Reload this Page A few spec b questions
#1: 05-20-2013, 01:09 AM
 UTwrestler22
UTwrestler22's Avatar
Car: Stage 2 05 OBP LGT sedan
Send a private message to UTwrestler22 Find all posts by UTwrestler22 Reply With Quote
I'm in the process of buying an 07 spec b. with a few quick questions.
1. Are the stock Bilsteins height adjustable? Or adjustable at all?
2. Is the stock UP catted?
3. Is it possible to swap the black/blue interior with the red leather interior?
4. What is peak boost/max torque for the vf-46 to be pushing? Both semi-safely and harshly?
5. What horsepower/torque is the shortblock/transmision good for? Is the 6 speed stronger than the 5?
UTwrestler22
Find More Posts by UTwrestler22
#2: 05-20-2013, 05:23 AM
 Max Capacity
Max Capacity's Avatar
Title: Gearhead
1. no
2. no
3.yes, all it takes is money.
4. ?
5. ?
Max Capacity
#3: 05-20-2013, 05:27 AM
 Dbl_D718
Dbl_D718's Avatar
Car: 2007 spec.B
Send a private message to Dbl_D718 Find all posts by Dbl_D718 Reply With Quote
4. ∞
5. ∞
Becuz spec.B?
MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII
The Following User Says Thank You to Dbl_D718 For This Useful Post:
Nrw (05-21-2013)
Dbl_D718
Find More Posts by Dbl_D718
#4: 05-20-2013, 06:42 AM
 iNVAR
iNVAR's Avatar
Title: Nerd^2
Car: 05 LGT 5MT Stg2 custom
Send a private message to iNVAR Find all posts by iNVAR Reply With Quote
You know, all of those questions could be answered with just a teeny tiny bit of searching. You've been here long enough to know that. And not only that but you'd gain a wealth of knowledge for sifting through some of the posts.
Whatever you do, don't start your car without the TMIC installed. Or turn the crank backwards, etc. etc.
4) Depends on tune.
5) It's the same engine as yours and mine. Do some reading!
Transmission: do some more reading/searching! http://legacygt.com/forums/showthrea...se-123635.html
The Following 5 Users Say Thank You to iNVAR For This Useful Post:
Code (05-20-2013), laff79 (05-22-2013), Nrw (05-21-2013), SCASEYS (05-20-2013), thefultonhow (Yesterday)
iNVAR
Find More Posts by iNVAR
#5: 05-21-2013, 11:13 AM
 UTwrestler22
You should put that as your signature. It'd be easier considering you say the exact same thing every chance you get. Find something else to hit me with.
Thanks for the quick answers everyone
UTwrestler22
#6: 05-21-2013, 12:17 PM
 Max Capacity
Title: Gearhead
Hye, iNVAR, may be hit him with something like, Check your oil level, these car use it.
Sorry, it's hard to keep us trolls at bay sometimes.
The Following User Says Thank You to Max Capacity For This Useful Post:
laff79 (05-22-2013)
Max Capacity
#7: 05-21-2013, 12:45 PM
 UTwrestler22
Oh and ive done a lot of searching simply trying to find the peak boost for the vf-46 but all ive found is info on the five arc design.
UTwrestler22
#8: 05-21-2013, 01:17 PM
 Max Capacity
Title: Gearhead
Shouldn't there be a compressor map somewhere for it ?
Don't those show optimum boost levels ?
Max Capacity
#9: 05-21-2013, 01:23 PM
 boostedgrocerygetter
boostedgrocerygetter's Avatar
Car: Facebook. BGG Sway Bar Brackets
Send a private message to boostedgrocerygetter Find all posts by boostedgrocerygetter Reply With Quote
Regardless why would you wanna push the turbo to its max boost levels. It's far safer to go with a bigger turbo. Last thing you wanna do is feed your motor that turbo.
As far as the trans what are your goals for the car. Are you planning on a lot of power (being as you asking for the 46 boost limits I doubt it) or are you looking to launch the car.
Find More Posts by boostedgrocerygetter
#10: 05-21-2013, 02:57 PM
 iNVAR
iNVAR's Avatar
Title: Nerd^2
I hit you with that all the time because those are the most memorable things you've posted about so far. I don't need to hit you with something else because what I consider what I'm hitting you with a pretty big hammer already.
You're welcome, for doing the searching for you re: transmission since you still seem incapable of searching for yourself.
As I said, peak boost depends on the tune. You shouldn't be asking what peak boost/torque is though. You should be asking what the ideal amount of boost to target at what RPM and tapering to what boost at redline would be and with how much timing, etc. etc.
And the answer to that is: almost the same as a VF40 with some slight improvement down low and mid-range. You can make a VF40 push a bit more boost out down low.... but it's not a good idea to go much farther than what's been established.
iNVAR
#11: 05-21-2013, 03:14 PM
 UTwrestler22
I'd like to have it to 300 horse on stock turbo/fueling. I've just heard the simple answer for the vf-40 of about 250 wtq and like 19 psi is leaving the safe range. It seems that the vf-46 is a little more complex.
And invar, did i give you a reason to hit me with that? (Even considering i didnt do damage to the car from that and a cobb tech told me it would be fine considering i ran it for a minute til it died, but you've heard that arguement before)
@ maxcapacity, i searched for a while, couldn't find any details.
UTwrestler22
#12: 05-21-2013, 03:35 PM
 iNVAR
iNVAR's Avatar
Title: Nerd^2
300whp is most likely not going to happen.
http://legacygt.com/forums/showthrea...hpi-93974.html
You sort of deserve it from that other thread regarding BOVs and trying to give that other noob (yes, you are still a noob) crap. Noobs don't get to give other noobs crap, especially after your own thread. Don't forget that the post I'm referring to has you yelling at the guy to SEARCH. See the irony yet?
iNVAR
#13: 05-21-2013, 03:44 PM
 Nrw
Nrw's Avatar
Car: 05 LGT BrenTuned
Send a private message to Nrw Find all posts by Nrw Reply With Quote
I don't think IHI releases any compressor maps.
Nrw
Find More Posts by Nrw
#14: 05-21-2013, 06:36 PM
 Drew888
Drew888's Avatar
Car: 2008 Spec-B, Infamous Tuned!!!
Send a private message to Drew888 Find all posts by Drew888 Reply With Quote
Except for general curiosity it won't mean much. You are not turning up boost unless you are self-tuning and if you’re not tuning well... this will get real interesting soon enough.
I suspect you'll just get it tuned by a competent tuner and he'll just tell you all that and more about your car.
VbGallery
Drew888
Find More Posts by Drew888
#15: 05-21-2013, 07:58 PM
 jfg22557
jfg22557's Avatar
Car: 68HTA+EWG+Meth= :0
Send a private message to jfg22557 Find all posts by jfg22557 Reply With Quote
^ I lol'd a bit
300whp from a VF46, I highly doubt thats possible even on a dynojet, let alone something with an accurate multiplier(s) (ie. a mustang or dynapack).
Whats with the obsession over numbers these days anyway? Are you looking to compensate for something?
Seems like every other thread I read is about someone looking to get some outlandish results from the stock turbo and fueling. Just for reference, the conservative tune I've been running for the past 60k on my 68HTA is right at 21psi peak, 305/335. And the car's fueling system (and everything else for that matter) is far from stock.
EDIT: ^ on a mustang dyno
The Following 2 Users Say Thank You to jfg22557 For This Useful Post:
iNVAR (Today), thefultonhow (Yesterday)
jfg22557
Find More Posts by jfg22557
