Go Back   Subaru Legacy Forums > Technical Forums > Detailing, Maintenance, and Long-term care
Reload this Page Not pleased with '07 SpecB 6MT drain plug...
#1: 10-01-2012, 10:42 PM
 KU_MechE
Send a private message to KU_MechE Find all posts by KU_MechE Reply With Quote
So, the '07 6MT has two drain plugs for the tranny/front diff. Using a nice Snap-On wrench, I rounded off the 14mm hex head of the rear plug. Had to go buy a Craftsman Bolt-Out set, which worked great.
Since a replacement plug was $6.00 at the dealer and would possibly give me the same problems at the next fluid change, I bought a new 16mm plug from Lowes. This new plug uses a 19mm hex and, when properly torqued, shouldn't be a pain to remove. See the difference below:
KU_MechE
Find More Posts by KU_MechE
#2: 10-03-2012, 08:29 PM
 apexi
Car: '09 Legacy 2.5i SE 5MT
Send a private message to apexi Find all posts by apexi Reply With Quote
Were you using a 12pt or 6pt wrench?
apexi
Find More Posts by apexi
#3: 10-05-2012, 07:30 PM
 KU_MechE
12pt, but with a pretty good fit. Might have to get a set of 6 points now
KU_MechE
#4: 10-06-2012, 10:05 AM
 pbts
Send a private message to pbts Find all posts by pbts Reply With Quote
Just use the fumoto valve. I've had it on two of my cars now and its pretty convenient:
http://www.quickoildrainvalve.com/
pbts
Find More Posts by pbts
#5: 10-08-2012, 12:44 PM
 Subyroo651
Subyroo651's Avatar
Car: 2013 Outback 2.5Ltd
Send a private message to Subyroo651 Find all posts by Subyroo651 Reply With Quote
I would never put a Fumoto on a trans drain. Durr
Subyroo651
Find More Posts by Subyroo651
#6: 10-08-2012, 05:46 PM
 Dbl_D718
Dbl_D718's Avatar
Car: 2007 spec.B
Send a private message to Dbl_D718 Find all posts by Dbl_D718 Reply With Quote
Kinda embarrassed to link to my noob thread, but I had some issues with mine too...
http://legacygt.com/forums/showthrea...se-189647.html
Long story short: bolt extractors wouldn't get mine out, had to take it to a shop to have it drilled.
MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII
Dbl_D718
Find More Posts by Dbl_D718
#7: 10-09-2012, 08:48 PM
 KU_MechE
The glory:
KU_MechE
