this as a project as it needs , and it needs the head gasket doing a 02 sensor which i should be able to supply if i get it in time. also had a new air mass sensor,full cam belt change and tensioners etc all done with genuine subaru parts API subaru,had all new vac lines and vac control box, earthing kit, strut brace,basic all under bonnet either was new or replaced all within last 20,000 mls. have loads of paperwork and service. this car has had a remap from B.R.Developments who is well known. double din dvd player. the car being a RSK comes with a full upgraded sound system is very loud. its just had a new gearbox fitted with steering wheel gear change,all working as it should. also a new pair of matching turbos. theres lots more. Also has a hard to find RSK number plate
looking for something to the value of £1800
im located in BURY LANCASHIRE UK BL9 +447938108279
