Reload this Page PCV valve
#1: 10-13-2011, 07:34 AM
PCV valve
 m_dogg
Car: 2009 2.5i Special Edition
Send a private message to m_dogg Find all posts by m_dogg Reply With Quote
I'm almost at 30K miles with my NA 2.5 so it's time for some maintenance. Changed plugs, air filter, cleaned MAF, Mobil1 synthetic - do I have to replace the PCV valve? I'm new to this platform and to be honest, I don't know where to look for it...Also, anything else I should check/replace?
TIA!
m_dogg
Find More Posts by m_dogg
#2: 10-13-2011, 07:43 AM
 Max Capacity
Max Capacity's Avatar
Car: 05GT Wagon 5MT stg2, 09 specB stg2
welcome to the forum.
Sorry to hear your using Mobil 1. But then, your NA so its not as important.
Sorry but as you read more your understand about the oil thing.
I'm at 144,000 miles, have never changed the PCV.
We change the fluid in our rear diff and manual trannys every 30,000 too.
254,000miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. CHECK your oil, these cars use it.
Engine Build - Click Here
Max Capacity
#3: 10-13-2011, 10:39 AM
 RomanC
Car: 05 LGT 5MT LTD
Send a private message to RomanC Find all posts by RomanC Reply With Quote
Maybe you should as you loose oil on almost daily basis judging from your posts
My PCV at 95K was completely stuck so that the oil was just streaming into the intake. After the PCV got replaced the oil consumption subsided dramatically.
RomanC
Find More Posts by RomanC
#4: 10-13-2011, 10:42 AM
 m_dogg
What would be an oil of choice? I used Amsoil on my Regal but it had shit load of mods.
Good to know, as far as trans fluid - pan drop and new filter or flush?
Diff fluid - rear only or R & F?
Thanks!
m_dogg
#5: 10-13-2011, 11:03 AM
 m_dogg
So I just found this (sorry, car did not come with the manual...bastards)
http://www.cars101.com/subaru/subaru_maintenance.html
Diff & trans fluid = (I) inspect not (R) replace - I'm starting to get confused hehe. Looks like brake fluid needs to be changed at 30K...
m_dogg
#6: 10-13-2011, 11:08 AM
 Max Capacity
I haven't changed the brake fluid in my 05 yet.
Automatics are different, I don't have one so I do follow them that closely. You do have a front diff in front of your tanny. So you should have two dip sticks, I think one on each side of the tranny area.
RomanC
My 05 also has a A/O seperator that was installed by a shop. I believe they removed the PCV. I believe my problem has to do more with old abused rings and cylinder walls. From years ago.
Oh yea, and now it's pushing 21psi. So I can't complain to much.
Max Capacity
#7: 10-13-2011, 11:16 AM
 m_dogg
Ahhh...it all makes sense now, trans dipstick is on the right, then i looked closely and was like WTF is that other dipstick on the left for
m_dogg
#8: 10-13-2011, 11:19 AM
 Max Capacity
I also think they take different fluids too. There was this same type question a ago or so.
Max Capacity
#9: 10-13-2011, 11:49 AM
 AZP Installs
AZP Installs's Avatar
Title: Tri-State Subaru Experts
Car: 94LegTurb->92SVX->05 LGT->11 STi->14 BRZ
Send a private message to AZP Installs Find all posts by AZP Installs Reply With Quote
For the auto trans the easiest thing to do is a drain and fill. No dropping of the pan or anything like that. Just make sure that you don't over fill the transmission. We normally only replace what comes out and then triple check the level once it has been driven. However there should also be a trans filter on the side of the trans or behind the battery (dependent on build date). There is a slight chance you don't have a filter at all (again build date specific). The diffs get heavy gear fluid (75w90) and the trans gets auto fluid.
The PCV you might as well inspect so you know if it is in good shape. At 110K mine was considered "working" but sounded dirty and for the $15 I just replaced it. Brakes will need a flush as well.
Amsoil is a good choice for this car as well. Mobil 1 has been a topic of some discussion. Some use it with no issue while others find it is the devil in a bottle. The NA motor can stretch out its oil changes with Amsoil as long as you use their filters too.
** Forgot drain and fill coolant too
-Jake
AIM: AZP Installs | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Dealer
AZP Installs
Find More Posts by AZP Installs
#10: 10-13-2011, 11:55 AM
 mustangendsley
mustangendsley's Avatar
Car: 2005 2.5 GT Limited, Stage 2
Send a private message to mustangendsley Find all posts by mustangendsley Reply With Quote
90k and i have the stock one.
mustangendsley
Find More Posts by mustangendsley
#11: 10-13-2011, 05:56 PM
 quick4dr
quick4dr's Avatar
Car: 1.5xtr 4:1ELH, EWG,FMIC,cdVB, EFI
Send a private message to quick4dr Find all posts by quick4dr Reply With Quote
Bought my car at 60kish, at around 68k i did a pcv and grimmspeed AOS. At that time my tmic was very clean just a light sheen of oil but nothing coated. Now at 83100 with new IPR tmic at 70k, and its dry.
My Grand Prix GTP use to chew up its pcv valve every 8k, lol never burned oil just 13lbs of m90 boost.
its a cheap easy to do part, I say if in doubt swap it out.
quick4dr
Find More Posts by quick4dr
#12: 10-13-2011, 08:44 PM
 m_dogg
^Ahh fellow M90 that joined the dark side I see
Gen III or V blower?
m_dogg
