The Official: Fastest Legacy Thread (1/4 and 1/8)
  • 4 months later...
  • Replies 311
Posted Images
Fastest LGT/OBXT (top 20)
1. 11.102 @ 130.97 - Grimlin
2. 11.137 @ 129.49 - Doogie29th 04STi 6MT
3. 11.320 @ 118.30 - O_vang
4. 11.400 @ 125.24 - Strizzy 6MT
5. 11.668 @124.24 - jmorris6689 6MT
6. 11.836 @ 127.44 - Bkatter
7. 12.094 @ 118.92 - wichitalegacy MT
8. 12.198 @ 113.70 - Tomcat 3.6L H6 MT
9. 12.210 @ 115.36 - 07spec_b 6MT
10. 12.210 @ 107.44 - dr20t 2004 Subary Liberty GT Auto
11. 12.352 @ 111.88 - Antny MT
12. 12.357 @ 117.79 - Legacy_GT_Pilot MT
13. 12.435 @ 111.19 - Legend 5MT
14. 12.532 @ 112.95 - Rome_STI 5EAT
15. 12.591 @ 108.59 - Rutchard 6MT
16. 12.665 @ 114.75 - ESP Dyno
17. 12.672 @ 112.33 - TRSCobra 5mt
18. 12.837 @ 106.37 - Trabbic MT
19. 12.856 @ 109.07 - hardtop65 5MT
20. 12.865 @ 105.43 - AKLGT (f/k/a trdvibe) 5EAT
bounced out:
12.908 @ 106.88 - SubLo MT
12.959 @ 106.60 - Tuned200 MT
13.045 @ 106.76 - dr_sharp 6MT
13.064 @ 107.33 - timbo7 5mt
13.066 @ 104.91 - 01legacygt 6mt (2010)
13.066 @ 103.96 - kevkel33leg05
13.090 @ 103.84 - tuned200 mt
13.332 @ 102.41 - pierce88 5eat
13.662 @ 98.65 - biz77 mt
13.695 @ 102.84 - mwiener2 mt
13.698 @ 100.23 - infamous1 mt
13.724 @ 103.11 - gmachine
13.810 @ 99.95 - johnno
13.851 @ 99.06 - izzy
I updated the top 20, adding new slips and removing a couple duplicates. BDII let me know if you don't think any of these should be on there because rules. Speaking of rules - lee07 - update your post with more deets and we'll get you on there.
I'll be running on the 3rd, hoping I can crack #20! :lol:
  • 3 weeks later...
Well finally hit the 1/4 mile and not so impressed. Spoke with some muscle guys and did some reading. Cars are set up way differently. Tread is low on the AS, they drenched the staging area and apparently that is a big deal for street tires. Also had to wait in line so had heat soak. Next time I'll bring the lap top for better info. Also, I guess I shouldn't really complain as this is supposed to be an east "GT" car made for the cruising the highway. Not jumping off the line.
Event: 1/4 mile Drag
Loaction: Gulfport Dragway
Date: 10/09/2015
14.2663 -@ 96.09 (Silinc3r) (5mt)
Ambient Temp: ~72F
Elevation: 17ft
Weather: clear at night
Car: 2005, Subaru Legacy GT/SpecB
Tuner: Anthony Berry, Drunkman tuning @PCola, FL
Track info: 1/4 mile
Transmission: 5speed
Peak Horse Power at RPM: ?
Peak Torque at RPM: ?
Fuel: 93 Shell Premium VPower
Engine/Power Modifications: VF52, DW65C fuel pump, BP TMIC, Perrin short ram, Megan full exhaust
Driveline Modifications: Stock clutch @ 110,000 miles, STi short throw
Suspension Modifications: BC BR coilover set at a little over halfway towards stiff, STi Genome front strut bar
http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG1488.jpg
Edited by Silinc3r
Elevation
Have some questions. I have no clue if this is the original clutch, car is at 110,000 now. If I launch on the road the tires will spin, tires are worn, so I know the clutch is ok. How much of a difference can a new clutch make? Also, same with the tires.
Running a 14.2 in a "stage 2" car just seems wrong. I did have about a 3/4 tank, 18s, stock spare, 06Spec B seats. I am going to try and go back soon, ditch the spare, run early so I don't heak soak and see if that makes a difference. I will also be logging this time.
You know its questions like this that lead to 5 digit engine builds, right?
Your 60 foot time is 1.9 seconds? Perhaps that's the first thing to work on. many others are 1/3 that or better. 60 feet is about the distance of an 4 lane intersection. off the line, you should be dumping the clutch around 4000 to 5000rpm not slipping. And your foot goes to floor until the next upshift.
If you practice on the street, have a good lawyer on speed dial.
You can practice in your driveway with a timer app. The lights are either .4 seconds or .5 seconds apart on the tree. Car is off. Timer starts. At whatever the countdown is you release clutch and plant your right foot. There is probably an app for this too.
At about 10-20 hard launches, you'll be needing new parts.
Hmmm, 4000-5000 you say? I have been doing at least 5000 because I don't want to bog. Also I wasn't using the tree since that is for reaction time only. No influence on ET.
I have done probably around 20 hard launches, though they have been at higher RPM so maybe that's my saving grace.
thanks for the advice!
I've been 1.7 60's before. But my clutch is woreeeeee out. 1st to 2nd gear change is well... terrible. Sounds like I never shift just mows through the clutch. You say your going 14s with a stage 2 car? There's something wrong. Probably needs. Driver mod. I had a stock lgt and have bee. 13.90s with an air filter and catback.
Yea, I was consistent though. I am going to try differet RPM for launch. If that doesn't do it, I'll wait for new tires.
Its not your starting rpm that's problematic its you don't start revving until the light goes green. the car next to you is already revved up before the green.
Also can you tell them not to wet the burn out pit down or drive around?
Shifts seem slow. looks steering wheel moves a bit too (cell phone screen is hard to tell).
That last upshift costs you - what if you just keep it at red line until cross the line?
The tree is only for reaction time. I wasn't worried about the guy, i was just focused on trying to break 14. Not sure if that's what you are referring too. Unless, you are saying I need to hlod the rpm longer before I dump it.
  • 3 weeks later...
okey dokey. first post is updated to have corrected times, using turkeylord's spreadsheet. I added 1/8 mile times for the 3 fastest 1/4 LGTs. Also added "proof" links for a few cars, including top 4 fastest.
If the proof link doesn't lead to the correct location, feel free to spam me with the correct link(s).
for future posts, following the template will get your post added sooner.
The proof links all go to the same location: O_vang's post.
I think you meant to say "Hey Boxkita, thanks for updating the first post with the current data. I'll help you sort out the links that are missing."
That said, I fixed the 3 quickest 1/4 proof links.
Edited by boxkita
You're right. That is what I meant to say. Thanks Boxkita.
Looks like 1st 4 are already correct ...
jmorris6689 - http://legacygt.com/forums/showpost.php?p=3851006&postcount=3
Bkatter - http://legacygt.com/forums/showpost.php?p=4795588&postcount=238
wichitalegacy - ?
Tomcat - ?
07spec_b - http://legacygt.com/forums/showpost.php?p=4082231&postcount=91
dr20t - http://legacygt.com/forums/showpost.php?p=4494109&postcount=176
Antny - ?
Legacy_GT_Pilot - ?
Legend - http://legacygt.com/forums/showpost.php?p=3870088&postcount=28
Rome_STI - http://legacygt.com/forums/showpost.php?p=4173932&postcount=131
Rutchard - http://legacygt.com/forums/showpost.php?p=4347552&postcount=151
ESP Dyno - http://legacygt.com/forums/showpost.php?p=4688814&postcount=235
TRSCobra - http://legacygt.com/forums/showpost.php?p=3870027&postcount=26
Trabbic - ?
hardtop65 - http://legacygt.com/forums/showpost.php?p=3941643&postcount=49
AKLGT - ?
Note that I didn't do much auditiing to make sure I had the exact right post (ie. matching a time with the listed time). I just grabbed the one that looked right at first glance.
Edited by Dujo
  • 2 months later...
