SpecBamf41 Posted May 21, 2012 Share Posted May 21, 2012 So I got it running. Ran fine after I noticed the Tb was half open while trying to start it. After it raced to redline I figured that one out. Now my problem is it run like crap. Miss fire codes on cilinder one so far for codes and another that was unknown. But I can get it to show up again. Plus sometimes when it dies there is smoke coming back though the intake. I'm thinking my timing could of got messed up during the redline that lasted a sec or two. To tired to check. Done for the night Sent from my Galaxy Tab using TapaTalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
TbirdMan Posted May 21, 2012 Share Posted May 21, 2012 hmm, floated/bent valves? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted May 21, 2012 I Donated Share Posted May 21, 2012 So whats your question? Sounds to me like you grounded out the wrong pins. Your wiring went wrong somewhere. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
SpecBamf41 Posted May 21, 2012 Author Share Posted May 21, 2012 I didnt touch the ecu yet. i dont know what pin to ground out BNR18g on 93oct Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted May 21, 2012 I Donated Share Posted May 21, 2012 Well that's probably your problem -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
SpecBamf41 Posted May 21, 2012 Author Share Posted May 21, 2012 i cant find the pin. someone said pin 83 in a post i read but pin 83 is the ground for the speedo. BNR18g on 93oct Link to comment Share on other sites More sharing options...
SpecBamf41 Posted May 22, 2012 Author Share Posted May 22, 2012 timing was spot on. o well at least that means nothins broke broke. but now i cant even start it.. i took all the plugs out. clean the the tips and it didnt even help a bit. im getting fuel. and before when i had it running i pulled the wires off each and had an arch on all them. im out of ideas as to way it wont fire up. it must be spark related, or timing. i wish someone knew what pin i need to ground out. but i dont see how a at/mt pin could make this much of a problem. i thought it just changed to fueling maps. what comes before the coil pack? BNR18g on 93oct Link to comment Share on other sites More sharing options...
subikid90 Posted May 22, 2012 Share Posted May 22, 2012 It is pin 83 on the ECU -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted May 22, 2012 I Donated Share Posted May 22, 2012 Before the coil pack? The wiring. Bust out your multi-meter Since you tore a lot of stuff off and out of the car - check to make sure all your grounds are hooked up....and on CLEAN metal. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
SpecBamf41 Posted May 23, 2012 Author Share Posted May 23, 2012 Pin83 in my 97 fsm is listed on a grounds layout and leads to the speedo. And I'm wondering what that tiny ground wire is for that goes from the top of the dog bone mount and then to the block. Also what is the thing plunged in right there at the top of the dogbone Sent from my Galaxy Tab using TapaTalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
V8lolsubie Posted May 23, 2012 Share Posted May 23, 2012 I didnt touch the ecu yet. i dont know what pin to ground out That is your problem. Timing is very different between AT and MT ECUs. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted May 23, 2012 Author Share Posted May 23, 2012 Guess why it wouldn't start. I'm so dumb Sent from my Galaxy Tab using TapaTalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
Balrock Posted May 23, 2012 Share Posted May 23, 2012 Well, you said you were getting fuel so I am guessing the pump was ok....we give up. Why are you so dumb? Link to comment Share on other sites More sharing options...
SpecBamf41 Posted May 23, 2012 Author Share Posted May 23, 2012 I was getting drops of fuel. I was out of gas Sent from my Galaxy Tab using TapaTalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
SpecBamf41 Posted May 23, 2012 Author Share Posted May 23, 2012 Somehow the navy thinks ill make a good Nuke sailor. They got a piece of work coming to them. Sent from my Galaxy Tab using TapaTalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
