Reload this Page 2012 LGT BM9: Invidia Q300 Installed + Notes (cat-back, for now)
Page 1 of 4 1 23 > Last »
#1: 09-10-2012, 09:05 AM
 nuclrxn
nuclrxn's Avatar
Car: 2012 BM9 2.5GT
Send a private message to nuclrxn Find all posts by nuclrxn Reply With Quote
2012 Legacy GT (BM9)
Invidia Q300 cat-back
RallySportDirect.com using an 8% Labor Day promo code w/ Free Shipping
Invidia Q300 Quality: 5 / 5
INSTALLATION:
Difficulty (2-person): 1 / 5
Difficulty (1-person): 2 / 5
Tools: ramp set, 12mm & 14mm sockets and wrenches
Notes: Invidia provides all gaskets, bolts & nuts, and pipes to do the installation. No directions included.
Hey guys, my buddy and I just installed the Invidia Q300--cat-back section only since Cobb Stage 2 maps aren't out yet--on my GT. The build quality is top-notch. The exhaust tips are huge and fill the exhaust cut-outs on the rear bumper as if they were meant-to-be. The tips don't jut out obnoxiously. The sound is nice and deep; burble, eh, not so much, although there is a hint of it. Drone isn't as bad I as I imagined. At 65MPH+ (6th gear), it barely exists; at less than 2000RPM in any gear, yes, you'll hear it.
The only cause of concern is where the stock down-pipe (DP) and the new resonator pipe meet. The stock DP has a sort of inner, recessed collar that inserts into the stock resonator pipe. That collar doesn't fit into the new DP, so the new gasket will not work effectively; I left it off. My buddy and I just tightened the bolts connecting the stock DP and the new resonator pipe to reduce the chances of an exhaust leak. Maybe there's an adapter that fixes this? Hopefully it'll be moot once Cobb releases Stage 2 for the 2012 LGT and I install the new catted DP.
Note: The spring-bolts that were removed are not reused as a new flex-joint is designed into the new resonator pipe.
The rest of the installation went relatively smooth and the pipes aligned almost perfectly with the exhaust cut-outs on the rear bumper. The right-side muffler does sag about 4-5mm lower than the left one.
Prior to breaking in the exhaust, the left muffler was exhibiting a loud sputter at a higher frequency that the right one. I figured it was a noise that would disappear once the exhaust broke it, and it did after driving about 10 miles.
I'll be sure to post a follow-up video demonstrating the new exhaust tone.
nuclrxn
Find More Posts by nuclrxn
#2: 09-10-2012, 10:04 AM
 aerophool
aerophool's Avatar
Car: 2012 Legacy GT
Send a private message to aerophool Find all posts by aerophool Reply With Quote
I had the Invidia Turbo back exhaust installed a couple weeks ago for $75.00, worth it to have a shop who routinely installs exhausts. Figured they could hang it better than I can. Anyway, they mentioned that it was one of the best bolt-up kits they had ever installed.
Aside: it is a very loud though around 2k as noted by other people who have it installed.
aerophool
Find More Posts by aerophool
#3: 09-10-2012, 10:09 AM
 eckseleven
eckseleven's Avatar
Car: '12 LGT 289whp/348wtq, '12 OB CVT
Send a private message to eckseleven Find all posts by eckseleven Reply With Quote
FYI, it's unlikely Cobb will ever release stage 2 maps for the '12 GT unless it is for their own down pipe (which they may never make either). After the '10s and '11s, I think they have too many concerns with making a stage 2 map that matches well with the various down pipes made by other companies.
eckseleven
Find More Posts by eckseleven
#4: 09-10-2012, 10:12 AM
 Rutchard
Rutchard's Avatar
Send a private message to Rutchard Find all posts by Rutchard Reply With Quote
$75 to install the whole turboback??? Deal of the century right there! Even on a lift, the DP is a pain in the ass
The Following User Says Thank You to Rutchard For This Useful Post:
acumenhokie (09-10-2012)
Rutchard
Find More Posts by Rutchard
#5: 09-10-2012, 10:54 AM
 nuclrxn
nuclrxn's Avatar
Car: 2012 BM9 2.5GT
Yeah, that was a concern of mine, but I did talk to a Cobb tech who said that it's in the works. If they take too much longer, though, I may just take it to Agile Performance to get a custom tune; my buddy's brother owns the place.
nuclrxn
#6: 09-10-2012, 11:50 AM
 Blizzard
Blizzard's Avatar
Car: Stage 2+ 2010 LGT
Send a private message to Blizzard Find all posts by Blizzard Reply With Quote
Pro tip: If you plan on getting an Invidia DP to match, do it before anything starts rusting. Also Cobb's stage II maps may never come out but you can always get pro-tuned I believe which is a better option anyway.
Blizzard
Find More Posts by Blizzard
#7: 09-10-2012, 12:44 PM
 nuclrxn
nuclrxn's Avatar
Car: 2012 BM9 2.5GT
Yeah, calling around the DMV: Agile, Mach V, PTuning to see what the best price is. So far, Mach V quoted me $500 (50% down) and it would have to be with them the whole day.
nuclrxn
#8: 09-10-2012, 02:01 PM
 acumenhokie
acumenhokie's Avatar
Car: 2010 LGT & 2009 FXT
Send a private message to acumenhokie Find all posts by acumenhokie Reply With Quote
If you're going to pro-tune go ahead and add the RacerX TMIC while you're at it.
acumenhokie
Find More Posts by acumenhokie
#9: 09-10-2012, 02:34 PM
 ziptiecloud
ziptiecloud's Avatar
Car: '12 LGT
Send a private message to ziptiecloud Find all posts by ziptiecloud Reply With Quote
Have you purchased the AP yet? You may be able to save a ton of money on the custom tune if you buy it from the same shop
ziptiecloud
Find More Posts by ziptiecloud
#10: 09-10-2012, 05:45 PM
 pfoyle
pfoyle's Avatar
Car: Brentuned '10GT-RacerX TMIC, Invidia TBE
Send a private message to pfoyle Find all posts by pfoyle Reply With Quote
Solution: Get a protune, great gains, no problems keeping it above 2k RPMs!
pfoyle
Find More Posts by pfoyle
#11: 09-10-2012, 06:39 PM
 Syndicate
Syndicate's Avatar
Car: '12 LGT, '05 2.5RS Wagon
Send a private message to Syndicate Find all posts by Syndicate Reply With Quote
...I've only had Mach V do maintenance work, but it seems like a cool shop thus far. I'd also suggest checking w/IAG as well. Oh yeah, nice to see another BM9 GT in DMV.
...a sort of silly question I've been wondering about. Are pro-tuned maps based off of the Cobb maps? So would a Cobb stage 2 map be required for a proper downpipe compatible tune?
...oh yeah, it seems like Cobb is telling everyone different things regarding the '12 stage 2 maps, when I inquired about them they said they got a car in to do development on.
Syndicate
Find More Posts by Syndicate
#12: 09-10-2012, 06:44 PM
 eckseleven
eckseleven's Avatar
Pro-tuned maps are custom made and independent of Cobb's maps.
The Following User Says Thank You to eckseleven For This Useful Post:
Syndicate (09-11-2012)
eckseleven
#13: 09-10-2012, 09:02 PM
 islandborn
islandborn's Avatar
Title: I ride Kharon
Car: '12 LGT BNR18G
Send a private message to islandborn Find all posts by islandborn Reply With Quote
Boom. Ditto. Thats what I'm running.... custom tune on the AP with the TMIC by RacerX tied to the Invidia. Now you got..... racecar.
islandborn
Find More Posts by islandborn
#14: 09-10-2012, 09:04 PM
 DOHCstunr
DOHCstunr's Avatar
Car: 2005 SWP Legacy GT Limited 5mt
Send a private message to DOHCstunr Find all posts by DOHCstunr Reply With Quote
Nice input. Pics would have made this thread significantly more relevant.
DOHCstunr
Find More Posts by DOHCstunr
#15: 09-11-2012, 02:59 AM
 blklgt05
blklgt05's Avatar
Car: 2010 Stg.II RRP LGT 2005 Stg.II OBP LGT
Send a private message to blklgt05 Find all posts by blklgt05 Reply With Quote
Do you even drive a 5gen GT? If not then this thread is definitely not relevant to you because we have completely different setups. There are only two 3" TBE options for us and we've all seen enough pictures of them.
The Following User Says Thank You to blklgt05 For This Useful Post:
Rutchard (09-11-2012)
blklgt05
Find More Posts by blklgt05
