Reload this Page 5MT won't go into 2nd gear
#1: 11-08-2012, 12:33 PM
 Kennyfvholla
Kennyfvholla's Avatar
Car: 99 OBL, 04 Accord EX 6MT coupe
Send a private message to Kennyfvholla Find all posts by Kennyfvholla Reply With Quote
Alright guys, I'm pretty sure something is internally screwed...
I was having difficulty getting my car into 1st and 2nd the other day at a stop, and then getting into 3rd once it went into 2nd. All other gear were fine if I didn't try and put it into 1st or 2nd. I still had difficulty while moving, but much less so.
The day before yesterday, or yesterday (I don't even remember), I wasn't able to get it into 2nd at all. I still can not. Engaging 1st gear is still rough when stopped, and not at all if I've just stopped from moving.
If I try to force it into 2nd it gets jammed and I have to force it back out. FYI, I'm only getting it like a few millimeters into the gate when it jams. It pretty much just won't go into the gate.
I've checked my linkage underneath for any problems, but it's exactly the same as it has been. Sloppy because of the lack of rubber bushings... But nothing seems broken or damaged beyond that.
Whatcha guys think?
Kennyfvholla
Find More Posts by Kennyfvholla
#2: 11-08-2012, 01:14 PM
 Swagon_Wagon
Swagon_Wagon's Avatar
Title: Joe The Shit Show
Car: 1997 Legacy GT Swagon
Send a private message to Swagon_Wagon Find all posts by Swagon_Wagon Reply With Quote
fuild. what gear oil are you running. 5mt are very picky
Originally Posted by Stang70Fastback View Post
Clearly, the solution to shit breaking is to break more shit until the shit works again.
I'm Dumber Then I Seem, Remember That, I Won't.
Swagon_Wagon
Find More Posts by Swagon_Wagon
#3: 11-08-2012, 01:37 PM
 Kennyfvholla
Why would this problem come out of nowhere? And why would I only have issues with 1st and 2nd, mostly 2nd of course?
I dont know what fluid is in it. I haven't touchd it since I bought it.
Kennyfvholla
#4: 11-08-2012, 01:45 PM
 Swagon_Wagon
scotty's coaktail is worth a shot. try it out. you can order it on grimmspeed
Swagon_Wagon
#5: 11-08-2012, 01:58 PM
 Kennyfvholla
Okay so I went out and pull the little dip stick.
It's bent...
And here's the level:
Kennyfvholla
#6: 11-08-2012, 02:26 PM
 Hepy117
Hepy117's Avatar
Car: '12 LGT DIP
Send a private message to Hepy117 Find all posts by Hepy117 Reply With Quote
I know on the 4th gens they are all bent so i am sure it's the same for your gen.
Hepy117
Find More Posts by Hepy117
#7: 11-08-2012, 08:04 PM
 Grimmrican
Grimmrican's Avatar
Car: 95 legacy outback
Send a private message to Grimmrican Find all posts by Grimmrican Reply With Quote
Well this is news to me I didn't even kno there was a dipstick for 5mt trannys. I looked into some gear oil today at work for my 95 ob and it said 75-90. My mechanic also said that it was fine (he's one of those mechs that has been building cars since Henry ford) so yea.
Grimmrican
Find More Posts by Grimmrican
#8: 11-08-2012, 10:18 PM
 broknindarkagain
broknindarkagain's Avatar
Title: ProGun & ProLife. So What
Car: 93BC - 95BD - 97BD - 98BG - 96BG
Send a private message to broknindarkagain Find all posts by broknindarkagain Reply With Quote
They call for 75w90...and thats a synthetic gear oil...however Subarus can be picky as to what brand / formula is used. Subaru Special S tends to work the best.
As far as your issue Kenny....I'm still sticking by what I told you before. It has to be the linkage. If not, you're having syncro problems.
-broknindarkagain
COME AND TAKE IT
"The only thing necessary for the triumph of evil is for good men to do nothing."
"When governments fear the people, there is liberty. When the people fear the government, there is tyranny.
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government."
"Never Forget, even for an instant, that the one and only reason anybody has for taking your gun away is to
make you weaker than he is, so he can do something to you that you wouldn't allow him to do if you were equipped
to prevent it. This goes for burglars, muggers, and rapists, and even more so for policemen, bureaucrats, and politicians."
broknindarkagain
Visit broknindarkagain's homepage!
Find More Posts by broknindarkagain
#9: 11-09-2012, 07:01 AM
 Kennyfvholla
I'm starting to think a bent fork...
My dad will finally be home this week and he will help me figure it out.
Can the synchro's be easily repaired if you tear the trans apart?
Kennyfvholla
#10: 11-09-2012, 08:00 AM
 broknindarkagain
You can buy a new transmission (well used) for cheaper then a new gearset. So repairing syncros is generally out of the question.
And if it were a bent fork, you would be having issues in every gear...especially first gear. When my fork bent, I wasn't able to get it into first gear at all...but I was able to force it into second and after I got moving I was able to shift from there.
-broknindarkagain
COME AND TAKE IT
broknindarkagain
#11: 11-09-2012, 08:12 AM
 Kennyfvholla
Hmmmm.. I guess I'm waiting for my dad either way. I need a lift to attempt a linkage repair.
Kennyfvholla
#12: 12-06-2012, 05:51 PM
 Kennyfvholla
Latest update:
This past weekend my dad and I put the car up on the lift and pulled the two-piece rear housing off the transmission..
We ended up finding out that I broke 20% of a fork off.. (Pics to come) We are not sure what fork it's from, and we won't unless we end up spliting the case. It is either the 1st/2nd fork or the 3rd/4th fork. Not 100% sure. While pulling and pushing on the engagement rods, every single gear engaged/disengaged perfectly. Same amount of force on each one. Nothing was broken, bent, or damaged on the rod that pulls/pushes that engagement rods.
I'm going to order a full set of gaskets and a new linkage to install on Wednesday. Hopefully all the gears will then engage smoothly and will work well enough until I sell the car. This goes on the theory that the broken component was causing my engagement issues and why I then ended up getting jammed into 3rd. If not, the whole trans will be coming out and torn apart to install a new fork.
Kennyfvholla
