iv_05gt Posted July 27, 2013 Share Posted July 27, 2013 Well, I swapped the injectors, (finally) installed new turbo inlet hose, Replaced the intake manifold - tgv gaskets, tightened every vac line, replaced 02 sensors and i still couldn't find what was causing the idle misfire. Compression & leak down test confirms cyl 4 has internal issues. Time to start saving (thankfully it's not my daily). Link to comment Share on other sites More sharing options...
06legsleeper Posted July 27, 2013 Share Posted July 27, 2013 damn that sucks man ... i just went through a misfire on cyl 3 .. i changed the plugs, pack on 3 and finally did my injector and she running great so far .. no miss that i can hear . and i scanned her and nothing .. i had a compression test and leak test done and it all came back good so the injector was my last thing . besides using 2 cans of brake cleaner to check for leaks .. and came back good Link to comment Share on other sites More sharing options...
subiestang Posted July 28, 2013 Share Posted July 28, 2013 Sounds like a bent valve. Ive had cars at work misfire at idle but smooth out when revving or driving. The valve stems are so thin that they actually had some flex in them. When I did the leak down, the stem would bend shut and I couldn't determine they were bent without removing them from the head. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 28, 2013 Share Posted July 28, 2013 I'm betting burnt valves in #4. Fairly common for cars on the factory MAP. OP does the engine use oil ? If no, you may be fine just having the heads rebuilt. The engine still has to come out, is there anything else that needs replacing while its out like a clutch, FW, up pipe? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
iv_05gt Posted July 29, 2013 Author Share Posted July 29, 2013 I'm betting burnt valves in #4. Fairly common for cars on the factory MAP. OP does the engine use oil ? If no, you may be fine just having the heads rebuilt. The engine still has to come out, is there anything else that needs replacing while its out like a clutch, FW, up pipe? It uses a significant amount of engine oil. Clutch and lwfw are like 40k old. Need to do the center diff bearings. I've been tuned for about 50k as well. Just going to continue saving and go through the car completely next spring. Many miles of me driving it like I stole it has worn everything out. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 29, 2013 Share Posted July 29, 2013 It uses a significant amount of engine oil. Clutch and lwfw are like 40k old. Need to do the center diff bearings. I've been tuned for about 50k as well. Just going to continue saving and go through the car completely next spring. Many miles of me driving it like I stole it has worn everything out. Like, how much oil does it use? And who tuned the car? just wondering.. Link to comment Share on other sites More sharing options...
iv_05gt Posted July 29, 2013 Author Share Posted July 29, 2013 Shamar @ infamous did my tune. It uses almost it's capacity in oil every oil change. (I knew this day was coming and i'd have to rebuild at some point). I let the issue slide. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 29, 2013 Share Posted July 29, 2013 Shamar @ infamous did my tune. It uses almost it's capacity in oil every oil change. (I knew this day was coming and i'd have to rebuild at some point). I let the issue slide. So it's like a quart every 1k then. When did it start using that much oil? Link to comment Share on other sites More sharing options...
iv_05gt Posted July 29, 2013 Author Share Posted July 29, 2013 Hmm.. over a year ago (it hasn't been a daily driver in over a year. I've put maybe 7k miles on it over the last year.) It always used oil from day 1 when i got it used. It just started using more and more oil over time. At this point when i went to take it for a ride i'd check the oil, top up and go. I've never really kept track of it's oil consumption other then making sure it was always topped up. Link to comment Share on other sites More sharing options...
SubOperator Posted July 29, 2013 Share Posted July 29, 2013 Similar story here as far as oil consumption goes. May be it's RI thing? Mine always used oil since I got it with 9K mileage, consumption went a little higher after I went Stage 2 (BNR16 & Shamar's tune). My only issue with idling was resolved with timing belt change at ~100K. I am at 140K now. Time to check the compression on cylinders for me. 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 248K 2007 B9 Tribeca Limited DGM - 258K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 29, 2013 Share Posted July 29, 2013 Mine always used oil since I got it with 9K mileage, consumption went a little higher after I went Stage 2 (BNR16 & Shamar's tune). How much were you using before and after the tune? Link to comment Share on other sites More sharing options...
jp233 Posted July 29, 2013 Share Posted July 29, 2013 Wow. Well, you can save yourself some additional money if you don't beat the piss out of it anymore until you pull the motor, because you may be able to re-use or sell some of the parts (mainly thinking cases, crank, and heads here).... and if something really bad happened you can lose the turbo too, obviously. Did you try the ole' compression test oil trick? put a dab of oil in the low compression cylinder and repeat the compression test. If it goes up, it generally points to the jug, ring, bore..... if not, it's likely valves. Link to comment Share on other sites More sharing options...
iv_05gt Posted July 29, 2013 Author Share Posted July 29, 2013 I pulled insurance from it, ordered a car cover. It's going to sit for a while. If i'm gonna overhaul it i'm gonna do it right & fun. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 29, 2013 Share Posted July 29, 2013 i pulled insurance from it, ordered a car cover. It's going to sit for a while. ^ if i'm gonna overhaul it i'm gonna do it right & fun. ^ Link to comment Share on other sites More sharing options...
iv_05gt Posted July 30, 2013 Author Share Posted July 30, 2013 It's not that bad. my 3.0R rides/handles better then my LGT. Where it's not as fast, or nice sounding, or manual, or turbo..... It's not bad at all on a spirited drive. It will hold me over until I can swing some neat car parts Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 30, 2013 Share Posted July 30, 2013 my 3.0R rides/handles better then my LGT. Really? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 30, 2013 Moderators Share Posted July 30, 2013 iv_05gt, you're doing this ALL sorts of right. I hope I'm in a similar situation if I ever have to do any motor work. Instead of a second car, I'm just hoping to have a built shortblock on the shelf for when/if something happens (picking up a donor block in a couple weekends ). Look forward to a build thread! "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
SubOperator Posted July 30, 2013 Share Posted July 30, 2013 How much were you using before and after the tune? On average I'd say 1/2qt before the tune and 3/4qt after. Now, I got the turbo swapped as well at the same time I got the tune, and new turbo oil lines *without* the filter. The oil consumption is not constant, it's very low if I stay off the boost and do not ride fast for long periods of time. In this scenario I can go through 3,75K OCI with ~ 1/2qt loss or less. If I do lots of WOTs though then it gets much worse. Obviously with Stage II tune there are lot more WOTs and fast rides for long distances(in the summer I travel up and down NE coast a lot). 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 248K 2007 B9 Tribeca Limited DGM - 258K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
SubOperator Posted July 30, 2013 Share Posted July 30, 2013 It's not that bad. my 3.0R rides/handles better then my LGT. Where it's not as fast, or nice sounding, or manual, or turbo..... It's not bad at all on a spirited drive. It will hold me over until I can swing some neat car parts Good luck. PM me if you need any tools/etc in a hurry or on weekend, I am in Richmond/Exeter border area, off RT 102. I'll have my son's OB as a reserve car once he departs to college 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 248K 2007 B9 Tribeca Limited DGM - 258K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
iv_05gt Posted July 31, 2013 Author Share Posted July 31, 2013 Really? My '09 3.0R Limited has the the Bilstein suspension w/ Aluminum parts just like the SpecB with stock 18's and 45k miles. My '05 2.5GT Limited has basic suspension, everything is warn out with aftermarket 18's w/ almost bald tires and 146k miles. Yup it handles better. Sub Op. I used to work as a tech @ speedcraft VW so i've got a lot of things. But i just might hit you up for a hand! Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 31, 2013 Share Posted July 31, 2013 My '09 3.0R Limited has the the Bilstein suspension w/ Aluminum parts just like the SpecB with stock 18's and 45k miles. My '05 2.5GT Limited has basic suspension, everything is warn out with aftermarket 18's w/ almost bald tires and 146k miles. Yup it handles better. Sub Op. I used to work as a tech @ speedcraft VW so i've got a lot of things. But i just might hit you up for a hand! Makes sense now. I did not know the 3.0R had the SpecB suspension parts. Link to comment Share on other sites More sharing options...
jp233 Posted July 31, 2013 Share Posted July 31, 2013 Having another vehicle is nice. My ho-hum 94 does well, especially since its a wagon so I can carry a bunch of stuff in it when needed. It is sure nice to have parts around ready for a rebuild though, I've gone through this several times with several toys. Right now since an 06 LGT is still without a mounted motor, anytime I want to dial up some boost I get in the F-250 and hammer it - 20psi on that thing makes it seem like the end of days is about to happen... but fun and LOUD! Link to comment Share on other sites More sharing options...
