stangbanger95 Posted May 16, 2016 Share Posted May 16, 2016 05 legacy 5mt, fresh oil change and new banjo bolt with less than 1000 miles. Car is bone stock. Recently started making noise at 3800-4200 rpm, sounds like a clacking as if the turbo is about to let go or terrible knocking you can very obviously feel through the shifter. I'd think it's a throwout bearing or turbo problem but the noise goes away after 4200 rpm so my understanding was that if it was one of those things it would get worse the higher you rev not disappear. Any ideas? Link to comment Share on other sites More sharing options...
Wagonation Posted May 16, 2016 Share Posted May 16, 2016 Heat shield? About where my rattled. Link to comment Share on other sites More sharing options...
stangbanger95 Posted May 16, 2016 Author Share Posted May 16, 2016 There's no heat shield on the turbo, previous owner trashed it. seems like a bad throwout bearing/bad turbo but again the noise and extreme vibration wouldnt vanish the higher i rev.. Possible ignition problem? no CEL Link to comment Share on other sites More sharing options...
apexi Posted May 16, 2016 Share Posted May 16, 2016 Any abnormal sounds at idle? That's when my TOB squealed like a pig.. Link to comment Share on other sites More sharing options...
stangbanger95 Posted May 16, 2016 Author Share Posted May 16, 2016 sounds completely normal everywhere except 3800-4200 rpm where it wants to shake itself apart, i can't figure it out. Link to comment Share on other sites More sharing options...
Wagonation Posted May 17, 2016 Share Posted May 17, 2016 There's no heat shield on the turbo, previous owner trashed it. seems like a bad throwout bearing/bad turbo but again the noise and extreme vibration wouldnt vanish the higher i rev.. Possible ignition problem? no CEL Any of the heatshields. Just saying since that was precisely the frequency that my non turbo heatshields were rattling. I also lack turbo heatshield. Link to comment Share on other sites More sharing options...
stangbanger95 Posted May 17, 2016 Author Share Posted May 17, 2016 Thanks for the replys, turns out its the first and second gear bearings inside the trans, changing the fluid helped slightly but until i find a new 5mt just going to have to drive nicely. Link to comment Share on other sites More sharing options...
