Go Back   Subaru Legacy Forums > Technical Forums > Turbo Powertrains (2.0GT, 2.5GT, 2.5XT)
Reload this Page leaking valve cover question
#1: 03-21-2013, 08:32 AM
 Trail_Head
Trail_Head's Avatar
Car: 2005 legacy GT Ltd Wgn
Send a private message to Trail_Head Find all posts by Trail_Head Reply With Quote
Hi Gents,
I need to change my passenger side valve cover gaskets. I'm curious about the 2 hoses that attach to the top of the cover. One seems to be a coolant line and the other seems to be vacuum. Do I need to disconnect these to remove the cover?
Thanks much
Trail_Head
Find More Posts by Trail_Head
#2: 03-21-2013, 01:28 PM
 Max Capacity
Max Capacity's Avatar
Title: Gearhead
They are both breather lines.
Yes, they may be dry so be careful not to break them. May be a little PB Blaster sprayed on them will help
Here' the inside.
You'll need to replace the oem hose clamp.
Max Capacity
#3: 03-22-2013, 05:20 AM
 Trail_Head
Trail_Head's Avatar
Wow! Great reply! Thank you!
This job looks dead easy with the engine out. My biggest concern WAS getting the cover back on without screwing up the wet gasket sealant. If it seems too tight I'll just remove the engine mount nuts and hoist that side up.
Thanks again,
TC
Trail_Head
#4: 03-22-2013, 07:33 AM
 wurkenman
wurkenman's Avatar
Title: Contributing V.P.
Car: 05 LGT(mine), 07 Legacy 2.5I (wife's)
Send a private message to wurkenman Find all posts by wurkenman Reply With Quote
Put them on a dry clean surface, no sealant, not needed.
If you woke up today, you have another chance to do it right.
I have the typing ability of a epileptic in a strobe lit room typing with boxing gloves.
wurkenman
Find More Posts by wurkenman
#5: 03-22-2013, 07:10 PM
 Subakook
Car: 06 OBXT II F1-5eat
Send a private message to Subakook Find all posts by Subakook Reply With Quote
You will need some RTV ultragrey or fujibond for this on the GT. Look up the vacation pics.
Subakook
Find More Posts by Subakook
#6: 03-27-2013, 05:18 AM
 2slo4me
2slo4me's Avatar
Car: 2005 legacy gt limited wagon
Send a private message to 2slo4me Find all posts by 2slo4me Reply With Quote
I just did mine and I only used silicone to hold the gasket in place while installing... other then that you dont really need it...
2slo4me
Find More Posts by 2slo4me
#7: 03-27-2013, 02:04 PM
 ctlex
ctlex's Avatar
Car: 06 lgt
Send a private message to ctlex Find all posts by ctlex Reply With Quote
this is the truth. rtv should only be used a little between the rubber gasket and the valve cover to hold it in place while positioning the valve cover back on the engine.
ctlex
Find More Posts by ctlex
#8: 03-27-2013, 04:36 PM
 wurkenman
wurkenman's Avatar
My bad. I did mine with the engine out.
wurkenman
