Go Back   Subaru Legacy Forums > Model Specific Forums > First Generation Legacy (1989 - 1993)
Reload this Page 92 ls pinging really bad!!!
#1: 05-04-2013, 10:46 AM
 bcmaxx
Car: 91 legacy sdn 2.2, modified cherocar
Send a private message to bcmaxx Find all posts by bcmaxx Reply With Quote
our 92 legacy started pinging terribly!!! under load the worst, sounds like a piston about to shoot out, under light accell its fine, and when its cold, same its perfect. knock sensor? theres no cel light or anything, has had new plugs, fuel wires, coil maf, and coolant temp sensors all within the last 10,000kms
bcmaxx
Find More Posts by bcmaxx
#2: 05-04-2013, 03:12 PM
 Tangointhenight
Tangointhenight's Avatar
Car: 2006 Outback XT
Send a private message to Tangointhenight Find all posts by Tangointhenight Reply With Quote
What spark plugs do you have? If they're Bosch or domestic, replace them with NGK or Denso.
You can also try fuel system cleaner or Seafoam. Also, have you tried higher octane, and if you have, what happens then? Head gasket problems can also cause pinging
Tangointhenight
Find More Posts by Tangointhenight
#3: 05-04-2013, 07:55 PM
 snederhiser
Send a private message to snederhiser Find all posts by snederhiser Reply With Quote
Hello;
Knock sensor would be the likely suspect. Also check timing, and the cam/crankshaft sensors. Also check the ecu for stored codes. You may not have a hard fault yet to set off the light but enough for a stored code! Steven.
snederhiser
Find More Posts by snederhiser
#4: 05-30-2013, 12:36 PM
 bcmaxx
ngk plugs, number 22401aa310, knock sensor 22060aa031, new ngk wires, new coil 22433aa370, still pinging pretty good under load. no mechanical engine noise whatsoever. very frustrating!! seems to lack power too, fuel consumption also seems high, could a crappy 02 sensor cause this? It has a bwd direct plug in sensor.no codes either
bcmaxx
#5: 05-30-2013, 12:39 PM
 bcmaxx
i have seafoamed it, ran it in tank, and tried octane boost with 91 octane, still pings. no sign of headgasket issue, no trace of exhaust oil in coolant, no external leaks.
bcmaxx
#6: 05-30-2013, 06:28 PM
 mnstrmech
mnstrmech's Avatar
Car: 1993 legacy wagon
Send a private message to mnstrmech Find all posts by mnstrmech Reply With Quote
weak fuel pump. try checking fuel pressure.
mnstrmech
Find More Posts by mnstrmech
#7: 05-31-2013, 03:06 PM
 bcmaxx
alright, will do, dont know why I forget the basics sometimes... I noticed the fuel pump isnt under the seat? drop tank to replace?
bcmaxx
#8: 05-31-2013, 06:04 PM
 snederhiser
Hello;
Pull up the trunk mat and look for a oval cover behind the seat on the right hand side. You can pull the return line and see if there is fuel returning to the tank if you don't have a pressure gauge. I am talking about the one under the hood. Check your cam sensor and knock sensor. Do yourself a favour and go to the only sticky we have for the first generation. Click on notes & tips, then tech articles, look for the FSM (92 manual). Download this, Steven.
snederhiser
#9: 06-05-2013, 04:49 PM
 bcmaxx
pump good, pressure and flow good, trying oem front oxygen sensor tonight, and hopefully some injectors in the next couple days. Also thinking my bigger tires arent helping matters especially in fuel dept, maybe drop back to a 16" 205/55/16
bcmaxx
#10: 06-05-2013, 10:40 PM
 monkeyposeur
monkeyposeur's Avatar
Car: 95 BK, 93 SS!
Send a private message to monkeyposeur Find all posts by monkeyposeur Reply With Quote
Fuel pump replacement DIY: http://legacygt.com/forums/showthrea...iy-198427.html
monkeyposeur
Find More Posts by monkeyposeur
#11: 06-07-2013, 10:21 PM
 snederhiser
Hello;
Pull the front covers and check the timing, could have skipped a tooth somewhere. Steven.
snederhiser
#12: 06-11-2013, 03:09 PM
 bcmaxx
next on my list, it had a new oil pump very recently
bcmaxx
#13: 06-13-2013, 06:52 AM
 05LGTLtd
05LGTLtd's Avatar
Title: Contributing V.P.
Car: 2005 LGT Limited wagon, 5 speed
Send a private message to 05LGTLtd Find all posts by 05LGTLtd Reply With Quote
Exhaust flow good?
All I need now is a hill holder and a center passing light...
05LGTLtd
Find More Posts by 05LGTLtd
#14: 06-13-2013, 10:54 AM
 jp233
Car: on 2nd '06 LGT.... DD= '94 AWD N/A wag
Send a private message to jp233 Find all posts by jp233 Reply With Quote
check for stored codes, for sure.
You can test the injectors at least to hear them click, but that will not tell you about real flow. I've had WitchHunter clean/flow test several sets of injectors and you'd be amazed how well a car will run with crappy injectors, though.
Crank and cam sensors, definitely check.
Timing, yep that too. Count your teeth and make sure those cams are lined up right!
jp233
Find More Posts by jp233
