Reload this Page AFR bouncing around. Normal?
#1: 06-03-2011, 04:52 PM
 jcole05
Car: 05' LGT Ltd, 6MT swap, Dom1.5xt-r 10cm
Send a private message to jcole05 Find all posts by jcole05 Reply With Quote
I have an AEM fuel gauge. Simple question: why does it constantly bump up and down when I am cruising. Pretty much in a rhythm it will go from ~13.8 to ~15.3....bounce up, bounce down, bounce up, bounce down about once a second or faster. Never sits at stoichiometric for even a blink.
Now, when I go WOT it quickly drops to 11-11.2 and stays there. Just wondering if this is normal behavior. Thanks.
jcole05
Find More Posts by jcole05
#2: 06-06-2011, 11:07 AM
 Boostin
Boostin's Avatar
Title: Back to Turbo
Car: 2004 Volvo S60R
Send a private message to Boostin Find all posts by Boostin Reply With Quote
It's not supposed to sit at stoichiometric. It's supposed to oscillate. It cycles rich to supply gases for the reduction catalyst (NOx) and lean to supply gases for the oxidation catalyst (HC, CO). In fact, if it didn't oscillate it would throw a code.
On the search for a new DD...
Boostin
Find More Posts by Boostin
#3: 06-06-2011, 06:44 PM
 jcole05
That's why forums like this are so helpful. Thanks so much for the simple and clear explanation.
jcole05
#4: 06-08-2011, 10:42 PM
 NSFW
NSFW's Avatar
Title: Stage Free
Car: 6mtblackturbowagon
Send a private message to NSFW Find all posts by NSFW Reply With Quote
Also, you can see it in a data logger with the "AF Correction #3" and "Closed loop target AFR" parameters.
NSFW
Find More Posts by NSFW
