thule fit kit says I need 47" but I can get a good deal on used 43s. Going for flash look anyway. Gutter to gutter seems to be roughly 42 on our cars so it looks like it should fit if I can mount them at the very end of the bar. Please advise. Maybe someone could measure theirs. Thanks much in advance
Drogos
Find More Posts by Drogos
#2: 11-03-2012, 12:19 PM
 Max Capacity
Max Capacity's Avatar
Title: Gearhead
Funny, I just put my Thule box back in the shed.
IMO no. you can't mount the bars at the end. I'm guessing the bars less the end caps, will make lots of noise.
Max Capacity
#3: 11-03-2012, 12:23 PM
 Drogos
Car: 08' spec B
can you measure distance between mounting points? I know it's going to be very close but I am hoping I can make it work since deal is hard to pass and I would cut longer bars for flash look anyway.
Drogos
