Reload this Page "Bullet Proof" TMIC Kits
Page 1 of 33 1 2311 > Last »
#1: 07-18-2012, 07:24 AM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 5MT
CONTACT ME DIRECT HERE WITH ANY QUESTIONS: bptmic@gmail.com
Hi everyone!
For those of you who read this post http://legacygt.com/forums/showthrea...rx-158870.html you already know what this is. For those who haven’t read it, if you are still running you 05-09 LGT or 08+ WRX with the stock TMIC I highly recommend taking the time to read through the thread.
This modification has been around for some time now as an alternative to those looking to beef up their stock intercooler (either for durability or for increased boost levels) for a reasonable price—not everyone has the cash or the need for an aftermarket TMIC in order to meet their needs. One of the problems with the kit up until now is that the fabrication of the metal pieces required for the kit is difficult, time consuming, and potentially dangerous to those without a reasonable amount of experience in cutting metal. While my second attempt and making my own kit was successful, the first attempt ended with a pile of bent metal and bloody fingers.
With SeeeeYa’s permission (Thanks, Jeff!), I have been looking at some scenarios to get a number of kits fabricated professionally by a machine shop and I believe this will prove to be the solution to providing these kits to those who need them at a reasonable price. I’m pretty confident that the machine shop is set to produce some kits for me, and I’ve been given the go ahead to move forward with this as a homebrew vendor to supply them.
Two kits will be available:
  • Kit #1 ($70 shipped CONUS): will include all of the required aluminum pieces for the kit, drilled to the original specs for using threaded rod. You will need to buy your own mounting hardware (bolts, nuts, threaded rod, etc.); these pieces will also have a groove should you choose to use zip ties down the road for any reason.
  • Kit #2 ($90 shipped CONUS): will include all of the required aluminum pieces for the kit, plus 2 stainless zip ties to use in lieu of any other sort of mounting hardware (bolts, threaded rod, etc). Pieces in this kit will be straight-cut on each end (instead of angled) and a “groove” will also be machined along the entire length of each of the longer pieces to hold the zip ties; they will not be drilled unless specifically requested. This kit should have everything you need to "bullet proof" your stock TMIC. It should be noted that the stainless steel zip ties will need to be tightened sufficiently, which may or may not be able to be completed with normal tools (read: pliers, vice grips, etc.). It's highly recommended that you purchase a "CV Joint Banding Tool" to use to sufficiently tighten and secure the zip ties--it will make things immensely easier and you can pick one up online for ~$10-15.
Video of zip tie installation with the tool: http://legacygt.com/forums/showpost....5&postcount=83
To confirm, here’s what will be included in the kit:
  • Four (4) pieces of aluminum channel designed and cut to fit on the top/bottom of the stock TMIC where the end tanks attach to the core
  • One (1) piece of aluminum channel designed and cut to fit on the front passenger corner of the stock TMIC where the end tank attaches to the core
  • Two (2) stainless steel zip ties (ONLY IF KIT #2 IS SELECTED)
  • Instructions for installing the kit
ORDER YOUR KIT HERE: https://sites.google.com/site/bptmickit/
Where can I get the tool to tighten the stainless steel zip ties???
A few choices: NAPA Autoparts, Amazon (
here
here here
, or I prefer
this one
this one this one
I also think that some Autozone's rent them for "free" (you pay for it, then return it when you're done through their rental program).
I’d like to get 10 people to commit to buying a kit before I pull the trigger on getting the kits made (please let me know what type of kit you would like if you express interest). Once I’m confident that the interest is there I will notify everyone, ask for deposits, and get things going as far as getting a batch of the kits made. I’ll do my best to keep everyone up-to-date on timelines for production / delivery—my best estimate is that they should be ready for shipping within 2-4 weeks after I place the order.
I’ll keep a running list of those interested going here for now. If you have been added to this list mistakenly please let me know. Here's the list so far:
  1. .:Catalyst:. (kit #2) *PAID* *SHIPPED*
  2. Lucid (kit #2) *PAID* *SHIPPED*
  3. BoozeRS05 (kit #2) *PAID* *SHIPPED*
  4. Hadvw (kit #2) *PAID* *SHIPPED*
  5. Pako (kit #2) *PAID* *SHIPPED*
  6. Wakeupandbord (kit #2) (nasioc) *PAID* *SHIPPED*
  7. Gex (kit #2) *PAID* *SHIPPED*
  8. Marc999 (kit #2) (ottawasubaru.com) *PAID* *SHIPPED*
  9. B00ster (kit #2) *PAID* *SHIPPED*
  10. DeadGeneration (kit #2) *PAID* *SHIPPED*
  11. jtc4313 (kit #2) *PAID* *SHIPPED*
  12. maus (kit #2) *PAID* *SHIPPED*
  13. bflolegacy (kit #2) *PAID* *SHIPPED*
  14. brad_houck (kit #2) *PAID* *SHIPPED*
  15. GrayT (kit #2) *PAID* *SHIPPED*
  16. ktmrider (kit #2) *PAID* *SHIPPED*
  17. Tema (kit #2) *PAID* *SHIPPED*
  18. Ebranch (kit #2) *PAID* *SHIPPED*
  19. fmowry (kit #2) *PAID* *SHIPPED*
  20. TehRicer (kit #2) *PAID* *SHIPPED*
  21. mitskip (kit #2) *PAID* *SHIPPED*
  22. ScoobyTed (nasioc) *PAID* *SHIPPED*
  23. Chris GTO TT *PAID* *SHIPPED*
  24. TrooperWRX *PAID* *SHIPPED*
  25. Matthew D (unknown username) *PAID* *SHIPPED*
  26. UTwrestler22 *PAID* *SHIPPED*
  27. boxerbenny *PAID* *SHIPPED*
  28. ArtClassShank *PAID* *SHIPPED*
  29. Brock Samson *PAID* *SHIPPED*
  30. loc *PAID* *SHIPPED*
  31. thefultonhow *PAID* *SHIPPED*
  32. Eric S (unknown username) *PAID* *SHIPPED*
  33. JL42 *PAID* *SHIPPED*
  34. Roy D *PAID* *SHIPPED*
  35. James M *PAID* *SHIPPED*
  36. Ben G (unknown username) *PAID* *SHIPPED*
  37. Justin B (unknown username) *PAID* *SHIPPED*
  38. Jordan D (unknown username) *PAID* *SHIPPED*
  39. Sevak A (unknown username) *PAID* *SHIPPED*
  40. Ian P (unknown username) *PAID* *SHIPPED*
  41. ScottFW *PAID* *SHIPPED*
  42. Shello007 *PAID* *SHIPPED*
  43. dukeneverwinter *PAID*
  44. way2tall89 *PAID*
  45. CT08SpecB
  46. xt2005bonbon
  47. Drock73
  48. Joe (unknown username)
UPDATE (7/19): material will be delivered to the shop to begin production tomorrow!
UPDATE (7/24): after a hiccup with the first shop, material has been dropped off at shop #2.
UPDATE (7/31): machine shop has pushed the completion date for the millwork back to 8/10. Assuming this date holds true, the first kits will be in the mail on the 11th of August.
UPDATE (8/13): All the material is in hand and the first 8 kits are ready to go. As soon as I have the banding tools for the zip ties to include with these kits they will go out!
UPDATE (8/14): First kit shipped out, 14 kits sitting on the shelf ready to go
UPDATE (9/26): My current stock of material has all been cut into kits and will likely be sold out shortly. Three kits remaining at the moment before I have to look at the possibility of another production run. Thanks for the orders, everyone!
VERY IMPORTANT CAVEAT: The term "Bullet-Proof" when used in referring to this kit is not meant to imply that installing this kit will make your OEM TMIC impervious to high speed munitions fired from any sort of projectile weapon, device, machine or similar. This kit is only designed to prevent boost pressure from causing end tank separation, and nothing more.
DISCLAMER
Neither I nor the original designer of this kit can take responsibility in the case of damage to anything on your vehicle that results indirectly or directly from the installation of this modification. If you doubt your capacity, do not undertake the installation of this modification; ask for help or have it installed by someone qualified.
The Following 7 Users Say Thank You to BarManBean For This Useful Post:
.:Catalyst:. (07-18-2012), DeltaNu1142 (07-20-2012), GrayT (08-22-2012), jtc4313 (08-14-2012), laff79 (07-18-2012), Lucid (07-18-2012), Pako (07-18-2012)
BarManBean
Find More Posts by BarManBean
#2: 07-18-2012, 07:38 AM
 laff79
Title: Confrontation Specialist
Car: '05 ABP Legacy GT
Send a private message to laff79 Find all posts by laff79 Reply With Quote
bump for a good deal.
I'm the proud recipient of the first Barman kit and am very pleased to report that it shipped quickly and works like a charm.
Might need to do a little filing on the corners, but all-in-all a great, cheap way to ensure the life of the stock IC.
The Following User Says Thank You to laff79 For This Useful Post:
BarManBean (07-18-2012)
laff79
Find More Posts by laff79
#3: 07-18-2012, 07:48 AM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 5MT
This first kit was also a homemade version--the same type of kit is also installed on my car. It's my hope that by going through a machine shop for future kits that any extensive finish work will be unnecessary.
BarManBean
#4: 07-18-2012, 08:07 AM
 Pako
Pako's Avatar
Car: '08 LGT 5MT | Infamous1 Stg 2
Send a private message to Pako Find all posts by Pako Reply With Quote
This saves me all sorts of trouble. Add me to the list, kit #2 please. Thank you for putting together this package!!
Pako
Find More Posts by Pako
#5: 07-18-2012, 08:18 AM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 5MT
I should also mention that I would like for someone local to test the kit with the zip ties if possible prior to shipping all the remaining kits. Local means the Northern Virginia area. Let me know if you are interested in testing fitment / installation.
BarManBean
#6: 07-18-2012, 08:43 AM
 laff79
where do you get those 33'' ss zip ties if u dont mind me asking
laff79
#7: 07-18-2012, 08:45 AM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 5MT
McMaster-Carr has 'em.
BarManBean
#8: 07-18-2012, 09:10 AM
 96r50
Car: 2005 Legacy GT 5MT
Send a private message to 96r50 Find all posts by 96r50 Reply With Quote
Thanks BMB for getting this done!
I may have read this in the original thread and forgotten, but why is there only one short piece (for the front passenger corner) and not four (one for each corner)?
96r50
Find More Posts by 96r50
#9: 07-18-2012, 09:19 AM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 5MT
As I've understood it, that corner is actually the most prone to failure. When I installed my kit I actually spoke to Jeff about possibly omitting this piece since it seemed wasteful to buy a whole 8' piece of aluminum just for a 3" piece to install. He let me know that the passenger side corner on the front is the most prone to failure so the piece is necessary. To my knowledge, the other corners are not prone to failure, especially with the rest of the kit installed. You should not have a problem as long as you install the kit PRIOR TO any sort of extreme failure. The tabs on my intercooler were starting to separate a little bit (from 60k miles at stock boost), but they easily pinched back down and the kit has performed well through my stage 2 install, tune, and subsequent driving (~5k miles so far).
BarManBean
#10: 07-18-2012, 09:33 AM
 96r50
Thanks for the explanation. I'm in for Kit #2.
96r50
#11: 07-18-2012, 10:21 AM
 .:Catalyst:.
.:Catalyst:.'s Avatar
Title: AllWheelsDriven
Car: 2006 spec.B #163 stage.2 .:CryoTuned:.
Send a private message to .:Catalyst:. Find all posts by .:Catalyst:. Reply With Quote
Come on gang let's get a couple more commitments! I'm going stage 2 this weekend and need this to get me through until I'm ready to go with a PW TMIC (or the Grimmspeed if it's the right setup for me and is released in the near future). Cheap way to reinforce the OEM TMIC without the hassle or need for tooling to DIY!
.:Catalyst:.
Find More Posts by .:Catalyst:.
#12: 07-18-2012, 10:31 AM
 famaya26
famaya26's Avatar
Car: 05 LGT 5EAT
Send a private message to famaya26 Find all posts by famaya26 Reply With Quote
I hope this kit is still available next march. I hate not having money!
famaya26
Find More Posts by famaya26
#13: 07-18-2012, 11:05 AM
 laff79
maybe BMB will do a layaway plan for poor people
Shello007 (08-10-2012)
laff79
#14: 07-18-2012, 11:08 AM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 5MT
Layaway for mod junkies
The Following User Says Thank You to BarManBean For This Useful Post:
famaya26 (07-18-2012)
BarManBean
#15: 07-18-2012, 11:13 AM
 96r50
Doesn't this kit work for more than just the 05-09 LGT? I seem to remember SeeYa doing it on his current generation WRX. Would it be worth reaching out to some of those owners as well?
96r50
