#1:
04-25-2007, 03:13 PM
how bad if i over fill engine oil ?
Car: 05.LGT 5speed
i just realize i over filled oil. much higher than the high mark on the stick. is it okay to drive like that ?
#2:
04-25-2007, 03:16 PM
Title: Too Big to Fail
Car: 05 Legacy GT/98 BMW 540 w/Chevy Power
What do you mean by "much higher"
#3:
04-25-2007, 03:37 PM
Title: Trunk Monkey Chief
1 full extra quart would probly be the absolute maximum you could overfill and not see anything really bad happen. even then, I would still try to get some out.
Worst case you overfill to the point that the oil hampers movement of the internals and the engine locks up...permanently
(Updated 2/7/13) 2005 Outback FMT Spec Yaris
#4:
04-25-2007, 04:45 PM
Car: Totaled 05 BSM LGT TDC Stg2+
A little excess...will just burn off
A lot of excess...mwiener2
#5:
04-25-2007, 09:38 PM
Car: 05.LGT 5speed
i put 5 quats on last oil change about 5 days ago. is that okay ?
#6:
04-25-2007, 09:40 PM
Title: Contributing V.P.
Car: 05 5EAT(IPT) Wagon. 18G 312HP / 293TQ
Hope you mean 5 quarts.
#7:
04-25-2007, 09:41 PM
Title: nice phone
Car: back in the wagon
check the level. once its above the full mark it can easily be way over full. i feal i just answered this question 5 seconds ago.
#8:
04-25-2007, 09:55 PM
Car: 05.LGT 5speed
yep! 5 quarts. is that too much ?
#9:
04-26-2007, 07:22 AM
That's how much I always fill. Half a quart shouldn't hurt anything, but you might smell it burning off for a while after the oil change...
Zac
#10:
04-26-2007, 07:50 AM
Title: Banned
Car: 06 Spec.B
Zac
As I understand it, the main danger with moderate overfilling oil is that cavatation can occur at the sump from aeration by the crank shaft turning the oil into froth wherein it losses its lubribating and cooling ability.
The extra oil won't "burn off".
#11:
04-26-2007, 07:53 AM
Title: Get to teh CHOPPA!!223@4%
Car: 05 Legacy GT Stage II+
a little bit of extra oil will burn off...thats why you have a blowby. i just wouldnt put in more than 1/2 qt to a qt more than recommended. you can flood seals and cause them to leak.
aeration can most definately happen, but not with 1/2 a qt too much. thats not enough to allow the crankshaft to hit the oil in the sump
you guys are so paranoid sometimes
#12:
04-26-2007, 07:55 AM
It will not "burn off". If you have too much oil to the point where it is to the level of the crankshaft you can (and likely will) destroy the rod bearings and main bearings - but you have to really overfill it to get to that point.
#13:
04-26-2007, 07:57 AM
Title: Pope Boxer I
Car: E90
This is where the fumoto valve comes in handy. Just let the car piss a little out.
OBAMA......One Big Ass Mistake America!
#14:
04-26-2007, 08:03 AM
Title: Banned
Car: 06 Spec.B
^ A pcv valve is for gases not liquids. Are you saying that excess oil will be drawn through the pcv valve and into the intake manifold?
#15:
04-26-2007, 08:08 AM
Title: Guest
Posts: n/a
Yes, pcv is a vacuum valve.
Why would you put more oil in than it says in the book? Do you prime the filter when you change it too? Thats always a good idea. Always fill it low (but visible on the stick) then check it, add a little, go for a drive, check for leaks, check oil level again and top it off. Cant go wrong.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
