Go Back   Subaru Legacy Forums > Model Specific Forums > Fourth Generation Legacy (2005 - 2009)
Reload this Page Wagons beware - tailgate electricals
Search Forums
Search via Google
Go to Page...
Page 1 of 5 1 23 > Last »
View First Unread View First Unread
#1: 04-29-2011, 04:44 PM
 LGT_King
LGT_King's Avatar
Car: 2007 DGM LGT
Send a private message to LGT_King Find all posts by LGT_King Reply With Quote
It took me awhile to find this info and solve my issue so I would just post it up here for a sort of FYI. Because if it hasn't happened it likely will.
My parents have a outback XT (I flashed it to stage 1 ). Anyway they complained that the rear trunk would not lock anymore with the keyless remote.
Went over pulled all the trim off and had a look at the mechanism and plugs. 2 plugs, one for seeing if its closed (dash light) and one to close/open it - both two wire.
Checked and the unlock wire got power but the lock wire didn't. Low and behold in the connection (accordion boot) between the hatch and the car on the right side the wire was cut clean. Even some other wires had exposed portions as if they eventually would be severed.
Connected a wire to join the lock wire and then wrapped all the wires with some exposed portions with electrical tape. And then everything with electrical tape... Some poor design maybe??
cliff note: wires being cut by the open/closing of the rear hatch inside the boot on the top right causing things to stop working. Mine was rear trunk lock, but easily could be light related.
The Following 11 Users Say Thank You to LGT_King For This Useful Post:
BAC5.2 (05-01-2011), BigBad (09-26-2012), BigTDogg (MA) (03-26-2012), gil_ong (04-30-2012), honeybadger (04-20-2012), jagcars26 (04-30-2011), Leonardo (04-01-2012), robinlsb (04-01-2012), SubOperator (05-01-2012), ViscousSquirrel (03-28-2012)
LGT_King
Visit LGT_King's homepage!
Find More Posts by LGT_King
#2: 04-29-2011, 05:01 PM
 black_bulletgt
black_bulletgt's Avatar
Car: 05 LGT Wagon Stage 1
Send a private message to black_bulletgt Find all posts by black_bulletgt Reply With Quote
thanks for the warning. will have to check mine out when i have some time.
black_bulletgt
Find More Posts by black_bulletgt
#3: 04-29-2011, 07:07 PM
 BAC5.2
BAC5.2's Avatar
Car: 2009 SWP Grandma XT-B (5MT)
Send a private message to BAC5.2 Find all posts by BAC5.2 Reply With Quote
Thanks! Since I have to run wires through there soon, ill sheath the wires to protect them.
BAC5.2
Find More Posts by BAC5.2
#4: 04-29-2011, 08:13 PM
 ironchefireland
ironchefireland's Avatar
Car: 05 RBP LGT ltd wagon 5MT
Send a private message to ironchefireland Find all posts by ironchefireland Reply With Quote
Interesting. I've got some odd thing were the keyless will lock the doors but not the rear lift, but will set the alarm. Sometimes I forget and the alarm goes off. Really annoying. Gonna have to check those wires.
ironchefireland
Find More Posts by ironchefireland
#5: 04-30-2011, 12:30 AM
 AkumaMax
AkumaMax's Avatar
Title: Contributing V.P.
Car: 2005 LGT Wagon Limited 5EAT
Send a private message to AkumaMax Find all posts by AkumaMax Reply With Quote
Thanks for the heads up I will look into this and maybe add some pictures to what you are talking about.
AkumaMax
Find More Posts by AkumaMax
#6: 04-30-2011, 06:58 AM
 jagcars26
jagcars26's Avatar
Title: Keeper of the hounds
Car: 05 Legacy GT wagon,09 Forester
Send a private message to jagcars26 Find all posts by jagcars26 Reply With Quote
Thanks fr the heads up.
jagcars26
Find More Posts by jagcars26
#7: 05-01-2011, 06:42 AM
 Max Capacity
Max Capacity's Avatar
Title: Gearhead
Car: 05GT Wagon 5MT stg2, 09 specB stg1
Send a private message to Max Capacity Find all posts by Max Capacity Reply With Quote
Mine is different. sometimes, it won't unlock. We went in from the back seat. popped the panel off and moved the lever down with a light push and it unlocks.
It did this the first time last Fall, but after driving the car to my buddies body shop, the thing unlocked and worked like there was no problem. Yesterday while the car was up on jackstands, the hatch wouldn't unlock.
Will trouble shoot more during the next week or so. Tranny's out being rebuilt, but that's a different thread.
175,000+ miles, 5/20/12 new ej257 short block, 8/20/11 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. Also CHECK YOUR OIL, these cars use it.
Max Capacity
Find More Posts by Max Capacity
#8: 03-26-2012, 07:45 AM
 Max Capacity
Title: Gearhead
Open the hatch and pull the rubber cover back on the wires in the right upper corner, you may find broken wires there.
My buddy's body shop repaired four or five broken wires there on mine for $120.00 much cheaper then the $3-400 estimate I got from the dealer.
Max Capacity
#9: 03-26-2012, 07:46 AM
 frank_ster
frank_ster's Avatar
Title: MASTER OF THE BUCKARU
Car: 05 lgt 5EAT 3.8, buell 1125cr ,79 camaro
Send a private message to frank_ster Find all posts by frank_ster Reply With Quote
ah thats whats wrong with mine ! mine was blowing the fuse for locks .. now just the hatch lock doesn't work anymore ..
Now that's thinking out of the boxer!
fyi all 05 legacy's have built in code reader
The Following User Says Thank You to frank_ster For This Useful Post:
frank_ster
Find More Posts by frank_ster
#10: 03-26-2012, 11:23 AM
 nwsurfwakeskate
nwsurfwakeskate's Avatar
Car: 2005 Legacy GT wagon Manual
Send a private message to nwsurfwakeskate Find all posts by nwsurfwakeskate Reply With Quote
05 RBP wagon
122k miles. 3rd brake light quite working about a month ago and my rear dome light only turns on when I first open the hatch but then goes out after the hatch is more then 2 inches open. Any ideas where to start? I pulled the rubber boots back on the wires running through the hinges and they looked fine from what I could tell. Have yet to open up the trim yet. Pics or a how-to would certainly be nice!
Thanks,
CJ
nwsurfwakeskate
Find More Posts by nwsurfwakeskate
#11: 03-27-2012, 01:30 PM
 OutbackXT05
OutbackXT05's Avatar
Car: 05 OBXT OBP 20gXT 5mt
Send a private message to OutbackXT05 Find all posts by OutbackXT05 Reply With Quote
Mine is wierd. When i bought the car it had an aftermarket alarm in it. It works on all doors and the hatch. But the oem subaru one i bought after onlu opens/closes the door. Trunk does not work. And also my rear latch sensor is tripping out. It keeps flashing on and off on my cluster and its really annoying. Anyone know how to fix that?
OutbackXT05
Find More Posts by OutbackXT05
#12: 03-27-2012, 03:55 PM
 mbcracken
mbcracken's Avatar
Car: 05 GT 5MT Leggy Wagon
Send a private message to mbcracken Find all posts by mbcracken Reply With Quote
Wires breaking in the rubber wire cover between rear hatch and body have caused me many headaches...
It first started with my rear wiper intermitten not working properly. I first replaced the wiper motor which I did myself. Did not fix it... I replaced the wiper switch on the steering column. Did not fix it... Dealership fixed it by replacing wires for $100 (mostly labor as I didn't want to mess with removing headliner).
A couple weeks go by, the wires go out for the radio antenna...ugh. Got it fixed too at dealership.
Subaru really went cheap on these wires and have caused all sorts of headaches. Well documented over on the Outback forums. My recommendation would be to replace all the wires at once when you have everything opened up. Good luck...
Cheers,
Mike
mbcracken
Find More Posts by mbcracken
#13: 04-01-2012, 07:11 AM
 Leonardo
Leonardo's Avatar
Title: Cowabunga!
Car: 09 Smart ForTwo Passion
Send a private message to Leonardo Find all posts by Leonardo Reply With Quote
I would do what Mike did. I would take all issus related to this issue to the dealer so all this gets documented and probably SOA will release a service bulletin or recall as it will affect mostly all of the wagon & outbacks out there. If the dealer charged you and a recall is issued, you get refunded the money for those repairs done at the desler.
Leonardo
Find More Posts by Leonardo
#14: 04-19-2012, 09:41 PM
 nwsurfwakeskate
Well I finally dove into this to try and fix my 3rd brake light and rear dome light issues.
ended up cutting the boot in the middle so that I could fold it over its self. Without doing this I couldn't get enough wire exposed to add some butt splices in. Sure enough there was 2 wires broken and about half a dozen that were cut through the insulation. I repaired the wires that were broken and wrapped everything up in Rescue Tape (silicone tape). Both the 3rd brake light and rear dome light work the way they are supposed to now. I tried opening up the headliner a little bit to see if this was an easy wiring harness to replace. The shit looks like it runs everywhere and its electrical taped into every other wire harness that comes near it both in the tailgate and in the headliner! WTF subaru!!!!
I'm debating cutting the whole thing and rewiring each connection eventually but for now my bandaid repair should hold for awhile. Thank God the brake lights aren't in the tailgate. that could be a serious problem!
nwsurfwakeskate
#15: 04-23-2012, 05:49 PM
 frank_ster
frank_ster's Avatar
yep 3 wires sawed right through others insulation is cut. so will put 3 peices of wires in and protect the rest with some conduit if i can shove itin there
frank_ster
Thread Tools
Search this Thread
Similar Threads
Thread Thread Starter Forum Replies Last Post
07 LGT Wagon Tailgate Rattles? w3dstyle Warranty Issues & Problems 22 06-26-2008 03:37 AM
Nine 2006 USDM LGT MT wagons made unclemat Fourth Generation Legacy (2005 - 2009) 38 03-06-2008 03:47 PM
No Legacy Wagons prof555 Subaru News & Rumors 237 02-09-2008 01:45 AM
1993 Legacy Wagon L, Tailgate problem FloydLegacy First Generation Legacy (1989 - 1993) 2 07-24-2005 01:42 AM
Sedan rear styling... racerdave Fourth Generation Legacy (2005 - 2009) 56 03-23-2004 07:16 PM
