Go Back   Subaru Legacy Forums > Walkthroughs > Walkthroughs :: Performance Modifications
Reload this Page a Front Sway Bar Install. W/ pics.
#1: 11-13-2012, 08:46 PM
 chimaira4deth
chimaira4deth's Avatar
Car: 05 Legacy Limited GT - Stage III
Send a private message to chimaira4deth Find all posts by chimaira4deth Reply With Quote
So after searching and searching, i decided to just go ahead and start my front sway bar install WITHOUT a Walkthrough from the forum.
I researched enough on the full idea on sway bar upgrades and suggest you do the same. so heres an illustrated version, for the ones seeking to tackle this task.
Prepare for a FEW+ hours off the streets and under the car.
I just used WD-40 to break loose and clean tools and hardware.
Keep all the parts that are removed from the car (nuts, Bolts, etc.. etc...) CLEAN,
as they will need to be Re-installed.
Use "Anti sieze metal compound" on all bolts re-entered into your car,
for a more quality job.
First off :
put the car on ramps
The car needs to stay at a level stance from left to right to keep the sways from having any tension upon removal. ramps do the trick.
Second :
remove splash guard of course, you can not work with that in the way.
now you can attempt to remove the Front Endlinks
you would need a size 4 alan key and a 14mm wrench,
but save your self some time and use some kind of cutting tool to remove them.
you only need to cut the one side of the link that attaches to the control arm.
my tool of choice was Sawz-All.
Third :
Remove the chassis brace, directly under the bar.
you can not fish the oem bar out, again save time and remove the 10 bolts holding it in.
you can leave the 2 bolts located in the center towards the rear of the vehicle backed out 3/4 of the way to give yourself enough room to get the bar out. thats what i did. no need to fully remove it.
Fourth :
Remove left and right stay brackets / bushings,
I replaced mine with aftermarket ones, suggest you do the same.
now the oem bar and the oem endlinks go through the open area of the chassis brace, and then removed from underneath your car. go on, GET!
NO PICS, self explanatory..
Fifth :
When re-installing the upgraded stay brackets/bushing (poly),
you want to use a lithium based water proof grease.
Apply grease inside of Bushing, between the bracket and bushing, and on the Bar.
i did a lil over kill on the grease, but who cares right.. in theory i know im good.
now Re-attach Stay brackets and upgraded Bar, loosely.
you will need to move the bar side to side to match up with the new Solid endlinks.
Sixth :
I'm using Whitelines solid front Endlinks, With the $5 Whiteline washers. GET the washers.
place the washer between the the bar and control arm,
and between the bar and the endlink. easy as that.
Start with the bar in the general area they are gonna sit during use
(Bar higher than Control arm)
when fitting Endlinks to the bar.
remember, Keep things LOOSE until everything has been fitted, and anti siezed.
now tighten it all up.(brackets,endlinks)
I put about 15-20 ft/lbs torque on hardware.
to be honest im not sure if that's spec, but no issues apparent.
seventh:
Re-install chassis brace, again 15-20 ft/lbs, anti seize.
now Splash Guard
cake, enjoy.
B. Kelley
I dont think my thread turned out the way i wanted it to but i tried. lol
pics are in order from left to right, down.
goodluck everyone.
ID:	133858   Click image for larger version
ID:	133859   Click image for larger version
ID:	133861   Click image for larger version
ID:	133862   Click image for larger version
ID:	133864   Click image for larger version
ID:	133865   Click image for larger version
ID:	133868   Click image for larger version
ID:	133869   Click image for larger version
Last edited by chimaira4deth; 11-14-2012 at 05:10 AM.. Reason: trying to resize photos, but no luck..
The Following 2 Users Say Thank You to chimaira4deth For This Useful Post:
amm203 (02-16-2017), kunfuzion (01-14-2016)
chimaira4deth
Find More Posts by chimaira4deth
#2: 11-13-2012, 11:01 PM
 Drift Motion
Drift Motion's Avatar
Title: wheels
Car: Malibu w/V8 RWD Conversion
tip: change all the [url] to [img], same with the [ /url] and [/img]
It'll help a lot!
Drift Motion
#3: 11-14-2012, 04:42 AM
 chimaira4deth
That's what I was tryin to do thanks man!!
chimaira4deth
#4: 11-14-2012, 04:43 AM
 chimaira4deth
Pictures turned out huge! Lol
chimaira4deth
#5: 11-14-2012, 06:24 AM
 RochNY91TSI
RochNY91TSI's Avatar
Car: '10 Forester, '12 LGT
Send a private message to RochNY91TSI Find all posts by RochNY91TSI Reply With Quote
Wow, the value of not living in the rustbelt. Amazing to see such clean bolts and parts under the car!
RochNY91TSI
Find More Posts by RochNY91TSI
#6: 11-14-2012, 06:58 AM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 6MT (gone). '15 F150 3.5TT
Great walkthrough.
Not currently in stock
BarManBean
Find More Posts by BarManBean
#7: 11-14-2012, 07:44 AM
 chimaira4deth
That's an 05 Virginia car with 140k miles. Lol I can only imagine how much the northern cars suck to work with.
chimaira4deth
#8: 11-14-2012, 07:46 AM
 chimaira4deth
Originally Posted by BarManBean View Post
Great walkthrough.
Thanks man!
I really like how these bars handle.
Thanks for selling them to me lol
chimaira4deth
#9: 11-14-2012, 07:50 AM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
They suck big time, trust me...
BarManBean
#10: 11-14-2012, 08:20 AM
 laff79
laff79's Avatar
Title: V.P. of Rustle
Car: '05 ABP Legacy GT
Send a private message to laff79 Find all posts by laff79 Reply With Quote
nice write-up
laff79
Find More Posts by laff79
#11: 11-14-2012, 10:37 AM
 BLACKeNeD
BLACKeNeD's Avatar
Car: 2006 LGT LTD Infamous stg2 MothaFooker
Send a private message to BLACKeNeD Find all posts by BLACKeNeD Reply With Quote
I live in NY and the front sways tooke me 5+ hours. Every one of the 10 bolts holding the chassis brace on were seized. Only after breaking 2 bolts did I decide to use heat in addition to the pb blast
BLACKeNeD
Visit BLACKeNeD's homepage!
Find More Posts by BLACKeNeD
#12: 11-14-2012, 10:53 AM
 PDX Flat-4
PDX Flat-4's Avatar
Car: 05 LGTL
Send a private message to PDX Flat-4 Find all posts by PDX Flat-4 Reply With Quote
Nice walk through looking to upgrade mine soon
PDX Flat-4
Find More Posts by PDX Flat-4
#13: 01-04-2014, 04:48 PM
Thanks!
 jeb532
Car: 2011 Legacy 3.6R
Send a private message to jeb532 Find all posts by jeb532 Reply With Quote
made my 26mm bar a 45 minute start to stop job!
The Following User Says Thank You to jeb532 For This Useful Post:
chimaira4deth (07-17-2014)
jeb532
Find More Posts by jeb532
#14: 10-20-2016, 07:05 AM
 spc2125
spc2125's Avatar
Car: 06 LGT Spec B #368 VF52 325whp/333wtq
Send a private message to spc2125 Find all posts by spc2125 Reply With Quote
I wish all walkthrus were like this one.
Kudos
spc2125
Find More Posts by spc2125
