JLGT Posted April 25, 2013 Share Posted April 25, 2013 Just a simple write-up for those that might not know what is required in removing your headlights. Also to take away some fear that some members may have about bumper and headlight removal when changing bulbs or installing HID kits. ========================================= TOOLS: FLAT HEAD SCREW DRIVER 10MM SOCKET AND SOCKET WRENCH PROCEDURE: REMOVE YOUR FRONT BUMPER http://legacygt.com/forums/showthread.php/front-bumper-removal-2010-206177.html REMOVE THESE 2 10MM BOLTS AND 1 PUSH RETAINER http://i.imgur.com/kKuQsZo.jpg 10MM http://i.imgur.com/nydy820.jpg 2 10MM BOLTS http://i.imgur.com/FCNZySo.jpg REMOVE THE LOWER BLACK PLASTIC HEADLIGHT BRACE http://i.imgur.com/adQjhTF.jpg ON TOP OF THE HEADLIGHT REMOVE 1 10MM BOLT AND 1 PUSH RETAINER http://i.imgur.com/7UkJ3T8.jpg 10MM BOLT (KEEP A HAND ON THE HEADLIGHT TO PREVENT IT FROM FALLING AS YOU REMOVE THE LAST BOLT) http://i.imgur.com/cirOO76.jpg DISCONNECT THE GRAY CONNECTOR (PASSENGERS SIDE) http://i.imgur.com/zFz0iRM.jpg REPEAT STEPS ON THE DRIVERS SIDE , THE GRAY CONNECTOR IS A BIT SHORTER ON THE DRIVERS SIDE SO PROTECT THE FRONT OF YOUR HEADLIGHT AS YOU TRY TO REMOVE IT. http://i.imgur.com/vkNpZ0F.jpg ========================================= AS A QUICK BONUS: DISABLING YOUR DRL'S: DISCONNECT THE CONNECTOR SHOWN ON THE DRIVERS SIDE RIGHT NEXT TO YOUR WASHER FLUID RESERVOIR. TAPE UP THE CONNECTOR WITH ELECTRICAL TAPE. http://i.imgur.com/OSZzk1G.jpg Link to comment Share on other sites More sharing options...
SpidermanMTL Posted April 25, 2013 Share Posted April 25, 2013 You are one classy fellow.... STAY CLASSY DAMMIT! Great write ups! MY BUILD TAKE 2 : http://legacygt.com/forums/showthread.php/spideys-12lgt-take-2-266018.html Link to comment Share on other sites More sharing options...
redstriker Posted April 25, 2013 Share Posted April 25, 2013 Great write up! Link to comment Share on other sites More sharing options...
GTEASER Posted April 25, 2013 Share Posted April 25, 2013 Thanks so much JLGT!!! Now all I need is an I-Pad to keep in my tool box. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
islandborn Posted April 25, 2013 Share Posted April 25, 2013 This was perfect. I just sent in for Scott to JDM my lights out.... I'll be needing this soon. Link to comment Share on other sites More sharing options...
nstg8r Posted April 26, 2013 Share Posted April 26, 2013 What I did when I disabled my DRLs, was just pull the connector out half way and then tape it. This way it doesn't rattle around. I've since reconnected it, however. Someday, when I get the chance or I'm really, really bored, I'm going to create a relay harness that will use the DRL circuit but bypass the the high beams allowing us to add on an LED DRL setup. Link to comment Share on other sites More sharing options...
ebo03 Posted May 31, 2014 Share Posted May 31, 2014 Subscribed. Link to comment Share on other sites More sharing options...
testa422 Posted May 31, 2014 Share Posted May 31, 2014 phillips led DRL setup...man this pic was taken so long ao! Link to comment Share on other sites More sharing options...
Humble Rumble Posted August 16, 2017 Share Posted August 16, 2017 Posted this in the Front Bumper Removal thread too, but JLGT can you re-host and re-post your images using Imgur? They're currently all broken thanks to Photobucket. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
benleg Posted August 16, 2017 Share Posted August 16, 2017 Wish I could see the photos. What I see: PLEASE UPDATE YOUR ACCOUNT TO ENABLE 3RD PARTY HOSTING Love, Photobucket Link to comment Share on other sites More sharing options...
dgoodhue Posted August 16, 2017 Share Posted August 16, 2017 Wish I could see the photos. What I see: PLEASE UPDATE YOUR ACCOUNT TO ENABLE 3RD PARTY HOSTING Love, Photobucket Assuming one wants to pay $500/year for 3rd party hosting... Link to comment Share on other sites More sharing options...
JLGT Posted August 19, 2017 Author Share Posted August 19, 2017 Updated due to peebucket Link to comment Share on other sites More sharing options...
