Go Back   Subaru Legacy Forums > Technical Forums > Naturally Aspirated Powertrains (2.5i, 3.0R)
Reload this Page Wider stance/suspension. im new!
#1: 04-17-2013, 06:29 PM
 BooneLegacyi
Car: NA 05 Legacy ltd.
Send a private message to BooneLegacyi Find all posts by BooneLegacyi Reply With Quote
Hey Im new! Real excited to see how my legacy turns out. You guys put so much effort and thought into these its so inspiring! I have the NA 05 Legacy ltd. I know its not a fast car so I won't bother so much on the performance side. Everything is stock but is like to get a wider stance. I know there are spacers out there as well as rims but I'm thinking maybe .5in wider on each side. Would you guys think its even worth it? What other options are there ?
Also thinking about springs. I'm not fond of the ridiculously harsh ride plus I live in the mountains so coilovers wouldn't really benefit me. I'm thinking some springs? Lower it .5in at most since I still need clears for steep roads.
Any info advice helps!
Thanks! Will
BooneLegacyi
Find More Posts by BooneLegacyi
#2: 04-17-2013, 06:56 PM
 Drift Motion
Drift Motion's Avatar
Car: RMS13 --> 05 Turbo Camry
you named it
either get spacers or wheels that are either wider and/or lower offset
Drift Motion
#3: 04-17-2013, 06:57 PM
 bucko3the7man
bucko3the7man's Avatar
Title: Yeah!! Traction bitch!
Car: 05 Legacy GT BrenTuned
Send a private message to bucko3the7man Find all posts by bucko3the7man Reply With Quote
Take Look at the epic engineering springs, they're a progressive spring and would lower just a bit
bucko3the7man
Find More Posts by bucko3the7man
#4: 04-18-2013, 02:45 PM
 rchayes21
rchayes21's Avatar
Car: 2008 2.5i LTD
Send a private message to rchayes21 Find all posts by rchayes21 Reply With Quote
I'm kind of like you, I also have a 2.5i. I wanted a tougher look. However I chose coilovers and no spacers with a high offset. And I love it, even though its not exactly "stanced". But it does sound like your roads are harsher than mine. My point is ; if you do springs (epic, eibach whatever). . Go ahead and save yourself the headache and buy Koni yellow struts. I've ridden in a LGT with that set up. It rode really well and handled every bump nicely. Barely any role when turning and a rare amount of sag under acceleration. I know it's more money. But if you just do stock shocks with aftermarket springs on, it won't take long before your struts are screwed. Now this is just if you do the spring/strut set up. Cause if it was me... I would still put coilovers on. Just IMO. Hope it helps and look forward to seeing pics
rchayes21
Find More Posts by rchayes21
#5: 04-18-2013, 03:29 PM
 bucko3the7man
I've got konis and epics on and I love them
The Following User Says Thank You to bucko3the7man For This Useful Post:
rchayes21 (04-18-2013)
bucko3the7man
#6: 04-18-2013, 06:42 PM
 rchayes21
rchayes21's Avatar
Car: 2008 2.5i LTD
^ see what I mean....I've never heard anyone say anything bad about that set up
rchayes21
#7: 04-18-2013, 07:34 PM
 bucko3the7man
It's the best dd setup according to s lot of people. Dujo Went from stock to isc coilovers to koni/epic and never looked back
bucko3the7man
#8: 04-18-2013, 07:50 PM
 rchayes21
rchayes21's Avatar
Car: 2008 2.5i LTD
^ couldn't have said it better.
rchayes21
#9: 04-18-2013, 08:49 PM
 GEE-OTTO
GEE-OTTO's Avatar
Title: GEE OTTO
Car: 2009 OBP Legacy 2.5i SE 5sp
Send a private message to GEE-OTTO Find all posts by GEE-OTTO Reply With Quote
KYB's + Htechs !!!
GEE-OTTO
Find More Posts by GEE-OTTO
#10: 04-18-2013, 09:07 PM
 careercadaver
careercadaver's Avatar
Car: 2005 SWP LGT 5MT
Send a private message to careercadaver Find all posts by careercadaver Reply With Quote
Originally Posted by GEE-OTTO View Post
KYB's + Htechs !!!
Yikes...only thing worse would be STechs... The Tein springs offer a nice stance but that's pretty much it... :/
careercadaver
Find More Posts by careercadaver
#11: 04-18-2013, 10:40 PM
 BooneLegacyi
Its definitely a dd on some harsh roads. I've been looking at the eibach pro series springs? Does anyone have these with the stock struts? I've heard keeping them stock keeps the ride barable? Ill post some stock pictures. Bought this car myself can't wait to make her look good!
BooneLegacyi
#12: 04-19-2013, 06:44 AM
 GEE-OTTO
GEE-OTTO's Avatar
Title: GEE OTTO
You silence your blasphemy
So ill give this setup a chance if its fails Koni + Htechs
GEE-OTTO
#13: 04-19-2013, 07:10 AM
 bucko3the7man
NRW is on koni/htech
bucko3the7man
#14: 04-19-2013, 12:16 PM
 careercadaver
Eibachs with stock struts would likely be fine. Know that lowering springs on stock struts decreases the overall life of the strut because you're taking the hydraulic out of its optimal range of motion. Though this would likely be pretty minimal with the goals you mentioned.
Not sure how new to this you are so bear with me if you knew this but an alignment will be necessary after any significant variance in height.
GL and post up some pics of whatever you land on! Before and after and your impressions would be beneficial to the site!
careercadaver
#15: 04-19-2013, 12:21 PM
 Billy Dagwood
Billy Dagwood's Avatar
Car: 2005 ABP LGT 5MT
Send a private message to Billy Dagwood Find all posts by Billy Dagwood Reply With Quote
Unless I'm mistaken (and I'm not), eibach = epic. Same springs, different branding.
Billy Dagwood
Find More Posts by Billy Dagwood
