Hugo L. Posted January 31, 2012 Share Posted January 31, 2012 I generally let my car heat up before leaving for work during winter. The Legacy doesn't get very hot very fast, but it's not too bad. However, I noticed that when it's cold out (like around 0°F or something), it does blow hot air when I drive around town, but the air becomes lukewarm at best the minute I come to a stop at a light (or stuck in traffic). I have to rev the engine get it to blow hot air again. It's as if the cooling system is too efficient. Anyone else have that problem? Link to comment Share on other sites More sharing options...
joop1987 Posted January 31, 2012 Share Posted January 31, 2012 Thermostat failed in open state. Link to comment Share on other sites More sharing options...
Hugo L. Posted January 31, 2012 Author Share Posted January 31, 2012 So I replace the t-stat and I'm good to go? Link to comment Share on other sites More sharing options...
bmx045 Posted January 31, 2012 Share Posted January 31, 2012 or you're low on coolant. remember water output increases as rpms increase, therefore any hot coolant will flow through the heater core increasingly when system pressure is built and flow increases. At a stand still, if your shit is too low, the flow will probably be less than optimal. jack the car up only on the passenger side and open the turbo tank, burp the hoses and recheck level, you can also do this while the car is running Link to comment Share on other sites More sharing options...
doccrowley Posted January 31, 2012 Share Posted January 31, 2012 check your coolant levels. ^^^^^ Link to comment Share on other sites More sharing options...
Hugo L. Posted January 31, 2012 Author Share Posted January 31, 2012 Hmm, that's a good idea. Link to comment Share on other sites More sharing options...
