Go Back   Subaru Legacy Forums > Walkthroughs > Walkthroughs :: Basic Operation & Maintenance
Reload this Page Fully independent fogs lights
Page 1 of 11 1 23 > Last »
#1: 04-04-2005, 03:27 PM
 Deer Killer
Deer Killer's Avatar
Title: 50% air
Car: 05 LGT
Send a private message to Deer Killer Find all posts by Deer Killer Reply With Quote
This mod will enable you to keep you fogs on with your high beams and use your fogs with your parking lights only. This walkthrough shows the wiring points only, not the dissassembly, or how to do your wiring. Standard disclaimer applies, you may break your car at your own risk.
1. First pic - overview, shows three locations you need to modify. From left to right: Blue connector from the mirror control/wiper heater assembly. Fog relay/relay assembly. Left stalk connector.
2. Second pic rear of relay assembly. With the relay assembly pulled out, cut the blue/white wire, secure the loose end from the car, and tap into the blue/white wire coming from the relay assembly.
3. Third/fourth pic. Find the violet wire on the blue connector, and attach your tap from step two here. Instead, you may also wire your tap into constant on or ACC, if you don't like your parking lights being on to have your fogs on.
4. Fifth pic. When looking the the front most part of the connector you will see a white/red and a black/black wire on the the same edge. Splice these two together, without severing either. (Careful, as there is another black/black on the other side which I did not check to see what it was)
ID:	5850   Click image for larger version
ID:	5851   Click image for larger version
ID:	5853   Click image for larger version
Deer Killer
Find More Posts by Deer Killer
#2: 04-04-2005, 03:58 PM
*Jedimaster*
Title: Guest
Posts: n/a
Thanks mang!
*Jedimaster*
#3: 04-04-2005, 11:45 PM
 John M
John M's Avatar
Car: Formerly 05 LGT w/ FP Green
Send a private message to John M Find all posts by John M Reply With Quote
What are 2 wires are you connecting together at the switch harness when you do the last part of the mod? (I assume one is the ground source)
Does the fog on/off switch still work after this?
Except for that step it's identical to the steps I've already posted.
John M
Visit John M's homepage!
Find More Posts by John M
#4: 04-04-2005, 11:50 PM
 Deer Killer
Title: 50% air
Car: 05 LGT
It's what's on the other pole of the fog switch, switched ground. Now body ground.
Yes, everything works.
Deer Killer
#5: 04-05-2005, 09:18 AM
 jdkobe
jdkobe's Avatar
Car: 05 Outback XT
Send a private message to jdkobe Find all posts by jdkobe Reply With Quote
DearKiller - Thanks for this.. I somehow missed this posting and have really been racking my brain on it. Much appreciated!
jdkobe
Find More Posts by jdkobe
#6: 04-05-2005, 09:25 AM
 John M
John M's Avatar
Sounds good to me. May I add your step to my site (proper credit of course)?
I hadn't pulled the column apart or looked at the manuals. I just assumed that the switch did the disconnect when placed into the high beam position (that it wasn't being fed switched ground). That's what I get for assuming!
John M
#7: 04-05-2005, 09:41 AM
 Lee MD
Car: 97 Legacy GT Wagon
Send a private message to Lee MD Find all posts by Lee MD Reply With Quote
Could someone post pics on how they do their wiring when performing this mod? Deer Killer's instructions seem very straightforward, but I'm challenged when it comes to wiring. Thanks in advance.
Lee MD
Find More Posts by Lee MD
#8: 04-05-2005, 10:01 AM
*Jedimaster*
Title: Guest
Posts: n/a
I'm challenged in that was as well. I was also hopign for pix like John M had.
*Jedimaster*
#9: 04-05-2005, 11:48 AM
 Deer Killer
Title: 50% air
Car: 05 LGT
No I've applied for a patent
Deer Killer
#10: 04-05-2005, 12:04 PM
 jdkobe
jdkobe's Avatar
Car: 05 Outback XT
John - I need send props to you - your information was helpful and helped me thru the mod too.
jdkobe
#11: 04-05-2005, 09:45 PM
 John M
John M's Avatar
Lee - my pics show the first part of the mod in greater detail. Then do the second part of the mod in Pic 5 above and you're good to go.
http://www.moojohn.com/subaru/fogmod.html
Deer Killer -
I just don't want to use your pics without your consent. I'm too lazy to break out the camera this coming weekend when I do that part of the mod
John M
#12: 04-05-2005, 09:52 PM
 Deer Killer
Title: 50% air
Car: 05 LGT
Deer Killer -
Go ahead..
Deer Killer
#13: 04-07-2005, 08:09 PM
 team23jordan
team23jordan's Avatar
Title: Powered by Kimchi
Car: 2011 STi Sedan
Send a private message to team23jordan Find all posts by team23jordan Reply With Quote
i'm gonna do this soon!!
team23jordan
Visit team23jordan's homepage!
Find More Posts by team23jordan
#14: 04-08-2005, 02:50 PM
 Drift Monkey
Drift Monkey's Avatar
Title: Banned
Car: Subaru Legacy 2.5GT 5MT
Find all posts by Drift Monkey Reply With Quote
I'm probably gonna have to do this mod this weekend. What constant on power should I hook up to?
Drift Monkey
Find More Posts by Drift Monkey
#15: 04-08-2005, 07:13 PM
 Bretm1
Car: 2006 Saab 9-3 Sportcombi
Send a private message to Bretm1 Find all posts by Bretm1 Reply With Quote
Deer Killer -
I think I got it, but just to be sure, only do mod five (or pic 5) from deerkiller if I want fogs to stay on with high beams.
Thanks-Bret
This is not my beautiful car.
Bretm1
Find More Posts by Bretm1
Similar Threads
JDM Sedan Tail lights are in.... Opie Exterior/Aesthetic 99 03-22-2011 05:46 AM
Has Any1 Figured Out How To Get Independent Fogs Yet? 06jax2.5se Exterior/Aesthetic 10 01-27-2007 11:58 AM
Well, don't bother with the Vision Plus bulbs... gtguy Exterior/Aesthetic 58 08-31-2005 03:38 PM
HELP! WTB:99 Legacy GT head lights & Fogs pimphand Older Legacy Performance 2 02-17-2005 03:27 AM
HELP! WTB:99 Legacy GT head lights & Fogs pimphand Member Classifieds - ARCHIVE 0 02-09-2005 08:47 PM
