Reload this Page 2.5GT Turbo Oil Supply Banjo Bolt Filter Removal
Page 1 of 64 1 231151 > Last »
#1: 05-14-2007, 10:48 AM
 rao
Title: Too Big to Fail
Car: 05 Legacy GT/98 BMW 540 w/Chevy Power
Send a private message to rao Find all posts by rao Reply With Quote
I added this as a sticky with only the how to portion http://www.legacygt.com/forums/showthread.php?t=62371
After much discussion, it turns out that there are TWO filters inside of the banjo bolts that are at the entrance to the oil feed pipes - one on the driver's side that goes to the AVCS solenoid and one on the passenger's side that feeds the AVCS solenoid and the turbo oil feed.
Towards the end of this post http://www.legacygt.com/forums/showt...=58023&page=19 people discussed accessing this bolt for cleaning the filter and/or replacing it. Someone posted a great idea and I decided to consolidate the procedure in one post.
I removed the Bolt, removed the filter and put it all back together in about 30 minutes. Turns out that it is not hard to do at all. I didn't have time to try to tackle the driver's side bolt, but that one is of less concern.
Tools -
10mm wrench or 1/4" drive socket
14mm deep socket
14mm regular socket
Universal joint for the 14mm regular socket
17mm shorty wrench
Magnetic pick up (you are going to need it)
Make sure the engine is cold - you will be very intimate with portions of it.
Steps:
1. Remove the engine cover
2. Remove one of the heat shield bolts as shown in the picture
3. Remove the nut from the stud as shown in the picture
4. Remove the bolt from the bracket as shown in the picture. This is the hardest part because you can't get a good angle at it. Use the u-joint.
5. Remove the bracket itself
6. Remove the Banjo bolt. Use the 17mm shorty and take your time. Be careful with the washers and not that a few drops of oil WILL leak out onto the up-pipe.
7. Remove the filter. Be careful or you will break it.
8. Install the banjo bolt and washers. Do not overtighten.
9. Replace everything else.
Depending on your turbo and wastegate actuator the job might be easier or harder.
My filter had absolutely nothing in it (22k miles).
The car seems to drive much better, plus I am now richer AND better looking In fact several ladies approached me right after I completed the job - interesting.....
The pictures are the best I could do. The are is very hard to see, let alone photograph.
I bet I could do another one in around 20m minutes; NC crew I WILL be charging for this - no freebies.
I hope this helps people.
ID:	37005   Click image for larger version
Name:	5-14-07 - Turbo Feed Banjo Bolt (1).JPG
Rob
This DISCLAIMER applies to this post.
IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT
The Following 2 Users Say Thank You to rao For This Useful Post:
maoski87 (11-17-2011), wac (10-11-2011)
rao
Find More Posts by rao
#2: 05-14-2007, 10:54 AM
 fatbastard
fatbastard's Avatar
Car: '05 LGT Ltd Wagon 5MT
Send a private message to fatbastard Find all posts by fatbastard Reply With Quote
Nice...I may have to take a look at this, anything that can make the car run better and help with the ladies is alright by me.
Really though, is there any consensus as to why these would get plugged to begin with? If yours was clean after 22k it makes you wonder. All these blown engines are starting to make me rethink the mod path...would just like to get a little warm and fuzzy back.
fatbastard
Find More Posts by fatbastard
#3: 05-14-2007, 11:12 AM
 DeepFreeze2
DeepFreeze2's Avatar
Title: I'm serious about meets!
Car: '05 Legacy GT Ltd. 5EAT
Send a private message to DeepFreeze2 Find all posts by DeepFreeze2 Reply With Quote
Do you accept debit cards, Rob?
YA RLY!!! Home of +2500 useless posts!!!!
DeepFreeze2
Find More Posts by DeepFreeze2
#4: 05-14-2007, 11:28 AM
 rao
If you have a debit card you should be able to come up with cash
As to why or if the filters get clogged up - got me. My car hasn't been stock for most of those miles. I change the oil every 3 months with whatever 5w30 is on sale (i did use synthetic for a few changes but stopped).
Rob
rao
#5: 05-14-2007, 11:28 AM
 laneygirlid
laneygirlid's Avatar
Send a private message to laneygirlid Find all posts by laneygirlid Reply With Quote
I am a new 2007 Legacy GT owner and am not very mechanically savvy, but am wondering what necessitated this type of repair? Were you replacing some type of turbo filter?
Thanks.
laneygirlid
Find More Posts by laneygirlid
#6: 05-14-2007, 11:31 AM
 G.T.Subie
G.T.Subie's Avatar
Title: Richard Cranium
Car: S4 V8
Send a private message to G.T.Subie Find all posts by G.T.Subie Reply With Quote
:subscribe:
Denial is your best friend
G.T.Subie
Find More Posts by G.T.Subie
#7: 05-14-2007, 11:32 AM
 whitetiger
whitetiger's Avatar
Title: IDGAF
Send a private message to whitetiger Find all posts by whitetiger Reply With Quote
you say that there was nothing in the bolt/filter but after you replaced it, you felt a difference? that dosent make much sense.
whitetiger
Find More Posts by whitetiger
#8: 05-14-2007, 11:32 AM
 G.T.Subie
G.T.Subie's Avatar
Car: S4 V8
I thought that it wasn't a good idea to go back once you go to SYNTHETIC.
G.T.Subie
#9: 05-14-2007, 11:33 AM
 rao
Please MY CAR IS DOOMED
Rob
rao
#10: 05-14-2007, 11:34 AM
 rao
I also said I was richer and better looking. I was kidding. There is no way you could perceive any difference.
Rob
rao
#11: 05-14-2007, 11:35 AM
 G.T.Subie
G.T.Subie's Avatar
Car: S4 V8
Hey I was asking a serious question.
Just trying to educate myself.
<<<<Noob
G.T.Subie
#12: 05-14-2007, 11:38 AM
 whitetiger
whitetiger's Avatar
Title: IDGAF
oh, i thought you were serious about the running better part and then sarcastic about the other stuff.
how fine does the filter in the bolts look? is it just a screen mesh or somthing more?
whitetiger
#13: 05-14-2007, 11:38 AM
 direavenger
direavenger's Avatar
Title: Pro Bowler
Car: 2005 ABP LGT Sedan
Send a private message to direavenger Find all posts by direavenger Reply With Quote
rao, how many miles do you normally drive in 3 months? If the miles/OCI is low, we need to compare the filter to someone who has done extended OCI's for awhile. edmundu comes to mind...
The Dude - Two inches and counting...
direavenger
Find More Posts by direavenger
#14: 05-14-2007, 11:40 AM
 rao
<<<<Noob
I apologize; I got 2 messages mixed up.
There is a school of thought that you can't change back once you use synthetic oil, there is another school of thought that it doesn't matter. There is some merit to the idea that you shouldn't change to synthetic on a motor that has a lot of miles on it (like over 85k) because it might cause leaks due to changes in the seals. The key is to use oil that is properly rated and to change it at the right intervals, don't get hung up on the brand.
Rob
rao
#15: 05-14-2007, 11:42 AM
 rao
Well I am better looking
It is very fine screen mesh.
Not many - typically 2-3k miles. I just always change it every 3 months.
Rob
rao
Similar Threads
Questions about oil and turbo break-in colatkitty Turbo Powertrains (2.0GT, 2.5GT, 2.5XT) 1 12-22-2005 09:11 AM
Pennzoil Oil Filter Note - Use PZ:37 Unilat Turbo Powertrains (2.0GT, 2.5GT, 2.5XT) 1 03-21-2005 08:21 PM
Anyone know the right Amsoil oil filter sizes? rhess Fourth Generation Legacy (2005 - 2009) 0 02-24-2005 03:00 PM
