wannalegacy Posted November 18, 2011 Share Posted November 18, 2011 I've been out of the country a lot since getting my vehicle. Originally I was going to go with the Cobb stage 2 package which included the catted DP and exhaust system. Instead I purchased just the Accessport. The Cobb exhaust system excluding the DP is not available new anymore since it is out of production. I'm looking for a good exhaust system and catted DP and an UP for my car that will give me decent performance gains without having too much drone while driving on the highway. Are there any setups out there with good performance gains that pass emissions in VA, or would I have to reinstall my stock UP and DP? If so, would I get even better gains if I upgraded my headers? Any thoughts and suggestions about this would be helpful. I've been through the site and listened to a lot of different exhaust setups on this forum and want to make sure I make the right purchases if I'm going to be investing money in my car. Link to comment Share on other sites More sharing options...
robitrice Posted November 19, 2011 Share Posted November 19, 2011 exhaust section has your answers if searched....ill give a brief explanation. Cat back system vary....youtube is your friend for how it sounds. Any DP with a proper tune will let you pass emmissions when plugged into the diagnostics as longs the codes are off and no CEL. If you have a strict visual garage you wont pass with any mods Catback have minimal gains, stock is good for 300awhp. Headers not really worth it for a DD. Link to comment Share on other sites More sharing options...
wannalegacy Posted November 19, 2011 Author Share Posted November 19, 2011 Thanks for your advice on headers. I've spent hours searching the exhaust section and was looking for any additional input. Thanks for the explanation on passing emissions with a DP as well. Link to comment Share on other sites More sharing options...
wannalegacy Posted November 19, 2011 Author Share Posted November 19, 2011 Any additional suggestions would be greatly appreciated! I meant to put this thread in the exhaust section, but flubbed it. Link to comment Share on other sites More sharing options...
farberio Posted November 19, 2011 Share Posted November 19, 2011 The 08 does not have a cat in the up-pipe like the earlier LGT's, so, you can probably take that off your list and save some dough. Link to comment Share on other sites More sharing options...
wannalegacy Posted November 19, 2011 Author Share Posted November 19, 2011 Thanks for the info on the Up-Pipe. I knew it wasn't catted stock, just figure if I'm going to be replacing the DP and Exhaust I may want to take care of the rest while its in the shop. Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted November 20, 2011 Share Posted November 20, 2011 This is mine on my 05, Just posted it yesterday around 6pm. K&N Typhoon intake, GMS Crossover & UP pipe, & Invidia DP & V2 cat back. Exhaust clip, inside on out. Sorry for the dirty LGT. http://legacygt.com/forums/showthrea...25#post3639325 Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
wannalegacy Posted November 21, 2011 Author Share Posted November 21, 2011 Sounds great HD! I've seen a lot of negative things posted about changing out the stock intake on these cars. I'm assuming it's not a big deal as long as it is properly tuned for the new intake? Link to comment Share on other sites More sharing options...
Max Capacity Posted November 21, 2011 Share Posted November 21, 2011 IMO you don't gain much with a intake, get a good high flow air filter, I have a Perrin in the stock box. I'm catless up/dp in my 05, with stock exhaust, sounds pretty good, if you want more noise from the stock exhaust check out this. http://legacygt.com/forums/showthread.php/new-hog-zawst-system-sound-power-patented-washer-technology-35764.html Even with the exhaust the hp gain is about 10-12, is it worth the money. You can do the washer thing now and see how you like the sound. Or do what I did, I removed the mufflers from my 09 Spec B and put the muffler deletes I had made for the wagon years ago, on it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted November 21, 2011 Share Posted November 21, 2011 Sounds great HD! I've seen a lot of negative things posted about changing out the stock intake on these cars. I'm assuming it's not a big deal as long as it is properly tuned for the new intake? As long as you get tuned for your new air intake. You be ok. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted November 21, 2011 Share Posted November 21, 2011 ^^^ Yep, intake was upgrade do to FMIC hot pipe interference with stock air box. Cat back was upgraded because the stock one had about one more NY winter before it hit the ground. Cracks by the mid-pipe flange, hangers ready to give up the fight to hang on & muffler flanges was reduce to less than 1/2 of it's original thickness. When I went stage 2. I plan on reusing the OEM cat-back, but after I saw it was on it's last leg. I decided upgrade it. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
joedirtae09 Posted November 21, 2011 Share Posted November 21, 2011 . Are there any setups out there with good performance gains that pass emissions in VA, or would I have to reinstall my stock UP and DP? If so, would I get even better gains if I upgraded my headers? Im in VA also... its hit or miss on passing VA emisions and inspections. It all depends on what shop you go to. I have the catted COBB down pipe and one mechanic said he would pass me because it "looked" like I had a cat. I dont know what that meant since, I really do have one. I know some people that run a catless down pipe and have no problems. I wish I could run a catless down pipe but I dont want to risk it. Link to comment Share on other sites More sharing options...
brawline Posted November 21, 2011 Share Posted November 21, 2011 where in NOVA are you guys. You should come out to one of the meets in springfield at the hard times on monday nights. Im almost always there and my boy also come out most of the time with his legacy as well. Both of us have exhaust. if you want to hear in person. Link to comment Share on other sites More sharing options...
wannalegacy Posted November 21, 2011 Author Share Posted November 21, 2011 where in NOVA are you guys. You should come out to one of the meets in springfield at the hard times on monday nights. Im almost always there and my boy also come out most of the time with his legacy as well. Both of us have exhaust. if you want to hear in person. I was actually going to come out there tonight, but decided not too with the rain. I've been there before. A few of my buddies bring their SRT8 jeeps down that way so I was hanging with them. One thing I'd like to avoid is the snap pop after hard acceleration I've seen with some setups. I've been thinking of either the Catted Perrin or Cobb downpipe with either the SPT or Borla exhaust. I just see that a lot of people invest good money on their exhaust system only to be disappointed and I don't want to end up like that. Thanks for all the information/support! Link to comment Share on other sites More sharing options...
wannalegacy Posted November 22, 2011 Author Share Posted November 22, 2011 Is there a way to move this to the exhaust section of the forum? If so, please let me know so I or someone else can do so. Link to comment Share on other sites More sharing options...
brawline Posted November 22, 2011 Share Posted November 22, 2011 next monday you should stop by. when you say pop after hard excel do you mean as in backfire and or fireball? if so i would def go catted. i have gimmick exhaust and for the price i paid im extremly happy. Yes it is cheaper and fitment is a little off but not that bad. I believe my boy has borla on his legacy? Link to comment Share on other sites More sharing options...
wannalegacy Posted November 22, 2011 Author Share Posted November 22, 2011 Cool, I wanted to go catted anyways. I don't mind spending the extra money on expensive parts as long as they are good quality and get me where I want to be. Yeah, talking about the loud popping I've been hearing on a lot of the exhaust systems when they rev to redline and then back off the gas. Make sense? I would like to hear your buddies borla and see what you have done to your car. My car is basically a clean slate and I have some extra time on my hands. I'll most likely be there around 8PM on Monday. Link to comment Share on other sites More sharing options...
wannalegacy Posted November 29, 2011 Author Share Posted November 29, 2011 It was great seeing some nice and helpful Subaru owners there. Thanks for the advice and input everyone. Link to comment Share on other sites More sharing options...
wheelsbreakloose Posted December 2, 2011 Share Posted December 2, 2011 I've been out of the country a lot since getting my vehicle. Originally I was going to go with the Cobb stage 2 package which included the catted DP and exhaust system. Instead I purchased just the Accessport. The Cobb exhaust system excluding the DP is not available new anymore since it is out of production. I'm looking for a good exhaust system and catted DP and an UP for my car that will give me decent performance gains without having too much drone while driving on the highway. Are there any setups out there with good performance gains that pass emissions in VA, or would I have to reinstall my stock UP and DP? If so, would I get even better gains if I upgraded my headers? Any thoughts and suggestions about this would be helpful. I've been through the site and listened to a lot of different exhaust setups on this forum and want to make sure I make the right purchases if I'm going to be investing money in my car. So, how do you like the Access-port? Are the power gains very noticeable? Any problems with it? I just purchased an 08 Spec B myself, and I am considering getting one for mine.I was just curious about how it Co exist with the SI Drive? Its from my understanding that each mode, I, S, and S#, are all different maps that the Factory ECU already has programmed right? So, would it just store the new map from the AP to the S# mode?.. I'm a total noob as you can plainly see, and I don't know much about how the system works obviously. Just thought that you or somebody else reading your forum might have the answers that I'm looking for.. Link to comment Share on other sites More sharing options...
lookslikeanevo Posted December 3, 2011 Share Posted December 3, 2011 exhaust section has your answers if searched....ill give a brief explanation. Cat back system vary....youtube is your friend for how it sounds. Any DP with a proper tune will let you pass emmissions when plugged into the diagnostics as longs the codes are off and no CEL. If you have a strict visual garage you wont pass with any mods Catback have minimal gains, stock is good for 300awhp. Headers not really worth it for a DD. Header did great for me... http://legacygt.com/forums/showthread.php/socal-dyno-day-and-bbq-meet-saturday-november-11-sign-46311p6.html Current:MY05 SWP wagon - 253/290 UP, AEM CAI, Invidia Q300, tuned@yimisport OLD: MY06 GRP - 274/314 Link to comment Share on other sites More sharing options...
wannalegacy Posted December 5, 2011 Author Share Posted December 5, 2011 WBL, I like the accessport. I feel like it gave me a small gain while smoothing out the powerband a bit. The map you add to your AP will cover S#, S and I driving modes. You don't need a map for each mode. Link to comment Share on other sites More sharing options...
Heedz Posted December 5, 2011 Share Posted December 5, 2011 I have a gimmick with a added 12" resonator, my parents can sit in the car no problem. It opens up with load. btw im catless throwing flames at night full boost. Having the dual exhaust makes our cars a bit quieter than imprezas Link to comment Share on other sites More sharing options...
wheelsbreakloose Posted December 6, 2011 Share Posted December 6, 2011 WBL, I like the accessport. I feel like it gave me a small gain while smoothing out the powerband a bit. The map you add to your AP will cover S#, S and I driving modes. You don't need a map for each mode. Hmmm.. So nothing happens when you switch modes on the SI Drive after the AP is installed?.. Thats sorta disappointing to know. I was hoping that you could store different maps for each mode!! That would have been Kickass! But, all well. Its not gonna stop me from getting one! Thanks wannalegacy. Link to comment Share on other sites More sharing options...
farberio Posted December 7, 2011 Share Posted December 7, 2011 Something definitely happens when you switch between S#, S and I. It still functions like normal. Link to comment Share on other sites More sharing options...
wheelsbreakloose Posted December 8, 2011 Share Posted December 8, 2011 Something definitely happens when you switch between S#, S and I. It still functions like normal. Really?.. So how does that work then?.. Does it just UP every mode? Like, theI mode becomes the old S# mode?. The S mode becomes a S## mode?, and the S# mode becomes a S### mode?. Lol! Link to comment Share on other sites More sharing options...
