Reload this Page MY BNR 18G 09 Spec.B
Page 1 of 5 1 23 > Last »
#1: 10-13-2012, 08:49 AM
 jasejase
jasejase's Avatar
Car: '09 SpecB 18G BrenTuned 347whp, '05 2.5i
Send a private message to jasejase Find all posts by jasejase Reply With Quote
I had another thread with FULL details on the journey to get my tunes ironed out, but it got muddled with several dyno plots, and my buddies similiar build. If you're interested in that - here's the link: http://legacygt.com/forums/showthrea...ew-180932.html
This thread will serve as the clean version of my original thread. Unfortunately, I don't have a ton of pics that are worthy, but I will brush the dust off the DSLR one day and update the thread accordingly!
2009 Spec.B
Power Mods:
BNR 18g Turbo with Upgraded Actuator Arm and wastegate
IP&T Filtered Oil Lines
DW 750cc top feed injectors
DW 65c High Flow Fuel Pump
Perrin TM Intercooler
NGK Iridium One Step Colder Plugs
Perrin turbo inlet hose
KsTech Cold Air Intake
Grimmspeed Boost Control Solenoid
TurboSmart Kompact Blow Off Valve
Bren Dyno Tune via Cobb Accesport
SPT 1.5 Cat Back Exhaust
Cobb high flow catted down pipe
Cobb Heatshield
Tranny / Suspension / Handling Mods:
SPT 6MT short throw shifter
Kartboy Shifter Bushings
Whiteline front adjustable sway bar
Whiteline rear adjustable sway bar
KartBoy Solid front & rear endlinks
AVO rear reinforcements
JDM STi Pinks on Bilsteins
3/8" rear suspension spacers (for perfect rake)
Grimmspeed MCB
Conti DWS on Motegi MR118 wheels (Winter Setup)
Oem Wheels and Summer tires (tires to be replaced next year!)
Non Performance Mods:
Hella Super Tones
Custom 'JDM Style' grille (and lower grille)
WC LatheWerks SI drive dial cover
OEM Ipod Integration kit
SPT Billet oil fil cap
SPT Billet battery tie down
NAV in motion hack
Stanza rear trunk spoiler/lip
DashDaq gauge cluster/carputer
Escort Passport 9500ix hardwire
Subtle radiator and alternator shrouds (stainless)
Power:
347 WHP, 376 WTQ via BrenTuning dyno tune, followed by a road tune for brush-ups. 19.5 psi boost.
To Do List:
Not much... When my brakes go, I will replace the pads with either StopTech or HPS. The rotors will likely be replaced with OEM or Concentric. I will most likely add some stainless lines at that point as well. No BBK in my future. Once the clutch goes, we'll start to look at those options as well! I also have some rear diff bushings to put in from TurninConcepts one of these days.
Misc:
Thanks to AZP Installs in NJ who played a huge part in my turbo install, taking time on a saturday to make it happen. Doing this in my garage just wasnt going to happen this year.
The car feels great. BrenTuning worked some magic and gave me the precise feel and driveability I was looking for, while still maintaining a conservative boost target and AFR. He really dives deep into the tables to make things work! It's a bigger turbo, so it took me a while to get used to it, and learn to drive it differently. However, once you figure things out, the 18g really comes alive! There is some obvious lag, but the hit makes it all worthwhile.
If i had to do it over again... Perhaps i would have went with a PW TMIC to gain some additional cooling surface.
Pics to follow....
jasejase
Find More Posts by jasejase
#2: 10-13-2012, 09:48 AM
 jasejase
jasejase's Avatar
A few off the phone.... Many of these are before suspension mods.
Name:	lowered small.jpg
Name:	grille small.jpg
jasejase
#3: 10-13-2012, 09:49 AM
 jasejase
jasejase's Avatar
The actual initial base line was 299.... for some reason, we didnt get that print out... but here's the final dyno/tune numbers.
Name:	specb dyno tune bren.jpg
jasejase
#4: 10-13-2012, 10:29 AM
 Haight 05LGT
Haight 05LGT's Avatar
Car: 05 ABP LGT Stg Totaled
Send a private message to Haight 05LGT Find all posts by Haight 05LGT Reply With Quote
Sweet Bee.
The Following User Says Thank You to Haight 05LGT For This Useful Post:
jasejase (10-13-2012)
Haight 05LGT
Find More Posts by Haight 05LGT
#5: 10-13-2012, 01:02 PM
 cryo
cryo's Avatar
Title: Vendor II
Car: 06 spec.b CornfedHTA68 CryoTuned
Send a private message to cryo Find all posts by cryo Reply With Quote
Subscribed.
Beautiful car and tastefully modded.
Congrats
Dave
CryoTune Performance Stage 1,2 & 3 E-Tuning and Tuning FAQ Click Here For Details
www.CryotunePerformance.com
www.CryotunePerformance@yahoo.com
cryo
Find More Posts by cryo
#6: 10-13-2012, 01:12 PM
 LosAngelesLGT
LosAngelesLGT's Avatar
Car: 05 LGT 5mt 371hp on 91oct & 06 OBXT Stg1
Send a private message to LosAngelesLGT Find all posts by LosAngelesLGT Reply With Quote
Love it
LosAngelesLGT
Find More Posts by LosAngelesLGT
#7: 10-13-2012, 02:39 PM
 Nrw
Nrw's Avatar
Car: 05 LGT BrenTuned
Send a private message to Nrw Find all posts by Nrw Reply With Quote
I've seen this car
Nrw
Find More Posts by Nrw
#8: 10-13-2012, 03:33 PM
 jasejase
jasejase's Avatar
Thanks guys!
Nrw: and....? Lol
Buy your custom Subaru baby onesies and custom Subie printed items here: http://legacygt.com/forums/showthrea...es-197958.html
Build: http://legacygt.com/forums/showthrea...-b-194664.html
jasejase
#9: 10-13-2012, 09:34 PM
 Nrw
Nrw's Avatar
I've taken videos and some pictures of it too.
Might have touched it too
Nrw
#10: 10-14-2012, 07:07 AM
 jasejase
jasejase's Avatar
We still talking bout my car here?
jasejase
#11: 10-14-2012, 07:46 AM
 Nrw
Nrw's Avatar
yes, you weren't looking when I touched it :quagmire:
The Following User Says Thank You to Nrw For This Useful Post:
jasejase (10-14-2012)
Nrw
#12: 10-14-2012, 08:04 AM
 Nrw
Nrw's Avatar
So you pic thread actually has some pics...
The Following 2 Users Say Thank You to Nrw For This Useful Post:
jasejase (10-14-2012), LosAngelesLGT (10-14-2012)
Nrw
#13: 10-14-2012, 08:47 AM
 PeterJMC
PeterJMC's Avatar
Title: Lvl 63 Night Elf Dwarf Paladin
Car: '10 Toyota Prius: Racecar Edition
Send a private message to PeterJMC Find all posts by PeterJMC Reply With Quote
Looks good!
'10 Prius: Racecar Edition
The Following User Says Thank You to PeterJMC For This Useful Post:
PeterJMC
Find More Posts by PeterJMC
#14: 10-14-2012, 09:51 AM
 Haight 05LGT
Fixed
Nrw (10-14-2012)
Haight 05LGT
#15: 10-14-2012, 11:23 AM
 mooshski
mooshski's Avatar
Title: Contributing V.P.
Car: 05' SWP LGT Brentuned
Send a private message to mooshski Find all posts by mooshski Reply With Quote
Beautiful.
mooshski
Find More Posts by mooshski
