Reload this Page Project Spec.B #163
Page 1 of 16 1 2311 > Last »
#1: 07-20-2012, 02:29 PM
Project Spec.B #163
 .:Catalyst:.
.:Catalyst:.'s Avatar
Title: AllWheelsDriven
Car: 2006 spec.B #163 stage.2 .:CryoTuned:.
Send a private message to .:Catalyst:. Find all posts by .:Catalyst:. Reply With Quote
August 2011, #163 came home with me with just over 60K on the odometer, bone stock besides tint and red painted calipers.
At 77K (right after going stage 1), the VF40 showed signs of failure were imminent with bearing noise and it was replaced under warranty.
Stage 2 hardware was installed at 80K - Finished up the Infamous e-tune at 82.5K. Pulls well and smooth power delivery. Of course now I'm hungry for more!
Installed the PW TMIC and doing a tune with Cryotune Performance for Stage 2 + PW at 86.5K. Updated the engine bay at the same time for a different theme overall.
87K - Cryotune Stage2+ is complete. Really pleased with the tune's drivability and performance! Will be working with him for the "next stage"!
For the 90K service, installed Gates blue racing kevlar accessory belts and tensioner pulley, OEM NGK plugs, Extra-S/LW Shockproof for tranny/diff, oil change with good old Rotella T6 5W-40 and a new engine under cover as well as a Grimmspeed LWCP.
At 93K installed Stoptech slotted rotors, street performance pads, and SS lines with ATE Super Blue fluid. BBK is overkill for my DD at this point and this stage of a brake upgrade really fit the bill.
Clutch upgraded at 96K. ClutchMasters FX350, OEM SMFW, TSK3, along with Group N Transmission Mount and Crossmember Bushings completed the upgrade. Break in is complete and this is an amazing setup! OEM pedal feel with great holding capabilities and super smooth shifts. Engagement is about 1/4 of the stroke off the floor and totally predictable. Doing the trans mount and crossmember bushings was the right choice - much less drivetrain slop during shifts and the SMFW paired with my Grimmspeed LWCP makes rev matching a breeze.
Currrent Mods and some pictures:
ENGINE BAY & EXHAUST
Process West TMIC
Forge Stealth BPV
DeatschWerks 65c Fuel Pump
TurboXS Down Pipe (Catted)
Grimmspeed Up Pipe
Grimmspeed LW Crank Pulley
Grimmspeed Turbo Heat Shield (Lined w/ DEI ReflectAGold)
Grimmspeed 3-Port EBCS
Grimmspeed Oil Cap
Grimmspeed 3" > 2.5" Exhaust Adapter
Grimmspeed Gaskets throughout
AVO Panel Filter
PTP Turbo Blanket
Gates Racing Blue Accessory Belts and Pulley
Kartboy Exhaust Hangers
Subtle Solutions Brushed Aluminum Alternator & Radiator Shrouds
Subaru JDM Battery & Reservoir Covers
RTG Engineering "spec.B" Battery tie-down strap
Redline Tuning QuickLIFT Plus Hood Struts
Prodrive Radiator cap emblems
TUNING
Tactrix OpenPort 2.0
CryoTune Performance - Stage2+ E-Tune
DRIVELINE
ClutchMasters FX350 Clutch
Subaru OEM SMFW
TSK3 Kit
Subaru STi 5MT Short Shift Kit
Kartboy 5MT SS Lever
Group N 5MT Transmission Mount
Group N Transmission Crossmember Bushings
SUSPENSION & BRAKES
spec.B Bilstein Struts
Swift Sport Springs
Hotchkis F/R Swaybars (PC Speedway Black)
Kartboy Solid Endlinks F/R
AVO RSB Reinforcement Brackets (PC Speedway Black)
Whiteline Front Inner LCA Bushings
Whiteline LCA AntiDive/Caster Kit
Whiteline Roll Center & Bump Steer Kit
Whiteline Rear Camber Kit
Whiteline Steering Rack Bushing Kit
Grimmspeed Master Cylinder Brace
Stoptech Power Slot Rotors
Stoptech Street Performance Pads
Stoptech SS Braided Lines
WHEELS & TIRES
Ray's VOLK CE28N 17x7.5 +43 Custom Powdercoated "Speedway Black"
Ray's Limited Carbon Black GT High Style Center Caps
Ray's Black Aluminum Valve Stems and Caps
Ray's Black DuraluminTuner Lugs Black 35mm 12x1.25
Hankook Ventus v12 Evo K110 225/45R17
OEM Subaru 17" LGT option with Blizzaks in 215/45R17 for winter
Gorilla Black 12x1.25 Spline Lugs for OEM wheels
EXTERIOR
Custom JDM S402 Style Honeycomb grill w/ 08 Badge from nospmoht04
Central Composites CF Front Lip Spoiler (2 - 1 Plastidipped for winter)
Central Composites CF Rear Deck Lip
R-REV CF Mirror Covers
R-REV CF Fog Light Housings
R-REV CF Eyelids
Stanza CF Hood Scoop
Grimmspeed License Plate Relocator
Grimmspeed LP Delete
Hella Horns Silver PC'd cage
Subaru OEM Splash Guards
Subaru JDM One Piece Rain Visors
Subaru OEM Cleared/Painted Headlights
TRS Morimoto 3Five RetroQuik 5000K Bi-Xenon HID Kit
Diode Dynamics Stage 2 Switchback Turn Signals, Yellow LED Fogs, and License Plate LEDs
Sylvania 921 Silverstar Reverse lights
PIAA Forza Hybrid Silicone Wiper Blades
Doc Designs Custom Vinyl Overlays & Decals
Debadged
Windows tinted 30%
Vanity Plates "SPEC-B"
INTERIOR
WC Lathe Werks Hybrid Black Copolymer/Burnt Gunmetal Piston Shift Knob
Redline Goods Perforated Black Nappa w/ Carbon Fiber Stripe Shift boot, E-brake Boot, and Armrest Cover
Subtle Solutions Brushed Aluminum Dead Pedal
Subaru JDM Dual Console Box
Subaru OEM Winter Mats
Diode Dynamics Stage 2 Interior LEDs
Diode Dynamics CF cup holder inserts w/ Subaru Logo
Escort 8500 X50 detector w/ Blendmount
Upcoming mods will include:
CBE
Grimmspeed DP (not yet released)
VBG1 w/ PLX AFR Sending Unit
DW 850cc Injectors
Turbo
e85 & 92OCT Stage3 CryoTune
Bilstein HD Shocks
Samco Silicone hoses
First Week
After suspension work and some exterior mods
Volk CE28Ns and Stoptech Sport Kit
Rear Lip
Stance
Engine Bay
Interior
spec.B #163 Build Thread with Pictures
Get CryoTuned!
LGT.com 2006 spec.B Registry Mapped
The Following 2 Users Say Thank You to .:Catalyst:. For This Useful Post:
loogie (09-17-2012), tmb1956 (07-21-2012)
.:Catalyst:.
Find More Posts by .:Catalyst:.
#2: 07-20-2012, 02:30 PM
 .:Catalyst:.
Reserved for new pictures...
Last edited by .:Catalyst:.; 03-28-2013 at 10:07 AM.. Reason: Upcoming Spring Pictures
.:Catalyst:.
#3: 07-20-2012, 02:57 PM
 mattg
mattg's Avatar
Title: Brass Monkey
Car: '05 Limited 5MT Stg 3+
Send a private message to mattg Find all posts by mattg Reply With Quote
You've been busy! Do you have the rear lip on yet? I need to shoot some pics of the B.
mattg
Find More Posts by mattg
#4: 07-20-2012, 03:42 PM
 legacy
legacy's Avatar
Title: LegacSti
Car: 05 LGT (Legacsti) & 06 Imprezza 2.5i
Send a private message to legacy Find all posts by legacy Reply With Quote
Nice car. Do you still have the stock Spec B rims? If so I'm interested? I would like to see some rear pics, as well as interior pics.
The Following User Says Thank You to legacy For This Useful Post:
.:Catalyst:. (07-20-2012)
legacy
Find More Posts by legacy
#5: 07-20-2012, 03:45 PM
 .:Catalyst:.
Yes the trunk lip is on and Central Composites is redoing the front lip and going to prototype some skirts too!
We definitely need to do a shoot so ican advance away from iPhone pictures.
.:Catalyst:.
#6: 07-20-2012, 03:49 PM
 .:Catalyst:.
I do have the spec.B wheels, and think I'm keeping them. Considering powder coating and running them for winters unless I can find someone with clean LGT stockers in 17".
If mattg and I get together soon we will do a proper shoot inclusive of those areas. I do have some rear shots I'll add when I get to a computer.
.:Catalyst:.
#7: 07-20-2012, 03:53 PM
 legacy
legacy's Avatar
Title: LegacSti
I hate when there isn't a computer around lol. I would be willing to trade you my stock 17's for your Spec B rims. what do you think? Do you just want to do rims or rims and tires? My tires are stock size and are Nitto Neo gens with plenty of tread as my leggy isn't my Daily. i Think I have like a 7 or 8 on the tread life still.
legacy
#8: 07-20-2012, 04:00 PM
 mattg
mattg's Avatar
Title: Brass Monkey
Skirt lips? They were going to do full rockers in dry CF for me but I didn't end up pursuing it. I would be in on the lips though.
mattg
#9: 07-20-2012, 10:26 PM
 SubyDude555
SubyDude555's Avatar
Car: 07 Spec Bad Ass! 380HP 351TQ 20G XT EWG
Send a private message to SubyDude555 Find all posts by SubyDude555 Reply With Quote
Lookin good man and nice list of mods! I see another Spec Bad Ass in the making here!
The Following User Says Thank You to SubyDude555 For This Useful Post:
.:Catalyst:. (07-21-2012)
SubyDude555
Find More Posts by SubyDude555
#10: 07-20-2012, 11:26 PM
 Sicotic
Sicotic's Avatar
Car: 06' LGT Stage 3.5 20g Infamous Tuned
Send a private message to Sicotic Find all posts by Sicotic Reply With Quote
looks good!
The Following User Says Thank You to Sicotic For This Useful Post:
Sicotic
Find More Posts by Sicotic
#11: 07-20-2012, 11:32 PM
 blongo804
blongo804's Avatar
Car: 05 Kinugawa TD06SL2/18g 5EAT
Send a private message to blongo804 Find all posts by blongo804 Reply With Quote
I'm liking it! Will continue to stalk as pics come
The Following User Says Thank You to blongo804 For This Useful Post:
blongo804
Find More Posts by blongo804
#12: 07-21-2012, 11:09 PM
 .:Catalyst:.
Yes precisely! I told Marcus you might want to jump in - he did say you guys discussed before. We are taking some measurements Monday
.:Catalyst:.
#13: 07-21-2012, 11:15 PM
 legacy
legacy's Avatar
Title: LegacSti
Let me know what you think about my last post?
legacy
#14: 07-21-2012, 11:20 PM
 .:Catalyst:.
Definitely not tires since these will be dedicated winters. I'm still on the fence and may hold onto these or I may go with something other than the early LGT stockers as well. These will be winters but it's hard to not consider 04 STi BBS for winter duty to keep them light and a little better offset. I'll let you know if I do decide to part with them
.:Catalyst:.
#15: 07-21-2012, 11:23 PM
 legacy
legacy's Avatar
Title: LegacSti
No problem man I will wait and see what you decide.
legacy
