angeltalin Posted June 1, 2015 Share Posted June 1, 2015 I've developed a weird clinking noise in my rear here is the video about the strange clanking sound in my rear suspension area. I have been underneath and shaken everything all suspension, exhaust, brake dust shield and nothing duplicates this. Only occurs from 0-15 mph Going over bumps does not make it better or worse and doesn't even make a difference Im on coilovers I remove my wheels weekly for cleaning, and they are not rubbing on the coil or calipers Does anyone have an idea what this might be? as you can tell it is very loud (louder than my exhaust) I know it can be wheel bearing, endlinks are shot or some sort of bushing but was posting to see if anyone person had the same noise and knows what fixed it for them StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
gto7419 Posted June 6, 2015 Share Posted June 6, 2015 That sounds like a rock hitting thin metal. Have you checked around brake dust shield? Link to comment Share on other sites More sharing options...
angeltalin Posted June 6, 2015 Author Share Posted June 6, 2015 Yeah I have checked there, the dealer told me today something is my axle...I don't believe him StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
gto7419 Posted June 7, 2015 Share Posted June 7, 2015 You have a jack and jack stands? Put the rear of the car up on stands and rotate one wheel at a time. You should be able to locate the issue. Link to comment Share on other sites More sharing options...
angeltalin Posted June 10, 2015 Author Share Posted June 10, 2015 Ended up being valve stem hardware installed at discount tire, they dismounted and remount/balanced it and now is quite StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
