Go Back   Subaru Legacy Forums > Walkthroughs > Walkthroughs :: Performance Modifications
Reload this Page Kartboy rear shifter bushing
#1: 05-28-2005, 12:32 AM
 bemani
Car: 05 LGTltd/02 WRX
Send a private message to bemani Find all posts by bemani Reply With Quote
Pretty simple install, much more room to work with on the LGT than the 02 WRX. However, there are 2 more steps than what needs to be done for the WRX.
First of all, leave the car in neutral, and get under the car using whichever way you prefer.
As you can see, the driveshaft is blocked by a heatshield, which has the O2 sensor passing through it. Shifter is above the driveshaft. So, first loosen the O2 sensor, then unbolt 4 bolts that hold onto the heatshield. You'll have to wiggle the loosen HS to get it out of the car.
Then remove the bolt and metal plate that you undo when you do the front bushings.
Pull the linkage toward the driver side to loosen it. Then, as I try to show in the following picture, use something long as a lever. I used a pipe. Use the bracket pointed to by the blue arrow as the fulcrum and pull the linkage toward the front of the car (direction of red arrow).
Very easy to pull the linkage out of the stock rear shifter bushing this way. And a lot of room to work with.
Now that the linkage is out, you can unbolt the 2 bolts and get the stock bushing out. Grease up the Kartboy one real good, and slip back on the linkage. The way it looks in the picture is the right side up. Yes I put too much grease on, I expected it to be real tough to get on like the WRX but it wasn't the case at all.
Then just bolt it back up to the chassis. Use the bolts supplied by KB. Note that those are 13mm, but the stock ones are 12mm.
Done. Put everything back in reverse order. Don't over-torque the bolt on the front bushing.
bemani
Find More Posts by bemani
#2: 05-30-2005, 11:43 AM
 Avishar
Avishar's Avatar
Car: Tricycle
Send a private message to Avishar Find all posts by Avishar Reply With Quote
review? thoughts? nice writeup!
Avishar
Find More Posts by Avishar
#3: 10-17-2005, 04:53 PM
 mwiener2
mwiener2's Avatar
Title: Trunk Monkey Chief
Send a private message to mwiener2 Find all posts by mwiener2 Reply With Quote
+1
My Mods List
(Updated 2/7/13)
2005 Outback FMT
Spec Yaris
mwiener2
Find More Posts by mwiener2
#4: 10-17-2005, 06:25 PM
 LivNLegacy
LivNLegacy's Avatar
Title: Original Member
Car: former: 02 bugeye, 05 LGT, 06 WRX Wagon
Send a private message to LivNLegacy Find all posts by LivNLegacy Reply With Quote
nice....thanks...i just scored a new KB SS on ebay cheap...need to find the bushings now, but this will mos def come in handy....thanks again
LivNLegacy
Find More Posts by LivNLegacy
#5: 10-18-2005, 05:38 AM
 TSi+WRX
TSi+WRX's Avatar
Title: Where'd that Pop-It go?!
Car: 13 Tribeca-me, 13 FXT Touring-wifey
Send a private message to TSi+WRX Find all posts by TSi+WRX Reply With Quote
Further tips:
To remove the O2 sensor, it is recommended to use a 22mm "Compact" offset O2 sensor "wrench" (it's really just a specialty socket for your drive ratchet). Usually had for $10 at any major automotive parts retailer. Good investment if you're a regular weekend wrencher.
Otherwise, a locking set of vise-grips can be used.
Also, unless you have Popye-sized forearms, you should be able to simply remove the heat-shield bolts, and move and/or bend-back the heatshield a slight bit and get your arm to where it needs to go.
Heat shield removal is optional, but you'll want to be sure that the exhaust piping is cool before you do this bushing mod, either with or without the shield!
<-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges
'13 ISM Tribeca, '13 FXT Touring, 5th Subaru Family
TSi+WRX
Find More Posts by TSi+WRX
#6: 10-26-2005, 05:57 PM
 Avishar
Avishar's Avatar
Car: Tricycle
but what does it dooooo?!
Avishar
#7: 10-27-2005, 06:01 AM
 TSi+WRX
TSi+WRX's Avatar
^ It takes up some of the slack and makes overall shift feel more direct and more positive. Once you compare how much the stock rubber bushings deflect versus these Kartboy ones, you'll understand immediately.
This in-turn translates to somewhat increased cabin NVH levels - primarily vibration through the stick.
The stick will retain its "notchy" feel, however.
TSi+WRX
#8: 10-29-2005, 01:09 PM
 mwiener2
mwiener2's Avatar
Very helpful hint --> Must tighten one bolt all the way before the other bolt will even thread. Took me 30 min to figure that out. I also didn't need any pipes or anything for leverage. I just popped out the linkage and pushed it back into the new one.
My Mods List
(Updated 2/7/13)
2005 Outback FMT
Spec Yaris
mwiener2
#9: 03-16-2008, 08:22 PM
 ultimakf7
ultimakf7's Avatar
Title: Old Dirty Buddha Balls
Car: '07 LGT 68HTA, '04 MSM 2860RS
Send a private message to ultimakf7 Find all posts by ultimakf7 Reply With Quote
DOH!!!!! are you freaking serious???
I spent 3 hours today tring to install the damned bushing thinking that the holes were too close together. I gave up soon after.. Boy, that was a boatload of fail, if you'd say so...
ultimakf7
Find More Posts by ultimakf7
#10: 03-16-2008, 08:24 PM
 ultimakf7
ultimakf7's Avatar
Oh man this is one hell of a old thread bump....
ultimakf7
#11: 03-23-2008, 04:16 AM
 Dr.Chu
Dr.Chu's Avatar
Title: Lost in Car Translation
Car: '13 Satin White Pearl ZC6 BRZ
Send a private message to Dr.Chu Find all posts by Dr.Chu Reply With Quote
Is it ok if we don't put the heatshield back?
For some reason it started to rattle after I put my catback on...
South Coast Subaru l Firestone of Rowland Heights l Yimi Sport l Koyorad
Dr.Chu
Find More Posts by Dr.Chu
#12: 11-07-2008, 03:55 PM
 jarrod
jarrod's Avatar
Car: 2011 Jeep Grand Cherokee Limited
Send a private message to jarrod Find all posts by jarrod Reply With Quote
old thread bump...rear shifter bushing is a major pita...i've got one bolt tightened all the way down and the other still won't thread
jarrod
Find More Posts by jarrod
#13: 11-07-2008, 04:03 PM
 ultimakf7
ultimakf7's Avatar
I still haven't tried again... it's still sitting somewhere in my garage, lol
ultimakf7
#14: 11-07-2008, 04:14 PM
 jarrod
jarrod's Avatar
all I can say is this damn thing better do something lol...i'd rather change spark plugs on this car
jarrod
#15: 11-07-2008, 05:12 PM
 jarrod
jarrod's Avatar
ok so I had to loosen the other bolt up then after fighting with it for about 30 mins the other one threaded...i'm done and time for a beer
jarrod
Similar Threads
Explanation of Continuous, Active and VTD AWD systems - an honest attempt Tophaholic Fourth Generation Legacy (2005 - 2009) 82 10-13-2012 02:47 PM
JDM Spat Sets; WAGON + SEDAN, $249.00 delivered Japanparts Group Buy Forum 154 09-08-2007 07:27 PM
FS Kartboy short throw shifter.. FoxHound Member Classifieds - ARCHIVE 25 08-10-2007 07:19 AM
Kartboy Shifter FoxHound Turbo Powertrains (2.0GT, 2.5GT, 2.5XT) 3 05-16-2007 02:17 PM
Kartboy shifter abakja1 Interior/Audio 2 05-12-2005 05:33 PM
