Go Back   Subaru Legacy Forums > Model Specific Forums > Fourth Generation Legacy (2005 - 2009)
Reload this Page legacy gt wheel spacers... need some insight
Page 1 of 3 1 23 >
Thread Tools
04-10-2011, 10:30 PM
 theone87
theone87's Avatar
Send a private message to theone87 Find all posts by theone87
i have an 05 legacy gt... and like most lgt owners im cursed with the 5x100 bolt pattern lol...
i was just wondering if buying wheels spacers to convert the hubs to 5x114.3 is a good idea... i already know the positives because every sight advertises it.. and i also have a wider variety of wheel choices... but are there any negatives to doing this... and if i was to do this to what specs should i buy these spacers...? brand? etc.... any info is appreciated...
heres a random site that sells them....
http://www.advancespeedshop.com/proj...s-p-16205.html
theone87
Find More Posts by theone87
04-10-2011, 11:05 PM
 contractkiller
contractkiller's Avatar
Title: Gun for hire
Car: 2005 LGT Wagon. GRP 5MT 18G
Send a private message to contractkiller Find all posts by contractkiller
why are you so opposed to the 5x100?
contractkiller
Find More Posts by contractkiller
04-10-2011, 11:35 PM
 Whatisit
Whatisit's Avatar
Car: 2009 Legacy GT-specB
Send a private message to Whatisit Find all posts by Whatisit
ive seen this style of wheel spacers crack clear off and a wheel comming off. Not to mention that you put alot of extra stress on the wheel bearings.
The Following User Says Thank You to Whatisit For This Useful Post:
theone87 (04-12-2011)
Whatisit
Find More Posts by Whatisit
04-10-2011, 11:43 PM
 Drift Motion
Drift Motion's Avatar
Car: RMS13 --> 05 Turbo Camry
Send a private message to Drift Motion Find all posts by Drift Motion
as awesome as 5x114.3 is
putting on those conversion spacer will just kill your wheel bearing
they are at least 15mm
you are putting alot of stress on the bearings
just stick with the limited amount of wheels 5x100 offers...
The Following User Says Thank You to Drift Motion For This Useful Post:
Drift Motion
Find More Posts by Drift Motion
04-11-2011, 06:33 AM
 jagcars26
jagcars26's Avatar
Title: Keeper of the hounds
Car: 05 Legacy GT wagon,09 Forester
Send a private message to jagcars26 Find all posts by jagcars26
/\truth
Wheel spacers=bad juju.
The Following User Says Thank You to jagcars26 For This Useful Post:
jagcars26
Find More Posts by jagcars26
04-11-2011, 12:44 PM
 IDRVSLO
IDRVSLO's Avatar
Title: The Headlight Guy
Car: 2005 LGT SWP
Send a private message to IDRVSLO Find all posts by IDRVSLO
Wheel spacers are just like using a lower offset wheel....people never seem to understand that and just say they ruin bearings....etc.
The Following 5 Users Say Thank You to IDRVSLO For This Useful Post:
Chameleon (05-10-2012), gdogg16 (04-07-2012), theone87 (04-12-2011), TRSCobra (04-11-2011), V8Bait (03-04-2013)
IDRVSLO
Find More Posts by IDRVSLO
04-12-2011, 12:41 AM
 theone87
theone87's Avatar
thanks for the info... really appreciate it...
theone87
04-12-2011, 01:50 AM
 Drift Motion
low offset wheel do not kill wheel bearing
i've ran all sorts of wheels from 0-20 offset for years
no problem
Drift Motion
04-12-2011, 08:39 PM
 IDRVSLO
IDRVSLO's Avatar
Car: 2005 LGT SWP
That is what I am saying.....a quality hub centric adapter or spacer places the same stress on bearings as a low offset wheel, if the correct math is done. I agree that a low offset wheel does not kill bearings....but everyone is paranoid with our cars.
Scott G
IDRVSLO
04-19-2011, 04:22 PM
 HaloNHorns2002
HaloNHorns2002's Avatar
Car: SWP '07 SE Wagon/'99 Miata/'99 Wrangler
Send a private message to HaloNHorns2002 Find all posts by HaloNHorns2002
If you really love your car you shouldn't drive it.
The Following 2 Users Say Thank You to HaloNHorns2002 For This Useful Post:
adreyna (04-08-2012)
HaloNHorns2002
Find More Posts by HaloNHorns2002
04-06-2012, 02:01 PM
 flipsubie06
flipsubie06's Avatar
Car: 06 Legacy GT Sedan
Send a private message to flipsubie06 Find all posts by flipsubie06
so wut would the proper math be for a 1" 5x114 adapter?
flipsubie06
Find More Posts by flipsubie06
04-06-2012, 10:41 PM
 Drift Motion
none, don't use them PERIOD
Drift Motion
04-06-2012, 11:52 PM
 scoobyscoodle
scoobyscoodle's Avatar
Car: '09 swp spec.B -'74 DL -'06 OBXT-R.I.P.
Send a private message to scoobyscoodle Find all posts by scoobyscoodle
If you run a spacer that retains factory axle studs, or uses longer axle studs, there is no difference between those and low offset wheels in terms of stress put on the bearings. As long as they are the kind of spacers that slide over your axle studs, I consider them safe, even if they are 15mm.
It's the really large "bolt on" spacers and 114 conversion spacers that you should stay away from. Having a spacer that is bolted to the hub, with studs pressed into the spacer that bolt the wheel on is a bad idea. They are weaker by design and transfer loads to the rotors differently because the studs that hold the wheels on do not pass through the rotors.
Do not buy conversion spacers or spacers with pressed in studs.
scoobyscoodle
Find More Posts by scoobyscoodle
04-06-2012, 11:56 PM
 Drift Motion
slip on/bolt on spacer != low offset wheel
Drift Motion
04-07-2012, 12:05 AM
 scoobyscoodle
how?
scoobyscoodle
Page 1 of 3 1 23 >
Thread Tools
Similar Threads
Thread Thread Starter Forum Replies Last Post
The new: ** OFFICIAL** Mid-Atlantic member directory TheWeatherWarrior Mid-Atlantic 233 05-12-2013 04:46 AM
All-New 250-Horsepower Legacy(R) 2.5 GT for 2005 EJ20H-TT Fourth Generation Legacy (2005 - 2009) 66 11-08-2008 07:41 PM
Wheels alone? Wheels with summer tires? Wheels with winter tires? SD's got it all!!! Subydude.com Wheels/Tires 73 10-11-2008 11:22 AM
05 legacy gt wheel grapenut262 Want to buy 1 05-05-2008 09:36 PM
Wheel VS legacy GT and Outback XT Alain969 Wheels/Tires 9 06-01-2006 11:01 AM
