Go Back   Subaru Legacy Forums > The Marketplace > Member Private Sales > Member Classifieds - ARCHIVE
Reload this Page FS (MA): STI/LGT used built shortblock - SOLD
#1: 10-25-2011, 10:42 PM
 unclemat
Title: Twinscroll troll
Car: 05LGTx2[w],13CTS-V[w],06Elise,12TXBaja
Send a private message to unclemat Find all posts by unclemat
Used 2.5L built shortblock (04-06 STI / 05-06 LGT). Started life as a brand new stocker only ~12k miles ago. Built at 6k miles. Now at 6k miles since the build. Built by RAW. Contains:
CP forged 99.5 pistons 8.2:1 compression ratio (stock spec) w/Swaintech skirt coatings
Cosworth main and rod bearings
stock STI crank (balanced)
stock STI rods
newer 703 case castings
shimmed 10mm oil pump (new when built, has 6k miles)
Just pulled from the car and disassembled (see pics). Needs refresh. Eats oil at a rate about 1qt / 700-800 miles since day 1. Not sure if caused by improper break-in or improper build. Tune is unlikely the culprit, tuned by reputable Chris of EFI Logics (ran sub-300 whp tune using a VF36 twinscroll setup). Not sure if it takes rehone and new rings to fix it or if it may need bore. Cylinder walls are clean w/cross-hatch visible. The only other issue is that two of the water pump bolts snapped during water pump removal. Need to be drilled out and holes heli-coiled.
Otherwise no problerms whatsover. No piston slap, excessive noises or knocking. Perfect oil pressure. Actually it ran smoothly, quietly (hardly louder than stocker) and reliably. I never let it go down on oil, was watching it like a hawk. I just didn't want to drive an oil burning car, which is not good in the long run. Given my power level I just went with a stock block.
SOLD Asking $1000 OBO. Would rather not ship, but could be arranged.
Check my for sale threads!
unclemat
Find More Posts by unclemat
#2: 10-26-2011, 07:49 AM
 unclemat
morning bump
unclemat
#3: 10-27-2011, 07:25 AM
 unclemat
bump.
unclemat
#4: 10-28-2011, 10:52 AM
 SBT
SBT's Avatar
Title: Site Majordomo
Rank: Admin
Car: SWP 05 LGTLW 6MT waiting on an S402
Send a private message to SBT Find all posts by SBT
Better pic of the snapped water pump bolt area available?
- Pro amore Dei et patriam et populum -
SBT
Find More Posts by SBT
#5: 10-28-2011, 07:38 PM
 DreDre
DreDre's Avatar
Car: LGT Limited
Send a private message to DreDre Find all posts by DreDre
i have a 2007 LGT and was wondering if this would fit my car
DreDre
Find More Posts by DreDre
#6: 10-29-2011, 09:52 AM
 unclemat
Not handy, will try to take one later.
It would. The pistons in 07-09 SB is slightly different. 05-06 block combined with 07+ heads (D25) would yield slightly higher compression ratio of ~8.8:1 vs 8.4:1 you have.
unclemat
#7: 10-29-2011, 02:03 PM
 Mortal2None
Mortal2None's Avatar
Car: 06 GT Wagon / 70 Mach 1 Mustang
Send a private message to Mortal2None Find all posts by Mortal2None
The waterflow on the 07 engine is different too (Reverse I think) so as long as you use the 07 pump you might be ok. Need to confirm it but I believe that was changed in 07
Mortal2None
Find More Posts by Mortal2None
#8: 10-29-2011, 02:52 PM
 DreDre
DreDre's Avatar
Car: LGT Limited
Alright thanks guys, i guess i gotta keep looking...
DreDre
#9: 11-01-2011, 01:23 PM
 unclemat
sold.
unclemat
#10: 11-02-2011, 06:06 PM
 Mortal2None
Congrats! Good deal for someone out there.
Mortal2None
#11: 11-02-2011, 09:14 PM
 SBT
SBT's Avatar
Rank: Admin
Moved off-forum.
SBT
