NINmh Posted July 26, 2012 Share Posted July 26, 2012 I'm tearing apart my 2.5D, and if it comes down to replacing being cheaper than repairs, I will do exactly that. However, I have the ability to get my hands on a 2010 Impreza 2.5i (EJ253) engine, Non-Turbo unfortunately.. But, its cheap & with only 36k(kms) on it. What would I be looking at to make that work? Is it doable, or should I pass..? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 26, 2012 I Donated Share Posted July 26, 2012 It bolts right up. You may need to swap over intake manifolds though....and possibly the heads. I'm not 100% sure. Not really a swap most people do. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
99legacyturbo Posted July 26, 2012 Share Posted July 26, 2012 Most likely would bolt and run off your stock ecu Easy swapp Link to comment Share on other sites More sharing options...
SpecBamf41 Posted July 27, 2012 Share Posted July 27, 2012 the biggest problem people have are going to be the fact that if you wanna swap the whole thing then the wiring and sensors may and mostly likely wont make the ecu happy, so then people are like haaay, lets swap on the old intake mani, then they are like shit, the intake manis dont match different phase heads. so then you swap heads, next thing you know the only thing you replaced is the short block and knooter valve BNR18g on 93oct Link to comment Share on other sites More sharing options...
99legacyturbo Posted July 27, 2012 Share Posted July 27, 2012 ^^^^ good point Joe Link to comment Share on other sites More sharing options...
joelwatts Posted July 27, 2012 Share Posted July 27, 2012 imo, not really worth it. the 25d is easy to find and relatively cheap. and its direct bolt in, no hassle required. I'm a native of South Carolina. I am a dying breed. Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted July 28, 2012 Share Posted July 28, 2012 imo, not really worth it. the 25d is easy to find and relatively cheap. and its direct bolt in, no hassle required. ^^^just what he said. There isn't enough HP gain per amount of Money that you are going to dump into that swap. Either EJ25D it or go with more powerful motor then the N/A one. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted July 29, 2012 Share Posted July 29, 2012 Get a 3.3 Sent from my Galaxy Tab using TapaTalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted July 29, 2012 Share Posted July 29, 2012 Swag, you have to be a mechanic to get that 3.3 in there all said and done... Link to comment Share on other sites More sharing options...
SpecBamf41 Posted July 29, 2012 Share Posted July 29, 2012 Yea I would never do that to a dd. It would be a strippes down track car on Ms. Sent from my Galaxy Tab using TapaTalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
