Reload this Page audio install help
#1: 09-05-2011, 05:34 PM
audio install help
 CHUCKmfnNORRIS
CHUCKmfnNORRIS's Avatar
Car: 2011 2.5i 6m/t satin pearl white
Send a private message to CHUCKmfnNORRIS Find all posts by CHUCKmfnNORRIS Reply With Quote
i am adding my sub and amp to my car and using the factory stereo unit, i am going to use a line output converter. i just need to know who has installed one and where they tapped into the factory speaker wires.
CHUCKmfnNORRIS
Find More Posts by CHUCKmfnNORRIS
#2: 09-05-2011, 09:31 PM
 20LEGGY10
Car: 2010 LGT Stage 1
Send a private message to 20LEGGY10 Find all posts by 20LEGGY10 Reply With Quote
I installed a JL 10w3 with an 1600 watt MA Audio amp in my car with the harmon kardon speakers. I tapped my line output into the speaker wires attached to the stock sub woofer, and i ran the radio wire to the cigar lighter fuse in the fuse box under the steering wheel. I also mounted the line output to one of the trunk beams next to the stock sub.
20LEGGY10
Find More Posts by 20LEGGY10
#3: 09-06-2011, 10:09 AM
 CHUCKmfnNORRIS
i dont have the harmon kardon system. i ordered at converter with a remote turn on wire. i really need to know what wires to tap into on the back of the stock unit.
CHUCKmfnNORRIS
#4: 09-12-2011, 12:06 AM
 SVXdc
SVXdc's Avatar
Car: 1996 SVX L AWD
Send a private message to SVXdc Find all posts by SVXdc Reply With Quote
This Subaru 20-pin pin-out table should help (although it doesn't show Legacy/Outback factory colors). Be sure to see the notes towards the bottom for options to avoid splicing factory wires.
If you really want to tap into your factory wires, search for "vacation pix".
SVXdc
Visit SVXdc's homepage!
Find More Posts by SVXdc
#5: 09-13-2011, 01:08 PM
 CHUCKmfnNORRIS
from what i am told is that the wire harness for the sub is already there, what wires did you splice onto?
CHUCKmfnNORRIS
#6: 09-17-2011, 01:44 PM
 SVXdc
SVXdc's Avatar
Car: 1996 SVX L AWD
In cars without the factory harman/kardon or McIntosh systems, the harness for the OEM underseat sub is not pre-installed. The harness will only be there if the powered subwoofer accessory kit was added at some point (by the port, dealer, or previous owner).
Sedans with the h/k system have a sub on the deck behind the rear seats. The wires run to the h/k amp (under the passenger seat).
For your non-h/k Legacy, the best/easiest way is to access the speaker outputs behind the HU. I have harnesses that make that much easier. See link I posted above.
SVXdc
