Reload this Page fog lights 2010 legacy ? nesscary
Page 1 of 4 1 23 > Last »
#1: 12-07-2009, 09:35 AM
 pegger
Car: 2010 legacy 2.5i limited
Send a private message to pegger Find all posts by pegger Reply With Quote
I am looking at buying a 2010 legacy limited the car the dealer has coming in does not have fog lights do you feel they are necessary or can you live without ?
pegger
Find More Posts by pegger
#2: 12-07-2009, 09:40 AM
 Rutchard
Rutchard's Avatar
Send a private message to Rutchard Find all posts by Rutchard Reply With Quote
Live without or install them later, it shouldn't be a hard install.
Rutchard
Find More Posts by Rutchard
#3: 12-07-2009, 09:40 AM
 Ride
Ride's Avatar
Car: '10 LGT Ltd Graphite Gray
Send a private message to Ride Find all posts by Ride Reply With Quote
You can live without, like most things, in my opinion. But these really make a difference when driving, they are very bright and light up the road (more so than other fogs I've had). In a nutshell, I find them more practical than usual. . . .
Ride
Find More Posts by Ride
#4: 12-07-2009, 10:28 AM
 home38er
Car: 2010 LGT
Send a private message to home38er Find all posts by home38er Reply With Quote
I'm about to spend $200 on the Fog Lights for my LGT. I've had a few nights where I felt that the extra low level light would make for a safer back road drive. They are super easy to install, so I hear. If your ok with doing your own install work(car's pre-wired) then dont pay the extra money or list price for the parts for a deal install.
Pegger, Good luck with the purchase
home38er
Find More Posts by home38er
#5: 12-07-2009, 10:44 AM
 naimouasta
naimouasta's Avatar
Car: 2008 QSM Legacy 2.5i SE
Send a private message to naimouasta Find all posts by naimouasta Reply With Quote
i suggest you buy them afterwards. and i don't think they make a difference, atleast on my 08. its more bling than function.
naimouasta
Find More Posts by naimouasta
#6: 12-07-2009, 11:12 AM
 BobGee
Title: Banned
Car: 2010 Legacy 3.6r Limited /nav
Find all posts by BobGee Reply With Quote
I'm getting them just for the look.
The install looks incredibly easy.
BobGee
Find More Posts by BobGee
#7: 12-07-2009, 12:49 PM
 schmoli
Car: 2010 Legacy 2.5i Premium
Send a private message to schmoli Find all posts by schmoli Reply With Quote
I had my dealer get them and put them in, just negotiate it when you buy the car (I also negotiated aftermarket leather wrap interior).
schmoli
Find More Posts by schmoli
#8: 12-07-2009, 01:01 PM
 iambuddylee
iambuddylee's Avatar
Car: 2010 LGT
Send a private message to iambuddylee Find all posts by iambuddylee Reply With Quote
for those of you doing the install, how do you turn them on? Are they wired to your lights? In the manual it looks like it shows another knob next to your main lights knob on the turn signal?
iambuddylee
Find More Posts by iambuddylee
#9: 12-07-2009, 02:10 PM
 naimouasta
naimouasta's Avatar
yea! for my 08, you get the fog lights, new switch stalk, and relay.
naimouasta
#10: 12-07-2009, 02:15 PM
 Hybr1dz
Car: 2010 Legacy 2.5i Premium CVT
Send a private message to Hybr1dz Find all posts by Hybr1dz Reply With Quote
Part of the installation is to replace the mirror adjustment control with a new one that includes the fog light button. It's not on your turn signal stalk in the 2010 model.
For the most part, the installation is easy. All the connectors are there, just hook it up. You also insert a new relay into your fusebox. Removing the old mirror adjustment control wasn't too bad. Use the new control that came with the kit as a reference to where the 4 clips are on the old one. Use a flat-head screwdriver to depress each clip from the back of the control while gently pushing from the front to release it from the control panel trim.
The tough part is getting the plastic tabs on the fog lamp housing to slide into the grooves of the bumper. At least it was tough for me. I ended up breaking the tabs on both my lamps. Be careful!
One thing I realized after I broke the tabs is that when you try to install the lamp right side up (so that the lamp connector is connected from the bottom of the lamp), there's a piece of plastic behind the upper-right tab (when you're facing the lamp) that I think is preventing the lamp from fitting nicely when I tried to install them. This upper-right tab is where you bolt down the lamp on the righthand side of your car. It would be the upper-left tab on the other side. Turn the lamp upside down so that the lamp connector is connected from the top and I think you will get a better fit. There is no extra plastic behind the upper tabs when the lamp is upside down.
Definitely let me know if you got it to fit right side up!
I'm checking with the merchant to see what can be done about my broken plastic tabs. Hopefully I can get replacements at minimum charge.
Edit: I realized I was talking about the right-hand lamp. It's the opposite for the left-hand lamp. So when I refer to the upper-right/upper-left tabs on the lamp, it's as if you're looking right into lamp as you are installing them. When I say "lamp on the righthand side of the car", it's as if you're driving. Sorry for the confusion!
Hybr1dz
Find More Posts by Hybr1dz
#11: 12-07-2009, 02:17 PM
 Ride
Ride's Avatar
Yes, it's a control button on the left side of the steering wheel, next to mirror adjustment. They work with the Auto-On headlights, so daylight only DRL's on, when light sensor enables headlights, it get both lights and fogs (if you have them on).
Ride
#12: 12-07-2009, 02:31 PM
 legacy360
legacy360's Avatar
Car: 2005 LGT Ltd 5EAT Wagon
Send a private message to legacy360 Find all posts by legacy360 Reply With Quote
Here's a picture of the switch placement. It's the blank panel to the right of the mirror adjustment
legacy360
Find More Posts by legacy360
#13: 12-07-2009, 02:33 PM
 dj0mla
dj0mla's Avatar
Car: 2011 Subaru Legacy Premium
Send a private message to dj0mla Find all posts by dj0mla Reply With Quote
Check this website out. Scroll all the way down to 2010 and you will see Subaru Legacy Fog Lights install. Very simple job probably 30 minutes tops.
dj0mla
Find More Posts by dj0mla
#14: 12-07-2009, 02:33 PM
 dj0mla
dj0mla's Avatar
http://techinfo.subaru.com/html/ixSe...d=&free_pub=13
dj0mla
#15: 12-07-2009, 02:41 PM
 iambuddylee
Car: 2010 LGT
good info, thanks all for sharing. I'm not sure why I thought in the manual it said that the fog switch was on the turn signal. I must have misread that.
iambuddylee
Similar Threads
Wagon rear fog lamp install unclemat Walkthroughs :: Performance Modifications 21 03-18-2011 08:38 PM
NO DRLs, Headlights, and Fog Lights. autoinsider Warranty Issues & Problems 16 07-12-2008 08:47 PM
07 Legacy, Prewired for Fog Lights?? dougger Exterior/Aesthetic 3 06-27-2008 07:32 AM
Spt Intake and Fog Lights jamato998 Member Classifieds - ARCHIVE 5 06-27-2008 06:03 AM
fog lights...HELP! cklegacy2006 Pacific Northwest 6 12-14-2007 10:10 AM
