Go Back   Subaru Legacy Forums > Technical Forums > Suspension/Brakes
Reload this Page Brake Caliper rotation play
#1: 03-25-2013, 10:38 PM
 triple_B
triple_B's Avatar
Car: 07 Wgn at Infamus Borla Ralitk Koni Rota
Send a private message to triple_B Find all posts by triple_B Reply With Quote
Hey all,
in the below links you will find videos showing the rotational movement of my front drivers side stock caliper. I compressed the caliper cyclinders and put in old pads to create space to show extreme rotation.
with good pads and compressed cyclinder the caliper will still rotate a bit.
I am getting quite a bit of wobble and steering wheel gerk when on the track. the wobble worsens as a session progresse, as if heat buildup makes it worse.
any ideas? has the caliber warped/ stretched after two years of hard lapping days? or are the guide pins toast?
I use Cryo rotors and hawk DTC-70 pads. im a really late hard braker. my pads last a long time and ive never boiled fluid.
rotors get hot though. after a 20 min track session and a one lap cool down of 4 minutes the rotors can be 800*.
thanks for any info
2007 Legacy GT front caliper guide pin rotation top/inside - YouTube
2007 Legacy GT front caliper guide pin move and rotation - YouTube
triple_B
Find More Posts by triple_B
#2: 03-25-2013, 11:43 PM
 jamal
jamal's Avatar
Car: 98 2.5GT
Send a private message to jamal Find all posts by jamal Reply With Quote
good thing the caliper only squeezes the pad. The bracket is what holds them in place.
I would consider new pins but it looks fine to me.
jamal
Visit jamal's homepage!
Find More Posts by jamal
#3: 03-25-2013, 11:52 PM
 triple_B
triple_B's Avatar
true it does squeeze but when caliper squeezes pads I was curious if/how it could be jolted around and create vibration...which I am feeling.
I change pads dozens of time a year (track pads) and over the last 20 years and I cant seem to recall that much play...but than again I cant recall being concerned.
just curious if other recall such play (lol).
triple_B
