Go Back   Subaru Legacy Forums > Technical Forums > Turbo Powertrains (2.0GT, 2.5GT, 2.5XT)
Reload this Page VanDyne Super Turbo
#1: 05-21-2013, 12:02 AM
VanDyne Super Turbo
 dahoseman
Car: 05 OBXT, 16G, raised, bull bar, lights
Send a private message to dahoseman Find all posts by dahoseman Reply With Quote
I've been waiting for something like this design for a long time. It has the benefits of twin charging in a single unit. No lag. Power from idle.
Technical Explanation of the VanDyne SuperTurbo - YouTube
dahoseman
Find More Posts by dahoseman
#2: 05-21-2013, 01:06 AM
 LegacyDan
LegacyDan's Avatar
Car: Jdm spec 2.0GT VF36 twin scroll
Send a private message to LegacyDan Find all posts by LegacyDan Reply With Quote
pretty popular on lots of german and vw models already
LegacyDan
Find More Posts by LegacyDan
#3: 05-21-2013, 05:49 AM
 Beanboy
Beanboy's Avatar
Title: 360 lbs of shove
Car: GRP20GLGT5MT Wagon , Buell XB12S
Send a private message to Beanboy Find all posts by Beanboy Reply With Quote
Nobody is transferring power back to the engine mechanically via the supercharger CVT like this system though.
This is closer to the electric turbocharger idea from BMW where an electric motor helps spin up the turbine and then is used to slow it down (no traditional wastegate) sending electricity back to a battery pack/capacitor.
-B
www.standardshift.com
Beanboy
Visit Beanboy's homepage!
Find More Posts by Beanboy
#4: 05-21-2013, 06:05 AM
 MatsuDano
MatsuDano's Avatar
Title: Cinnabon
Car: Cinnabon and Homeroom
Send a private message to MatsuDano Find all posts by MatsuDano Reply With Quote
was...
was that...
Al Gore narrating that?
zzzzzzzzzzz...
MatsuDano
Find More Posts by MatsuDano
#5: 05-22-2013, 02:10 AM
 dahoseman
I'm not even concerned with the regenerative power part. I like the supercharger with turbocharger component. For any smaller engine that lacks low-end torque, supercharging adds great drivability (like a VW Corrado, Small engine Mercedes, or Toyota Lumina Minivan). For any larger high-torque engines that already have low-end grunt, turbocharging is fantastic to add HP to the grunt torque (Dump trucks, Diesel trucks, Hennessy V10's)
I love a coffee-table torque curve. If a FAI system can produce boost at idle and continue that same boost to redline, I am quite interested.
dahoseman
#6: 05-22-2013, 09:01 AM
 GEE-OTTO
GEE-OTTO's Avatar
Title: GEE OTTO
Car: 2009 OBP Legacy 2.5i SE 5sp
Send a private message to GEE-OTTO Find all posts by GEE-OTTO Reply With Quote
Kinda like a useful version of Subaru Bi-Turbo setup
GEE-OTTO
Find More Posts by GEE-OTTO
#7: 05-25-2013, 07:40 AM
 wurkenman
wurkenman's Avatar
Title: Contributing V.P.
Car: 05 LGT(mine), 07 Legacy 2.5I (wife's)
Send a private message to wurkenman Find all posts by wurkenman Reply With Quote
Originally Posted by MatsuDano View Post
was...
was that...
zzzzzzzzzzz...
Come on people, I'm super serial !!!!
If you woke up today, you have another chance to do it right.
I have the typing ability of a epileptic in a strobe lit room typing with boxing gloves.
The Following User Says Thank You to wurkenman For This Useful Post:
Brprs (05-25-2013)
wurkenman
Find More Posts by wurkenman
#8: 05-25-2013, 08:36 AM
 StoplightAssassin
StoplightAssassin's Avatar
Title: Get some oppo
Car: 2012 Hammerhead-i Eagle Thrust
Send a private message to StoplightAssassin Find all posts by StoplightAssassin Reply With Quote
It looks like they're adding a lot of complexity, maintenance, and cost by using a system like this.
Recent turbo engines with direct injection have hardly any lag at all. Look at GM's new LTG engine. The twin scroll turbo is integrated into the manifold. Peak torque is available from 1500 to 5500 rpm.
Excelsior!
South Jersey Region SCCA AutoX: http://legacygt.com/forums/showthread.php?t=120907
'10, '11 ESP Champ!
'12 2nd Place STX
Final Overall Pax: 3rd '11, 4th '12
StoplightAssassin
Find More Posts by StoplightAssassin
#9: 05-26-2013, 09:54 PM
 dahoseman
Excelsior!
True for the most part. I do love direct injection and not sure why Subaru hasn't been on it for a while (like Mazda's Speed3 and Speed6). I'm still quite confused as to why it hasn't been on nearly every car for many years, considering it is actually a relatively 'old' technology whose benefits were realized when the Model T was modern technology and was refined even before computers were common.
To play devil's advocate, direct injection is great for what we colloquially call "lag", but is no substitute for having 3-5PSI right off of idle. Combining the two would be fantastic.
dahoseman
#10: 05-29-2013, 05:34 PM
 iNVAR
iNVAR's Avatar
Title: Nerd^2
Car: 05 LGT 5MT Stg2 custom
Send a private message to iNVAR Find all posts by iNVAR Reply With Quote
Err... I always thought that a small engine with little low-end torque is hurt by a supercharger at the low end... A supercharger is a direct parasitic mechanical load on the crank.
iNVAR
Find More Posts by iNVAR
#11: 05-29-2013, 06:10 PM
 boostedgrocerygetter
boostedgrocerygetter's Avatar
Car: Facebook. BGG Sway Bar Brackets
Send a private message to boostedgrocerygetter Find all posts by boostedgrocerygetter Reply With Quote
It would nice if you could get this set up on our motors but I don't see to much room for it.
As far as direct injection. Just a guess but it probably hasn't been to popular because of how dirty it allows the intake valves to get since you don't have to injectors to help clean them with fuel. Not sure about any of you but I wouldn't want to tear down one of our motors to walnut blast the intake valves.
Find More Posts by boostedgrocerygetter
#12: 05-29-2013, 07:19 PM
 K2e2vin
Car: '05 LGT Wagon, '92 Accord , '88 Civic
Send a private message to K2e2vin Find all posts by K2e2vin Reply With Quote
I don't know, I kind of think of it as more of a compromise between a turbo and twin-charge setup. Main reason being even though a (roots) supercharger doesn't have the peak efficiency of a turbo, it's more efficient over a wider area(a lot of guys prefer roots/screw SCs over centrifugal already). Though, of course this very much depends on the CVT/gearing and compressor choice. The transmission itself can be a source of more drag that reduces efficiency(I'd be curious about cooling too).
Also, the regeneration properties seem like a waste too since the turbine acting directly with the engine could also be a source of drag(friction) and backpressure. I'd imagine a properly sized turbo would work better and I honestly like BMW's idea better since it's using "wasted" energy converted into a storable(is that even a word?) form of energy.
Maybe if the somehow simplify everything, I'd be more conviced...but I think it's hard to beat a properly sized turbo. There's ways to set them up for economy, or power, or a combination of both!
If you want to twin charge your Subaru...check out the SC from Innovate for the BRZ/FR-S...half-way there?:
K2e2vin
Find More Posts by K2e2vin
#13: 06-06-2013, 01:09 PM
 dahoseman
A supercharger is parasitic at all rpms, but it produces more power than it requires to operate. It is also NOT equivalent (typically) to think of it as a belt driven turbo that builds boost after a lull of low rpm parasitical drain on power. Most superchargers have their greatest charging effects in low RPMs. There isn't a normal manifold vacuum on supercharged vehicles. As long as it's spinning, it's producing more power than it requires to run (except at initial start). I can't speak for other people's experiences, but I've driven several different small displacement supercharged vehicles (Several VW Corrado G60's and a Toyota Previa) as well as their normally aspirated counterparts.
The 1.8L corrado with the G-charger definitely had more power than the NA 1.8L engine or 2.0L (on other models) at 1000rpm when letting the clutch out.
Toyota actually dropped the NA engine option in favor of S/C on their 90's previa minivans because the supercharged version produced much better torque at the same fuel economy. I know people want to argue the parasitic model (it's true, but does not account for combustion, friction, and other variables in fuel consumption), but I've seen more than one vehicle stay at the same fuel consumption or actually improve fuel economy with mild supercharging. I can't give great explanations of why, but I'm just aware that it happens. Just look at the government EPA ratings on production cars.
1995 Toyota Previa NA with 135hp vs 1995 Toyota Previa S/C with 160hp. The supercharged engine actually gets 1mpg better on the highway.
http://www.fueleconomy.gov/feg/Find....12385&id=12386
Anyway, I'm clearly biased. I like superchargers on gasoline engines for real world driving. I rarely drive in the screaming high rpm in normal driving and I like to accelerate from stop signs and have grunt to get up a hill without shifting.
dahoseman
