rao Posted July 21, 2004 Share Posted July 21, 2004 I disabled a second friend's DRLs this afternoon and you definately do not need to remove the lower panel below the steering wheel, the white plug is easily accessable with it still in place. I had it unclipped before my firend could retrieve his flashlight from the trunk :D The first time I removed the panel (which is only a few minute job), but once you know what you are looking for and where it is, it is a lot easier. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Xenonk Posted July 21, 2004 Share Posted July 21, 2004 sweet, now I dont have to worry about burning out my JGTC yellow headlight bulbs from the overuse of the DRL. Keefe Keefe Link to comment Share on other sites More sharing options...
racerdave Posted July 21, 2004 Share Posted July 21, 2004 Someone has to do it... [img]http://forum.e46fanatics.com/images/smilies/xscuseless.gif[/img] Link to comment Share on other sites More sharing options...
rao Posted July 21, 2004 Author Share Posted July 21, 2004 I agree :lol: There was a picture of the relevant connector here: [url]http://www.legacysti.com/viewtopic.php?t=1216&highlight=daytime+running+disable[/url] Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
bemani Posted July 21, 2004 Share Posted July 21, 2004 What did I tell you? :D Link to comment Share on other sites More sharing options...
rao Posted July 21, 2004 Author Share Posted July 21, 2004 Yep :), if you know what you are looking for then it is as easy as a WRX, even easier. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
racerdave Posted July 21, 2004 Share Posted July 21, 2004 thx rao. :) Link to comment Share on other sites More sharing options...
mrkickass Posted July 14, 2005 Share Posted July 14, 2005 Can you disable the drl from under the hood? Does anybody have any pics where wires are at? Link to comment Share on other sites More sharing options...
mwiener2 Posted July 14, 2005 Share Posted July 14, 2005 [quote name='mrkickass']Can you disable the drl from under the hood? Does anybody have any pics where wires are at?[/QUOTE] Y? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
bmorrisj Posted July 15, 2005 Share Posted July 15, 2005 i did mine today, along with the foglight rewire.... [IMG]http://img.photobucket.com/albums/v34/bmorrisj/fogsnodrl.jpg[/IMG] Link to comment Share on other sites More sharing options...
mwiener2 Posted July 15, 2005 Share Posted July 15, 2005 I'll tell you something not to do.... I had done some work and wanted to make sure everythign was working fine when I was done. Fogs came on with parking lights, and with headlights. Then like 5 min later, I went to show a buddy, and the fogs wouldn't come on. Long story short, I took apart the whole car and checked everything with a meter only to figure out the high beams were on. Duh. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
rao Posted June 2, 2009 Author Share Posted June 2, 2009 Back from the dead Another DRL disable performed today in under a minute. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Guest Posted June 2, 2009 Share Posted June 2, 2009 That's awesome to know! Link to comment Share on other sites More sharing options...
ehsnils Posted June 3, 2009 Share Posted June 3, 2009 I agree There was a picture of the relevant connector here: That link is now invalid. It goes to some domain squatter... Link to comment Share on other sites More sharing options...
rao Posted June 3, 2009 Author Share Posted June 3, 2009 legacygt.com must not have kept up with its domain name payments Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
rock2534 Posted June 3, 2009 Share Posted June 3, 2009 So which connector is it?? I wouldn't mind turning that off myself. Link to comment Share on other sites More sharing options...
rao Posted June 3, 2009 Author Share Posted June 3, 2009 It is the white one. There is a box that has a white and a black or grey connector attached at the back left of the footwell. reach up under there and you will see it. You want to disconnect the white connector. For the lazy - here is another thread about it http://legacygt.com/forums/showthread.php?t=2117&highlight=drl that has pics. The original point of this thread was that you do no need to remove the lower panel. This is for 05 and 06 models only. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Bbc84 Posted June 4, 2009 Share Posted June 4, 2009 booo not for the 08? I want something this easy for independent fog lights. Link to comment Share on other sites More sharing options...
jedraz Posted June 4, 2009 Share Posted June 4, 2009 The DRL link above also works for the 08 or 09, I used it for my 09. Link to comment Share on other sites More sharing options...
