Go Back   Subaru Legacy Forums > Technical Forums > Exterior/Aesthetic
Reload this Page Hella Supertone Install Walk Through w/ pics
Page 1 of 17 1 2311 > Last »
#1: 11-10-2005, 01:26 AM
 j.reed
j.reed's Avatar
Car: '05 LGT Ltd. Obsidian Black 5MT 13.3@102
Send a private message to j.reed Find all posts by j.reed Reply With Quote
1) Remove intake, grill, unplug factory horns
Here are your stock horns (located in front of the passanger side front tire, below the air intake infront of the resonator), on the right is the unit that makes the chip sounds for the remote entry. I chose to unplug the horns and use some metal pieces to slide into the plug and connect to the relay via some wire. You can also leave them plugged in and splice into the wire.
2) mount horns
I removed this little holder for the hood release cable to mount the drivers side horn, the passangers side should be empty (this hole is for right hand drive cars). I then places some misc bolts and nuts and washers in their place to mount the horns. No contact with the grill or radiator happens when the mounting bracket touches the cross beam flush.
3) mount relay
No pic here, but down in the well where the horns are there is a ground nearby, towards the engine. I removed it, used the screw to mount the relay, and connected the relay's ground directly to it.
4) run cables
Follow this diagram and run the cables to the wheel well where we placed the relay. I ran cable over to the battery and the horns via the cross beam in front of the radiator. I ran in inside the beam alongside the hood release cable.
Finished product:
P.S. Don't steal my car. I didn't have time to blur my plates.
The Following User Says Thank You to j.reed For This Useful Post:
mkeGT (09-03-2011)
j.reed
Visit j.reed's homepage!
Find More Posts by j.reed
#2: 11-10-2005, 04:45 AM
*Jedimaster*
Title: Guest
Posts: n/a
Is it OK to post replies?
*Jedimaster*
#3: 11-10-2005, 08:48 AM
 SVXWRX
SVXWRX's Avatar
Car: 05 LGT UnLtd 5EAT / 05 FXT Premium
Send a private message to SVXWRX Find all posts by SVXWRX Reply With Quote
here is a simplified diagram to assist your Legacy-specific pics.
SVXWRX
Find More Posts by SVXWRX
#4: 05-16-2006, 01:38 PM
 suds2250
suds2250's Avatar
Car: 05 5MT wagon
Send a private message to suds2250 Find all posts by suds2250 Reply With Quote
I just recieved my Supertones and will be wiring them up. Could someone tell me if the diagram above retain the stock horns? I would like to use all of them if I could.
suds2250
Find More Posts by suds2250
#5: 05-16-2006, 03:26 PM
 rony
rony's Avatar
Title: Where's my brain?
Car: 05 Subaru Legacy GT Limited MT Protuned
Send a private message to rony Find all posts by rony Reply With Quote
With the use of a relay, like the above diagram, you could retain the factory horns. Don't know why you would, if you don't want to remove them, just simply disconnect them.
My Car vBGarage
rony
Visit rony's homepage!
Find More Posts by rony
#6: 08-09-2006, 07:36 AM
 CasopoliS
CasopoliS's Avatar
Title: Vendor I
Car: Yes.
Send a private message to CasopoliS Find all posts by CasopoliS Reply With Quote
BUMP - did this ever get fully written?
also... why is the relay needed? Can't I just tap into the 12v wire going to the stock horn?
Usually a relay is to use a low voltage / low current signal wire to mechanically switch 12vdc to something. But the stock horn has to get 12v somewhere right?
Let me know your thoughts. I will post my walkthrough when I am done.
CasopoliS
Visit CasopoliS's homepage!
Find More Posts by CasopoliS
#7: 08-09-2006, 07:56 AM
 PGT
Title: Yeah, that PGT
Car: '12 Rubicon MW3 & '12 300C SRT8
Send a private message to PGT Find all posts by PGT Reply With Quote
I used them on the stock wiring for a year and no issues. A relay is helpful (more output possibly), but not necessary for just a pair. Running four...you will need one.
PGT
Find More Posts by PGT
#8: 08-09-2006, 08:28 AM
 CasopoliS
CasopoliS's Avatar
Title: Vendor I
Car: Yes.
ok thanks. Well I am running 8 supertones. 4 in the grill, 1 in each front fender, and 2 behind the rear bumper WRX style ...kidding
So it will be like playing old school twisted metal with the supersonic special weapon that makes all other cars around you bounce. damn I loved twisted metal... maybe I should pull the 'ol playstation out.
CasopoliS
#9: 08-09-2006, 08:30 AM
 PGT
dude....memories. Twisted Metal2 was my favorite...I always played the pink caddy with 'wraith' weapon
PGT
#10: 08-09-2006, 11:57 AM
 CasopoliS
CasopoliS's Avatar
Title: Vendor I
Car: Yes.
remember that clown car that made that creepy laugh... you could tell it was around the corner because you could hear the laugh
a bit off topic but who cares. TM2 was the shiz.
CasopoliS
#11: 08-11-2006, 11:31 AM
 suds2250
suds2250's Avatar
Car: 05 5MT wagon
Here are a couple pics of my supertones. I used the hella relay and the diagram in post #3 to wire everything up. The relay is mounted in the left corner of the grille opening (you can see the blue wire connectors) using an existing threaded hole. The horns themselves I mounted using an existing hole in the cross support with a bolt and lock nut.
Jon
ID:	22692   Click image for larger version
335HP/360Tq VF-22/1820 clone with Meth
The Following User Says Thank You to suds2250 For This Useful Post:
mkeGT (09-03-2011)
suds2250
#12: 08-11-2006, 11:44 AM
 CasopoliS
CasopoliS's Avatar
Title: Vendor I
Car: Yes.
thanks for the pics.
holy crap wash your car dude!!!!
CasopoliS
#13: 08-11-2006, 11:52 AM
 suds2250
suds2250's Avatar
Car: 05 5MT wagon
LMAO! That's tomorrow's project.
suds2250
#14: 08-11-2006, 12:54 PM
 jim1969
jim1969's Avatar
Car: 2005 LGT
Send a private message to jim1969 Find all posts by jim1969 Reply With Quote
did you leave the stock horns in?
jim1969
Find More Posts by jim1969
#15: 08-12-2006, 07:52 PM
 suds2250
suds2250's Avatar
Car: 05 5MT wagon
Yes, I left the stock horns in. I t-tapped into the stock horn as shown in the diagram above, so the supertones and the stocks all are working, although you can't hear the stockers!
suds2250
Similar Threads
LGT Wagon Pinks Install w/ Pics hal9e3 Suspension/Brakes 39 04-11-2012 07:23 PM
Omori color boost guage install with pics JayEmVee Interior/Audio 3 05-03-2007 12:34 PM
Some Pics of cubby gauge install... msavino Interior/Audio 20 10-02-2005 07:29 PM
Pics of Uppipe & Downpipe Install Ferg Legacy Photos (2005-2009) 32 02-24-2005 07:49 PM
Pics of my 8500 X50 install mwiener2 Interior/Audio 6 01-08-2005 02:37 PM
