garygbnj Posted March 3, 2016 Share Posted March 3, 2016 2010 LGT-Stage II (Catted Down pipe, Borla Catback, Accesport retuned-App 350HP) 5W-30 Synthetic. Changing oil & filter every 5k. Is there a consensus as to the best oil change frequency? Link to comment Share on other sites More sharing options...
Blizzard Posted March 3, 2016 Share Posted March 3, 2016 Pretty sure the factory interval is 3750? Think the 4th gen had a higher interval and they started having issues with the banjo line filters clogging. I've always done mine somewhere around 3750-4000 and the car has just about 80K on it now. Link to comment Share on other sites More sharing options...
Zee199969 Posted March 3, 2016 Share Posted March 3, 2016 You may wanna go with 5w40 synthetic esp if you are at stage 2. Have you been checking your oil with regularity to see how it is? I think previous owner's manuals said 3750mi but that was later changed to 5k. I have been doing 5k OCI with no issues but I'm only at stage 1 My "Build" Link to comment Share on other sites More sharing options...
FLlegacy Posted March 3, 2016 Share Posted March 3, 2016 Fairly sure the latest is 3750 OCI with any turbo ej25 model, is the minimum recommended maintenance interval. But in the real world UOA will tell you how well your oil is holding up. Link to comment Share on other sites More sharing options...
Ellesedil Posted March 3, 2016 Share Posted March 3, 2016 Pretty sure the factory interval is 3750? Think the 4th gen had a higher interval and they started having issues with the banjo line filters clogging. I've always done mine somewhere around 3750-4000 and the car has just about 80K on it now. Speaking strictly about factory oil change intervals, I researched this some time ago. The 2010 LGT had a 3750 mile interval. 2011 initially had a 3750 mile interval as well, but was later changed to 7500 miles. In 2012, every vehicle in Subaru's lineup had a 7500 mile interval. Link to comment Share on other sites More sharing options...
dohclgt Posted March 3, 2016 Share Posted March 3, 2016 I'm using t6 5w-40 oil. Been changing it every 3,000 miles. Then I sent in a sample to blackstone and got back good result. They say to try 5k OCI. My car doesn't burn a drop of oil and I check it almost every week. Then it hit me..... I love this car too much... Link to comment Share on other sites More sharing options...
Blizzard Posted March 3, 2016 Share Posted March 3, 2016 Speaking strictly about factory oil change intervals, I researched this some time ago. The 2010 LGT had a 3750 mile interval. 2011 initially had a 3750 mile interval as well, but was later changed to 7500 miles. In 2012, every vehicle in Subaru's lineup had a 7500 mile interval. Sounds right from what I can remember (I've had this car for 6 years now ). I'd still shorten the interval up from 7500 if it were me. Link to comment Share on other sites More sharing options...
GTEASER Posted March 4, 2016 Share Posted March 4, 2016 I use 5k mile interval with Castrol Edge 5W-30 full synthetic and do a Blackstone oil analysis every 2 oil changes or 10k miles. All my reports have come back good with minimal breakdown of viscosity. I even ran a track day on each of the last 2 samples taken and it was fine. No oil consumption or oil added between changes. I have been at Stage1 for the last 3 analyses and am at 53k miles now with the car. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
acumenhokie Posted March 4, 2016 Share Posted March 4, 2016 5w40 every 3750 miles. Link to comment Share on other sites More sharing options...
Unsp0kn Posted March 4, 2016 Share Posted March 4, 2016 5W40 and I just changed mine a few hundred miles ago, planning on changing it again in about 2500 for my 60K maintenance and then going 5000 from then on. Link to comment Share on other sites More sharing options...
garygbnj Posted March 4, 2016 Author Share Posted March 4, 2016 Per the replies some are using 5w-30 per Subaru and some are using 5w-40. Why violate the viscosity recommendations of Subaru? Link to comment Share on other sites More sharing options...
Sarang Posted March 4, 2016 Share Posted March 4, 2016 Per the replies some are using 5w-30 per Subaru and some are using 5w-40. Why violate the viscosity recommendations of Subaru? In the owners manual it suggests a range of viscosity recommendations up to 20w-50. it has temperature ranges for them. Some are better in colder climates and some better for the Phoenix heat. It does say that 5w-30 is always preferred though. Link to comment Share on other sites More sharing options...
