02-27-2013, 02:22 PM
Can someone check my logs out??
I logged becasue at certain places the rpm drops for a second then continues. It either happens around 3000 rpm or 5000 rpm
2005 Legacy GT 5eat Cobb Stage 2 91oct
02-27-2013, 06:54 PM
anyone??
02-28-2013, 06:18 AM
Title: Banned
you have a decent amount of knock in the higher rpms at wot. beeee carefullllllllll. maybe you're leaning out, fuel pump okay? having a wideband would help out a lot right now...
02-28-2013, 08:34 AM
the first two logs i have are the wrong ones...the third is one of the 3 full logs i did.
I was wondering why the at some spots the rpm climbs than goes down then climbs again. If I watch the tach its like it gets stuck on 3,000 rpm or 5,000 rpm.
So ditch the V1 accessport and get a tune?
02-28-2013, 08:39 AM
Title: Banned
it's because you're knocking so much that ignition timing starts to decrease. ignition timing should go up as rpm goes up in order for the flame front to stay before TDC. typically the lowest ignition timing will occur either during an auto shift or at the point of full torque. in a 3rd gear pull you'll see engine load value increase and ignition timing will drop, as the rpms go up the timing should go up. in your case, timing is starting the fall because the ecu is pulling timing as rpms go up, concurrently. it keeps knocking as the timing want to go up, as it does that the total timing goes down. it also matters how the tables are setup in the tune, but, in general whether tuned or not, timing should go up as you accel.
02-28-2013, 10:17 AM
Ahhh i think i understand (my first time logging)
At 5660 RPM the ecu detected FKC and pulled timing from 19.5 to 18. The RPM went down to 5650 and then continued.
02-28-2013, 10:26 AM
Car: 2007 Subaru Legacy Spec B (DSM)
Can you post a LV? Also if they are saying you are leaning out... check that vacuum hose i mentioned.
02-28-2013, 10:38 AM
i checked that vacuum hose that goes to the regulator on the driver side of the engine bay where the fuel comes in, and it was good. The T connector is good as well. The JB weld job I did on my intercooler started to crack so right now I have my intercooler with more JB weld sitting next to me.
02-28-2013, 11:09 AM
would an exhuast leak post turbo casue a lean condition?
02-28-2013, 11:12 AM
Title: Banned
post turbo intercooler and manifold leaks will cause richness on boost and lean on vacuum. post turbo exhaust leaks should cause too much a/f change but check the learning view trims to be sure. if the D range is significantly negative then you're running learner than intended.
The Following User Says Thank You to Indiglow For This Useful Post:
03-01-2013, 12:36 PM
I have stock one still if you are interested I could bring it back after break.
03-01-2013, 01:03 PM
well it as jsut starting to pull the tabs after my first light jb weld job, i will see how this holds up first.
I wouldnt mind having you ride along to help data log. I am new to it and have not learned it all yet
03-02-2013, 05:12 PM
with it being so lean up top, could a bad injector cause this? I just got a CEL p0301 and the coil on that cylinder is only a few thousand miles old. The car idles kinda shaky as well
03-02-2013, 08:53 PM
Title: Banned
Vac leak
03-02-2013, 09:47 PM
Title: Nerd^2
Car: 05 LGT 5MT Stg2 custom
No, that is not what happened. It's just an artifact of RR's fast polling feature.
http://legacygt.com/forums/showthrea...html?p=3520285
